Old Aug 16, 2012, 03:05 AM
Blizzard72 is offline
Find More Posts by Blizzard72
Joined Aug 2012
Data
Power Mos Graupner: how to.
Good morning, I've just bought a motorglider, a Reichard Blizzard, and the last owner used it without motor, only in slope.
However I have to use it also in other location, so I need the motor.
The original setup is Graupner Ultra 1600 16v and Graupner Power Mos 75: is there someone who knows them?
I try to find something on the web but without success....
I don't understand if this kind of speed controller is opto like the 60 model and how to configure it....
Yesterday I tried to verify it with a 3s Lipo but the lights on it (red and Green) blink alternatively....and there was no sound from it !!
And nothing's happened....
best regards
Angelo
Blizzard72 is offline Find More Posts by Blizzard72
Old Aug 17, 2012, 12:19 AM
Joined Aug 2012
No one can help me ? I also found a kind of sheet where it's wrote how to set up the 60A model, but it seems it doesn't work....
Angelo
Old Aug 17, 2012, 07:06 PM
Flyting is offline
Find More Posts by Flyting
Joined May 2006
will this help?
Found some links on google.
http://www.cornwallmodelboats.co.uk/...pner_7176.html
http://www.rc-network.de/forum/showt...ra-1600-5-12-V
Try to use a RX battery(4,8v) to power your RX.
And then hook up your Lipo
Opto means no BEC(no power to RX)
remember to take off your prop when you testing your motor!!!!!!
best regards
Rune
Flyting is offline Find More Posts by Flyting
Old Aug 18, 2012, 06:44 AM
Joined Aug 2012
Thank you very much!
The 75 model otherwise has no "opto" written on it, so I don't know if it is opto or not.....
Here' a photo (I know that if the receiver is under a dedicated battery, the connector from speed controller and receiver should be with only two wires, but this has three...)
Description:
Angelo
Old Aug 18, 2012, 12:51 PM
Flyting is offline
Joined May 2006
I dont have this reg,but you can try to hold the red button when you plugg the battery
or you can take out the +(red) from the servo plugg from the reg, and use it as a opto with Rx battery
you can also try to mail Graupner for manual!
Rune
Help with Graupner Power MOS 56 #3283 Stephen M Power Systems 1 Jun 02, 2011 05:09 AM
Discussion 5.5x4.3 Graupner Speed Cam @ 14000 RPM - how much power is that? brtlmj Power Systems 7 May 15, 2008 09:36 PM
Graupner ESC Pico Mos series setup? mjfdassen Power Systems 0 Sep 07, 2004 07:27 AM
Graupner Pico Mos 20 ESC with useless instructions.. Christie Power Systems 0 May 30, 2002 02:25 PM
Esc Graupner Power Moss-how Could I Make It Works Cooler? CESARNOGUEIRA Power Systems 1 Sep 24, 2001 01:15 PM
