This thread is privately moderated by Alex Schauer, who may elect to delete unwanted replies.
Old Sep 09, 2012, 09:53 AM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Awesome! Because I think that my lead-free solder stuff actually comes out a little bit less shiny than the normal 60/40 or 40/60 or whatever stuff... that one's for a 20A ESC that I found, I also have a 25A one, but I think that there's something wrong with it Just need to find a cheap FPV-capable plane to use a 20A on!
DJO is offline Find More Posts by DJO
Old Sep 09, 2012, 10:42 AM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Originally Posted by DJO View Post
Quick question guys -
Does this look like a good solder joint, or is it cold? I can't tell the difference anymore, LOL
Dan
Looks like the positive lead is cold.
On a good joint, the solder "ramps" up to the wire. A bad solder joint is where the solder is in a "ball" and doesnt have a smooth slope on the flat part. Deans are hard to solder!
Alex Schauer is offline Find More Posts by Alex Schauer
Old Sep 09, 2012, 10:43 AM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Hmmm... well I'll see if it is choppy or cuts in and out of power when I put a motor on it.
Old Sep 09, 2012, 11:32 AM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Alright, here's what I'm going to do...
I have:
2 x 11g Servos (Solar A107's)
1 x 20A HK ESC
2 x 1100-1300 mAH 3S Li-Po batteries
1 x Radio 72 mHZ TX/RX (needs battery)
And I just ordered these from NitroPlanes:
Flying wing kit:
http://www.nitroplanes.com/02a-019-p...white-kit.html
and a motor:
http://www.nitroplanes.com/75m14-opt...12-1360kv.html
Going to try a 6x4 prop first on that motor... will see how it does. Probably will have to use a 6x5 or larger, though.
Dan
Old Sep 09, 2012, 12:35 PM
RCSwitz18 is offline
Find More Posts by RCSwitz18
RCSwitz18's Avatar
USA, CA, Livermore
Joined May 2010
Originally Posted by cale10 View Post
just extend the tail boom. works great after that.
First, when I gave too much collective, the tail would give out. So, I extended the tail boom a whole inch and a half.
Now when I give it too much collective, the motor dies and i have to dead stick it in
RCSwitz18 is offline Find More Posts by RCSwitz18
Old Sep 09, 2012, 12:52 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
If you know what you're doing and learn to flip the heli smoothly and slowly hovering inverted is fine, as well as flying around upside-down too this is with the extended tail boom, but completely stock electronics. (skip to around 30 seconds in the video)
Blade mCPX V2 Inverted Insanity (1 min 57 sec)
Dan
Old Sep 09, 2012, 01:09 PM
Jeremy Kamutzki is offline
Find More Posts by Jeremy Kamutzki
Obeying the law of gravity
Jeremy Kamutzki's Avatar
Canada, ON, Cambridge
Joined Jul 2011
Wow! Nice! One question, is the tail boom easy to extend and two: what is tail blowout? It doesnt fly inverted like that on phoenix
Jeremy Kamutzki is offline Find More Posts by Jeremy Kamutzki
Old Sep 09, 2012, 01:11 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Tail blowout is when you flip the heli too fast and the tail can't keep up with the movement, so it blows to one side really quickly... most of the time causing a crash.
Yeah - an extended tail boom you can get plug-n-play from Horizon Hobby for the same price as a regular one very simple, just pop it in!
This is what happens when the motor "bogs out" - see the end of the vid when it crashes... that was at FULL negative pitch, too
If you get one... make sure you have an instant reaction to hit the throttle cut button, it does save it! I did this at the end of the video when it bogged out, no damage!
Blade mCPX 3D With Inverted Crash on Tar! (1 min 3 sec)
Dan
Old Sep 09, 2012, 01:22 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Dan
I would use some heat shrink tubing over the joints. Makes them stronger and insulates from shorting. Leaving them exposed is never a good idea.
I put some on each lead, then a large piece over both of them and the connector's grip.
microflitedude is offline Find More Posts by microflitedude
Old Sep 09, 2012, 01:46 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Yeah I do that too... but I needed to show you guys the solder joints and not the heat shrink! LOL...
Electrical tape works great also.
Dan
Old Sep 09, 2012, 01:52 PM
Joined Jul 2011
http://www.youtube.com/watch?v=VmzKgONKaCM
Dan
ok. so why does the motor bog out? cause that's what looks like is happening to me all the time in Phoenix when I try to fly inverted. it just descends slowly. why does that happen? am I doing something wrong? keep in mind i have no real life collective pitch experience, so I probably am.
Old Sep 09, 2012, 01:54 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Well, first of all you have to be in idle up mode if you're flying on the simulator... otherwise every time it'll just descend and crash.
It bogs out in real life because the motor is brushed and not really crazy powerful enough to fly quick 3D maneuvers.
Dan
Old Sep 09, 2012, 01:58 PM
Joined Jul 2011
Dan
is idle up a setting on my Tx? I use a Dx6i
Old Sep 09, 2012, 02:04 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Yeah there should be a switch on the DX6i somewhere... can't remember where though.
Old Sep 09, 2012, 02:09 PM
Joined Jul 2011
Yup, I figured it out... It's amazing now!!!
Discussion GENERAL CHIT CHAT - advice, videos, cool stuff, new toys, reports, articles, ideas AussieJarred Dynamic Soaring 1092 Apr 24, 2016 07:02 PM
Discussion Official Eflite UMX Mig 15 DF Owners Thread NitroCharged Micro EDF Jets and Power Systems 5608 Jan 10, 2016 02:28 AM
Contest Chit Chat Thread With one Rule: You must reply to poster above you and be relevant! HoaRC Chit Chat 25 Aug 08, 2013 01:48 AM
Discussion General Chit Chat...... Keenan smith RC Airliners (Commercial, Cargo, Troop Carrier) 38 May 28, 2012 05:03 PM
