Old Aug 15, 2012, 11:48 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Question
Can I run my KK2 board & ESC's off my Bench Power Supply?
I just hacked an old PC Power supply to run my charger. I got rid of the 3.3v, but kept the 5v & 12v lines. The power supply is an older 230watt ATX that says 18amps on 12v. Not sure the amps on the 5v.
For testing and balancing i thought it might be easier to just wire my electronics to the PC power supply instead of charging and using one of my 3s.
The ESC's will be Turnigy Plush 30A.
AcroFPV is online now Find More Posts by AcroFPV
Old Aug 15, 2012, 01:02 PM
tacitapproval is offline
Find More Posts by tacitapproval
Joined Mar 2012
yes
tacitapproval is offline Find More Posts by tacitapproval
Old Aug 15, 2012, 02:53 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
well you definitely cant go full throttle (or anywhere near that) because the max output is 18A. it would work for very basic setup.
sirbow2 is offline Find More Posts by sirbow2
Old Aug 15, 2012, 03:23 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Thanks. Im kind of bummed cause I have a 430watt PC power supply that shows 12v @ 22amps, but i cant get that thing to power on. Out of 3 "extras" this was the only one that worked.
I do plan on upgrading to a larger power supply later, but I am hoping for now this will do.
Old Aug 15, 2012, 03:28 PM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Have you connected the green wire to ground?
TS00 is offline Find More Posts by TS00
Old Aug 15, 2012, 03:39 PM
sirbow2 is offline
Emress
Joined Nov 2011
just use your :iPos. as long as you charge them properly and dont let them go empty, you'll be fine.
Old Aug 15, 2012, 03:49 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Yup.
Two different grounds to be safe, but it wouldnt kick on... just let out a slight "wheeeze" and spun the fan for a second when switched off.
Old Aug 15, 2012, 03:51 PM
sirbow2 is offline
Emress
Joined Nov 2011
did you have a load on it when you turned it on ( the green and black). some newer PSUs wont turn on unless a load is present.
Old Aug 15, 2012, 03:53 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Yeah, was about to post this ^
A car tail bulb across a 12V line works well.
Old Aug 15, 2012, 04:15 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
I connected a spare HDD to one of the power connectors.
Old Aug 15, 2012, 06:14 PM
sirbow2 is offline
Emress
Joined Nov 2011
so it works?
you could just connect the quad, then power up.
Old Aug 15, 2012, 06:53 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
This sounds like a bad idea, a quad can easily pull hundreds of watts with a quick slip of the throttle. That will overload most PC supplies. They are not designed to be overloaded like say a proper bench top power supply.
Erknie is offline Find More Posts by Erknie
Old Aug 15, 2012, 10:52 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
What about just one ESC & Motor?
Old Aug 15, 2012, 10:55 PM
Erknie is offline
Joined Nov 2011
It depends on the motor, if it's more than a 230watt motor, then you may be in trouble.
Old Aug 16, 2012, 04:01 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Nah, it'll be fine, you'll never pull hundreds of Watts on the bench, there's nowhere for the power to go.
Sold (UPDATED)3 esc's with power board+flight control board and programer ALL SPLIT UP dr rc Aircraft - Electric - Multirotor (FS/W) 2 Jul 07, 2012 09:18 PM
Question Can I run a 12v power supply instead of a battery in my radio for simulator usage? super_nova Radios 11 Apr 27, 2009 06:13 PM
Discussion Can I run two chargers off 12v power supply? bhoges17 Electric Plane Talk 5 Dec 30, 2008 02:16 PM
Can I run Two Chargers off of (1) 12V regulated power supply? mrebman Batteries and Chargers 4 Feb 28, 2005 03:58 PM
