Old Sep 03, 2012, 03:27 AM
asad is offline
Find More Posts by asad
Joined Oct 2006
Originally Posted by winndaddy View Post
Sorry, I should have been a little more specific. But, yes, its the Scorpion SII 3008 1090kv motor. Motor is slightly warm after a hard run. All my Telink planes have the aluminum motor mount. It fits perfect. Can't comment on the wooden mount. I tossed it in the trash since I wouldn't be using it. I did run both the Scorpion and the TH's 78 gram motor on the Extra just to compare. Plane flew great with both. Understandably though, the Scorpion just has way more grunt.
Thanks. I'm happy to know it's good because I've already ordered this motor basing my selection on the fact that Ido Segev was using quite a heavy motor on his extravaganza in his debut video of the model.
asad is offline Find More Posts by asad
Old Sep 03, 2012, 03:30 PM
noahb is offline
Find More Posts by noahb
Carlsbad, New Mexico
Joined Feb 2004
Winndaddy,
What size motor and battery are you running in the slick? My son is wanting to get one of the slicks. I am going to run 1800 on my extra, so if the 1800 would work on the slick that will be great. Let me know,
noahb is offline Find More Posts by noahb
Old Sep 03, 2012, 03:47 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Noahb,
I have cut my Extra 330 wing down to only 1" longer than the Extra Slick and it handles the 1800 mah lipos very well. The 1800 mah lipo should work fine in the Slick..gives just a tad bit of weight for wind penetration, snaps, etc while certainly NOT overloading the wing/airframe.
Got another video today..should be up later this evening.
KE Spin is offline Find More Posts by KE Spin
Old Sep 03, 2012, 05:25 PM
winndaddy is offline
Find More Posts by winndaddy
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
Originally Posted by noahb View Post
Winndaddy,
I use the recommended 70gram motor from Twisted. For the battery, I mainly run 1600mah 25c packs. But I do run 1800mah 30c packs when the 1600's aren't charged. Both work great so you'll be fine.
Winn
winndaddy is offline Find More Posts by winndaddy
Old Sep 03, 2012, 05:44 PM
winndaddy's Avatar
Joined May 2012
You'll have to trim just a little off the nose to fit it. Also, battery placement will be further back that normal. Mines a little nose heavy running 1800 packs but its not bad. I did use a good bit of glue on the front though. Tried a 11x3.8 sf prop also. Maneuvers seem to be easier to perform with it over the 11x4.7. Not to mention, its more efficient.
Old Sep 03, 2012, 08:00 PM
winndaddy's Avatar
Joined May 2012
Well, my 330 is now a 44.5 incher. I'm gonna let the glue for the balancers set over night. I'll give her a go tomorrow.
Old Sep 03, 2012, 08:59 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Winndaddy,
I think you'll really like it at that size. At the original size the 330 is surely an excellent plane, however, with the slightly abbreviated wing span I like it even better.
Old Sep 03, 2012, 10:11 PM
winndaddy's Avatar
Joined May 2012
I'm gonna install SFG's just for the heck of it. Got some epp sheets laying around.
Old Sep 03, 2012, 10:13 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Ok, so here is the last of my mods:
I increased the rudder height by about an inch. The 330 is already a good "harrier" machine, but the slight increase in rudder height makes it just tad bit better. I found that the 330, for me anyway, was better in upright harrier than inverted harrier which is counter intuitive.
Normally, when flying upside down (with rudder down in clean air) inverted harrier is generally better than upright. However, after increasing the rudder height I saw an improvement in inverted harrier flight. I can also get tigher circles in harrier and even more response to all rudder inputs with no adverse effects. Once again, the plane was plenty capable before, just seems even better now.
I believe this is the last thing that I will change as Telink really did an excellent job on the 330. I just tweaked a couple things to personal preference.
Old Sep 03, 2012, 10:15 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I would be interested to see the results.
Have you installed the wing fences that came with the ARF?
Old Sep 03, 2012, 10:54 PM
winndaddy's Avatar
Joined May 2012
No, should I have? Big difference? The reason for me installing some SFG's has more to do with esthetics than anything. If it doesn't effect it negatively I'll be happy. I'm painting them red. Haha...
Old Sep 03, 2012, 11:00 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I have found that some planes "like" SFG's and with others, it makes no difference. However, when it comes to "wing fences"...the sfg looking things that came with the plane..I have found a near universal improvement on almost any plane. These are mounted in from the the wing tip around 150-160mm on the 330. Having flown with them on and off....definitely put them on...right where the manual says.
The wing fences stop the "span-wise" flow of air essentially across the airfoil and get it headed back toward the trailing edge. The benefits are improved stability, reduction or elimination of wing rock, better tracking and some improvement in ke flight.
Give them a try and oh yes, I like RED.
Old Sep 04, 2012, 09:59 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Hope everyone had a fun and safe Holiday Week-End....!
did a fair amount of flying myself. Tried the big motor (100g) from Twisted Hobbys and 2200 mAh packs, really liked the heavy setup, especially good when the wind was up.
Really enjoying all the posts that you all are putting out there with your thoughts, mods, etc, etc., it is a great airframe, Ido and the Telink crew did a great job!
Don't be shy about sharing more pictures and videos...
cdee
cdee is offline Find More Posts by cdee
Old Sep 04, 2012, 11:52 AM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Cdee,
Yes, got some flying in and another video. Will try to get it posted a little later.
I've got Telink 78g motor installed and I also have some "light" 2100mah lipos coming. Should be interesting. As you know I "clipped" the wing a little but I'm interested how the full 48" would fly on the 100g motor and 2100mah or so lipos...got any video?
Old Sep 04, 2012, 12:25 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Cdee,
No current video of the heavy s/u.. will work on getting one in the que, maybe this coming week-end... The 2200s I flew with over the week end were the Hyperions out of my 450 Trex.. lol! Not sure on the weight, I think thou that hyperions tend to the heavy side. Only have a couple 2200 packs at the moment, going to get more in the next week or so.
cdee
Sold Telink / Twisted Hobbys Extra Slick SU-29 LPU Monroe, MI bcucoach2 Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 10:59 AM
Sold NYC LPU: Brand New Built 33" EPP Extra 330 SC livinma1 Aircraft - Electric - Airplanes (FS/W) 9 May 30, 2012 07:19 AM
Sold 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2012 08:09 PM
Sold 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Fuel - Airplanes (FS/W) 4 May 16, 2012 10:45 AM
