Old Oct 18, 2012, 09:57 AM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Originally Posted by cdee View Post
jimbo.... the carbon rods go on both sides of the fuselage. There should be one long and one short per side, each starting from the nose, about 1/8" forward of the motor mount.
cdee
Where does the short rod go? It's not mentioned on the instructions or have I missed it?
Thx.
jimbo320 is offline Find More Posts by jimbo320
Old Oct 18, 2012, 10:04 AM
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Thx.
After you glue the wing in - step 28.
cdee
cdee is offline Find More Posts by cdee
Old Oct 18, 2012, 11:55 AM
Slopeaholic
jimbo320's Avatar
Joined May 2011
cdee
Yeah sorry i shoulda read the instructions all the way through...
What prop/motor/esc/batt are were using on this, what power output are we getting and what flight times?
As yet undecided what combo to get, lotttsa power would be good... I want fast vertical performance if poss.
Old Oct 18, 2012, 12:23 PM
Team Twisted!
cdee's Avatar
Joined Jun 2011
I tried the 78 and 100 gram motors, for better vertical, the 100g motor, don't remember the prop I have on it. I'll check and let you know.
cdee
Old Oct 18, 2012, 12:40 PM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I'm getting good verticals using the 78g motor which supplies 350 watts. :-)
The 100g motor may require the battery to be pretty far back under the wing. Using the 78g with 1800 and 2200mah lipos, my battery locations are already behind the leading edge of the wing.
KE Spin is offline Find More Posts by KE Spin
Old Oct 18, 2012, 01:19 PM
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
My battery is already half way back behind the leading edge of the wing with 1800 packs and I use the 78g motor.
winndaddy is offline Find More Posts by winndaddy
Old Oct 18, 2012, 01:25 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Thats the one thing with my CY and pitts, ive noticed the pull up out of prop hangs is pretty slow. Would like the Extra to zoom out...
Old Oct 18, 2012, 01:32 PM
Team Twisted!
cdee's Avatar
Joined Jun 2011
If you have the 24g or 26g motor... put 3s and a 8x4.7 on your Pitts, you will love it... the only way I fly mine anymore.
cdee
Old Oct 18, 2012, 02:09 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Do i swiss my Extra?..
Hmmm. That fuz looks plenty strong enough for some signature slopeflyer swiss cheese
Has anyone ever used white gorrilla glue to fit these carbon spars? Its pretty common place on the slope scene.
Old Oct 18, 2012, 05:57 PM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I initially used CA to glue in the cf spars but CA is brittle and broke loose in a few places. I then used some Beacons 3-in-1(advanced craft glue...it's like the foam tac) and have had good luck so far. :-)
I used the White Gorilla glue on a different plane recently and was kind of disappointed with it. Like the original GG much better.
Old Oct 19, 2012, 09:14 AM
United States, IN, Fishers
Joined Jan 2011
For those that are running the torque 2818/900 motor, has anyone tried using a small 4s pack?
I like crazy power!
Also, after reading thru all the threads, I could not tell if there is any consensus on the 78g or 100g set up. Which is overall the ideal set up for this foamy?
platnuim1 is offline Find More Posts by platnuim1
Old Oct 19, 2012, 04:25 PM
Carlsbad, New Mexico
Joined Feb 2004
I am using the torque motor, but have not tried a 3s pack. I run an apc 12x6 electric prop. To me, it has plenty power. It jumps out of a hover, and accelerates going up. I wish my gassers jumped like this. I would imagine on a 4s you would need to drop down to a 9x6 or 10x6, but I have no idea. It makes great power the way it is.
noahb is offline Find More Posts by noahb
Old Oct 20, 2012, 07:49 AM
Slopeaholic
jimbo320's Avatar
Joined May 2011
When i fit the wing, there is a gap/slot at the rear of the wing, in the fuz, where the ailerons sit.
It looks like to faciliate entry of the wing?
Shouldnt this be plugged up with some old foam? What is this gap for?. Clearly this gap at the back of the wing in the airframe is going to weaken it quite a lot...
Thx.
Old Oct 20, 2012, 10:53 AM
Team Twisted!
cdee's Avatar
Joined Jun 2011
Thx.
I believe the intent of Telink is for you to tuck the Rx in this area. I used it to pass the servo wires through from the aileron servos. You could plug it, but it's not necessary.
cdee
Old Oct 20, 2012, 12:25 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
We're getting there. Getting close, just install and motor fit.This is a monster compared to my other planes.
I need your help here guys, so what wattage motor/prop/esc do i need to get decent accelaration out of prop hangs?
I was comparing my Crack Yak and Pitts today, the pitts has a lot more power as it has a hyperion motor. Really noticed it today, as there was no wind. I want to get this right with the telink, Id rather spend a few more $$ to get more power, and get the performance i want.
Is the 78 or 100g motor gonna give me this?
Thanks guys.
Sold Telink / Twisted Hobbys Extra Slick SU-29 LPU Monroe, MI bcucoach2 Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 10:59 AM
Sold NYC LPU: Brand New Built 33" EPP Extra 330 SC livinma1 Aircraft - Electric - Airplanes (FS/W) 9 May 30, 2012 07:19 AM
Sold 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2012 08:09 PM
For Sale 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Fuel - Airplanes (FS/W) 4 May 16, 2012 10:45 AM
