Old Aug 29, 2012, 11:29 PM
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Agreed ! looks a blast KE
Kris... is offline Find More Posts by Kris...
Old Aug 30, 2012, 04:37 AM
Burke, VA
Joined Sep 2009
I like the way it elevators and harrier's, no wing rock. That's the one thing I don't like about the ExtraSlick, at high aoa too much wing rock. If you keep the aoa lower it's fine but I can't get a decent elevator out of it at all.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Aug 30, 2012, 10:01 AM
Renton, Wa.
Joined Feb 2006
Upright harriers are rock solid on this one, which is one of the things I really like about this plane. Another thing I'm impressed with is how precise it is, just point it and it goes.
stevelmaa is offline Find More Posts by stevelmaa
Old Aug 30, 2012, 10:44 AM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Yes, one of the things that I like the most about the Telink Extra 330 is that it has NO wing rock.
KE Spin is offline Find More Posts by KE Spin
Old Aug 30, 2012, 05:23 PM
Joined Jul 2008
Curious what people are doing on the hinge. It comes with 5, but uses 6 in the instructions. Are you only using 2 pieces instead of 4 on the rudder?
alchem is offline Find More Posts by alchem
Old Aug 30, 2012, 05:24 PM
Crack Team
Dan5.0's Avatar
Joined Dec 2008
Not too sure on the 330 but on my other Telinks I cut mine in half so I actually had some material left over.
Dan5.0 is offline Find More Posts by Dan5.0
Old Aug 30, 2012, 05:58 PM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Yes, I believe the instructions (which are pictorial) show the hinges being cut in half. That's what I did. :-)
Old Aug 30, 2012, 06:03 PM
Joined Jul 2008
Yeah I know, but you use two for the wings 2 for the elevator, and 2 on the rudder, which gives you 4 hinges on each after being cut. 12 total, but only 5 hinges to cut, only giving 10.
Old Aug 30, 2012, 06:06 PM
Joined Jul 2008
Wish I didn't do step 2, as it may not have needed them. I'm a heli guy getting into planes, so I have tons of ball links, no hinge material. Guess I need to stock up.
Old Aug 30, 2012, 06:13 PM
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Hinge Material...
Early kits have 5 fiber hinges in them, next batch will have 6 fiber hinges. In the mean time, if you have an extra one around the shop you can use that, or when doing the Rudder and Elevator, cut those into thirds instead of half. Sorry for the confusion, should have mentioned something about that in the build pics. It is mentioned in post #1 under "Build Comments".
cdee
cdee is offline Find More Posts by cdee
Renton, Wa.
Joined Feb 2006
Wish I could help. I used fiber hinges that I had in the drawer. Most local hobby shops carry them if you have one close. I personally used 3 on the rudder and 3 on each side of the elevator. Don't remember what I did with the wings.
Old Aug 30, 2012, 06:17 PM
Joined Jul 2008
Yeah I thought I got shorted 1, but check the material list and it said 5, so...
Yeah have motor mount coming tomorrow anyway, so have to run to the lhs.
Old Aug 30, 2012, 06:22 PM
Team Twisted!
cdee's Avatar
Joined Jun 2011
I have added a note to the picture in the build sequence... If you all spot any other things like that let me know and I will update the post as necessary. Again, sorry about the confusion that it has already caused some, I should have put the note in a better spot.
cdee
Old Aug 30, 2012, 06:59 PM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I skipped the step for adding hinge material at the counter-balance end of the aileron hinge line. Working ok so far. :-)
Old Aug 31, 2012, 04:28 AM
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Yeh I skipped that step on my Telink Yak well over a year ago and its still going strong. It doesn't have the ca hinges on any of the surfaces.
Aviefly is online now Find More Posts by Aviefly
Sold Telink / Twisted Hobbys Extra Slick SU-29 LPU Monroe, MI bcucoach2 Aircraft - Electric - Airplanes (FS/W) 7 Jul 12, 2012 10:59 AM
Sold NYC LPU: Brand New Built 33" EPP Extra 330 SC livinma1 Aircraft - Electric - Airplanes (FS/W) 9 May 30, 2012 07:19 AM
Sold 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Electric - Airplanes (FS/W) 4 May 16, 2012 08:09 PM
For Sale 3D Hobby Shop 48" Extra 330 EPP FlyWW1 Aircraft - Fuel - Airplanes (FS/W) 4 May 16, 2012 10:45 AM
