Old Aug 15, 2012, 05:42 PM
plane58 is offline
Find More Posts by plane58
plane58's Avatar
United States, MI
Joined Aug 2012
Motor mount made too short
I left a thread on the rcuniverse forum about the motor mount. After looking over the new plane the motor was off to the side. Took the cowl, engine mount and motor off and found out the one leg of the mount was about 2.5mm short (must have been the end of the day and they ran short of steel)... I can't fly without a motor mount...thanks
plane58 is offline Find More Posts by plane58
Old Aug 15, 2012, 05:52 PM
plane58 is offline
plane58's Avatar
United States, MI
Joined Aug 2012
motor mount
Almost forgot,The plane is a AeroSky Trainer 1410mm RTF
Item# 07A001
Order# yhst-17210252890263-290438 Nitroplanes
Old Aug 15, 2012, 07:42 PM
arnav is online now
Find More Posts by arnav
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
I suspect it is on purpose to produce the necessary right thrust angle...
arnav is online now Find More Posts by arnav
Old Aug 15, 2012, 09:14 PM
plane58 is offline
plane58's Avatar
United States, MI
Joined Aug 2012
The motor is so far to the right that the prop spinner crushed into the cowl.
If it's left like it is, it would fly in a circle and I would not need a rudder.
Old Aug 15, 2012, 10:04 PM
plane58 is offline
plane58's Avatar
United States, MI
Joined Aug 2012
I'm wrong, you are right about the motor angle , I found a spacer that must have dropped out of it's bag while I unpacked the plane. It now clears the front motor cowl. Thanks for setting me straight.
Old Aug 15, 2012, 10:29 PM
arnav is online now
arnav's Avatar
Joined Nov 2011
Is this the FMS SkyTrainer in disguise? Either way, with the spacer, or without you want to make sure that at the end of the day the motor is at 1 to 2 degrees to the right and 1 to 2 degrees down. In my FMS SkyTrainer you achieved it by connecting the motor mount straight against the firewall and putting the spacer between the mount and the firewall at the right upper corner when looking from the nose (or the pilot's upper left). It is not the end of the world if you don't do any of it, but then you would need to add quite a bit of trim in the air to account for the luck of right and down thrust angle. Good luck...
Discussion Too bad they never made it and sold it dll932 Life, The Universe, and Politics 0 Aug 04, 2012 09:16 PM
Help! Battery life is too short jcalvert Electric Plane Talk 17 Aug 03, 2012 02:45 PM
Discussion Standoffs a little too short ognolman Giant Scale Airplanes 5 Jun 19, 2012 10:46 PM
Question GWS P38 Boom mount screws too short? cincy GWS (Grand Wing Servo) 5 Jan 02, 2007 03:49 PM
