This thread is privately moderated by Ribble, who may elect to delete unwanted replies.
Old Aug 16, 2012, 03:02 AM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
V911 Notes 01
V911 Binding
Newer Version V911 Transmitter
Origami 2k-2k-1k Transmitter Rudder Modification - Reduces Rudder Throw
Vibrations
Gradual Rotation
Binding Yellow V911 Helicopter
V911 Stock Batteries
USB Hub Charging Batteries
Transmitters That Bind And Fly V911 Helicopter
V911 Wind-Surfing
V911 Binding
Transmitter off, throttle minimum
Helicopter on
Transmitter on quickly while V911 LED is blinking fast
You may have to turn the transmitter OFF and ON after V911 LED blinks slow again
V911 LED is on solid after good binding.
The original V911 transmitters moved the rudder so much that the helicopter was hard to control. The newer version reduced how much the rudder stick causes the helicopter to rotate and makes flying the V911 much easier. In low rates, the newer version transmitter shows two tabs on the LCD display for full left or full right rudder.
http://www.rcgroups.com/forums/showp...ostcount=11780
Night flying and reduced current draw. Numerous measurements
http://www.rcgroups.com/forums/showt...s#post22546678
V911 TX Mods
http://www.rcgroups.com/forums/showt...a#post22546678
Battery = 7.61v = 6x NiMh LSD 1.2v 2200mah AA cells
76.1ma = Normal LCD off
92.5ma = Normal LCD on
100ma = Normal Beeping
33.1ma = Current into 3.3v voltage regulator Vin = 5.13v ... RF Input power ~ 3.311v x 33.1ma = 110mw (about 20dbm)
13.1ma = 5 Red LEDs Vf = 1.817v
http://www.rcgroups.com/forums/showp...ostcount=10593
The two 2k resistors add exponential at rudder mid-stick, balancing rudder to neutral. The 1k resistor selects how much the stick potentiometer unbalances the two 2k resistors and reduces overall rudder control.
Short the 1k resistor to regain full rudder throw with exponential at mid-stick (works only on old V911 stock transmitters ??)
Vibrations
Replace main blades
Add a tiny washer between main blade and rotor head on one or both sides.
Replace main gear
Swashplate separated
Flybar weight lost (extreme vibrations)
Gradual Rotation
Insert battery into helicopter
Remove battery
Insert battery
Turn transmitter on
For nose-right (clockwise) rotation, push tail boom into main frame. Push tail motor in towards main frame.
1. Insert battery into Yellow
2. Watch for Yellow's LED to blink fast which may take a minute
3. Turn on V911 transmitter quickly, wait for beeping to stop
4. Turn off V911 transmitter
5. Turn on V911 transmitter
If not working, turn V911 transmitter off
Fully charged = 4.20 volts, about 3.70 volts after flight
TC531131 = 120mah 15c 37x12x6mm 3.94g
TC531136 = 130mah 42x12x6mm 4.55g
UC531136 = 130mah 4.4g
TC551136V = 145mah 4.38g
TC551140 = 150mah 25C/50C
TC551140V = 150mah 25C/50C 4.90g 47mm
601235P = 150mah
Swap helicopter battery when you have to run full throttle to keep it in the air. At that point you are at the end of the linear voltage curve and battery voltage will drop quickly.
Flying the V911 when it can not get off the ground will ruin the battery.
Most USB Hubs have a 0.2vdc or more voltage drop. If you suddenly have shorter flying times after inserting a USB Hub in the battery charging circuit, try charging the batteries without the USB Hub. Or buy a USB Hub that uses external power.
Stock V911 transmitter (and V929 quad transmitter)
Turnigy 9x and clones
FS-CT6B - Separate throttle and elevation knobs are great for flying V911 into a stiff wind.
DH9116
Unconfirmed report that Trex 100 is "fully compatible"
FS-T6 reportedly
In my opinion, the best for price, performance, ease of use, is the stock V911 transmitter. But then I only fly V911's in low rates windsurfing outside, Elevator trim full forward to keep the nose down so V911 does not kite (Bye Bye Birdie).
V911 Wind-Surfing
For forward flight with the V911, push the nose down and add throttle. Throttle makes it go faster as well as maintaining altitude.
When playing in the wind, keep the nose down or the V911 will float away in the wind. Control forward speed with throttle. Practice nose-left (counter-clockwise) turns to circle around and dive back into the wind. Nose-right turns are easy but hard to pull out of because the V911 picks up too much speed.
Ribble is offline Find More Posts by Ribble
Discussion 4.01 Governor /600 EFL PRO/ Solved helicocrasher Castle Creations 9 Jul 12, 2012 03:22 PM
Sold Tamiya 1/10 Jeep Wrangler (YJ) CC-01 andTamiya Cayenne S Transsyberia '07 DF-01 Kit mooneypilot Cars - Cars and Parts (FS/W) 0 Mar 28, 2012 04:51 PM
Contest Deleted note...Discare Note.. guyg Aerial Photography 1 Aug 19, 2009 12:33 PM
