Old Sep 05, 2012, 08:18 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Any flight footage guys ?
Kris... is offline Find More Posts by Kris...
Old Sep 05, 2012, 08:46 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
From the previous page:
Ray-Telink2 (3 min 8 sec)
KE Spin is offline Find More Posts by KE Spin
Old Sep 05, 2012, 09:11 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
See this one KE i want more
Old Sep 05, 2012, 11:18 AM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Did you see the 1st vid on page 12 of this thread?
Old Sep 06, 2012, 02:23 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Update:
Got my 2200mah lipos (6 oz.) and really like them in the Extra 330. Had to move them back 1" from where the 1800's mount but really like the increase in power and they finish my 5 1/2 minute flight times pretty strong as well being nice and cool.
Note: Using the 79g Telink motor.
Old Sep 06, 2012, 02:26 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
KE Spin... I will have to weigh my 2200 packs.. I was pretty happy with how it felt in the air as well with the big packs, especially when it was "breezy" out...
cdee
cdee is offline Find More Posts by cdee
Old Sep 06, 2012, 02:27 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Cdee,
Yes, my thoughts as well. Little more weight and power for the wind.
Old Sep 06, 2012, 03:53 PM
winndaddy is offline
Find More Posts by winndaddy
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
Sorry but a batteries mah rating has no effect on power, just flight time. Power comes from the C rating or how many cells a battery has.
winndaddy is offline Find More Posts by winndaddy
Old Sep 06, 2012, 04:37 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
But I would have though that say an 1800mah 25C would give you so much power for a given set up but if you ran a 2200mah 25C on the same set up it would be able to hold it's voltage better therefore giving you more power. Whether that power makes up for the extra weight or not is a different matter.
Aviefly is offline Find More Posts by Aviefly
Old Sep 06, 2012, 04:45 PM
slippyr4 is offline
Find More Posts by slippyr4
Joined Apr 2007
No: for a given "C" rating, a higher capacity pack has a lower internal resistance.
slippyr4 is offline Find More Posts by slippyr4
Old Sep 06, 2012, 04:50 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Windaddy,
Yes, I have heard that for number of years but find it is just simply not completely true. Here's a little test for you. Put a 1000mah battery in your 330 and go fly...then put a 2200mah in your 330 and go fly. Not just longer flight time but MORE power.
For the record, I can see and experience much better verticals with my 30c 2200mah lipos than with my 40c 1800mah lipos.
The C rating can be a little tricky. The ESC will not allow you to fully realize say 60c because the energy would be released too fast and would burn things up. The calculation would tell you that at 60c, the battery would discharge in 1 minute..this does not happen because the ESC regulates the rate of discharge so high C ratings can be somewhat misleading other than lower internal resistance and allowing the battery to perhaps run a little cooler and perhaps shorter charging time.
I will get my watt meter out and see what it says regarding both batteries.
Old Sep 06, 2012, 05:11 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Given two batteries of the same C rating but different capacities, the higher capacity battery is capable of delivering more amps for a longer period and thus more power.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Sep 06, 2012, 05:38 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Jet,
Yes, have to agree with that. Interestingly, my watt meter said that both my 30c 2200's and my 40c 1800's (same name brand and both new with only a few cycles, balanced and charged to 12.6v) initially delivered 350 watts using the Telink 79g motor. Based on C rating alone, the 40c 1800's should have intially delivered more power but did not...it was the same at the 30c 2200's. (As regulated by the ESC at these C ratings).
However, moving toward the end of my 5 1/2 minute flying time the 1800's tailed off (as seen on verticals) but my 2200's remained strong throughout. Yes, there is just more energy available so stronger performance over the run time.
Old Sep 06, 2012, 05:50 PM
winndaddy's Avatar
Joined May 2012
Originally Posted by KE Spin View Post
Jet,
I guess I learn something new all the time. Thanks for clearing that up.
Old Sep 06, 2012, 05:51 PM
Burke, VA
Joined Sep 2009
We also have to remember in a test like this that the motor is only going to demand so much, to truly stress test them you would want to use a motor that would theoretically demand as much amps as the largest battery could deliver and then compare that amount of watts to the amount that the smaller battery would deliver. After all a good example would be a 1000 mah 20c batt is capable of 20 amps continuous, but a 1000 mah 30c batt is capable of 30 amps continuous, so a motor capable of drawing say 40 amps would pull the max amount from the batts telling you the real ability of the batts to perform.
Sold Telink / Twisted Hobbys Extra Slick SU-29 LPU Monroe, MI bcucoach2 Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 10:59 AM
Sold NYC LPU: Brand New Built 33" EPP Extra 330 SC livinma1 Aircraft - Electric - Airplanes (FS/W) 9 May 30, 2012 07:19 AM
Sold 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2012 08:09 PM
Sold 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Fuel - Airplanes (FS/W) 4 May 16, 2012 10:45 AM
