Old Aug 15, 2012, 10:47 AM
Velko Velkov is online now
Find More Posts by Velko Velkov
Velko Velkov's Avatar
Joined Sep 2007
Ornithoid with flexible-adaptive wing
Span - 2 m
Weight - 900 g
Assembling of the wing is before flight.
Velko Velkov is online now Find More Posts by Velko Velkov
Old Aug 15, 2012, 09:18 PM
therealthing691 is online now
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
do you have a video of the action velko
therealthing691 is online now Find More Posts by therealthing691
Old Sep 22, 2012, 04:19 AM
Joined Sep 2007
Video of the action:
ORNITHOID DRIVE MECHANISM (0 min 35 sec)
Old Sep 23, 2012, 02:10 AM
Joined Sep 2007
The frame of the wing
Old Sep 23, 2012, 05:23 AM
australia
Joined Apr 2007
cool
regards Brian
Old Sep 23, 2012, 07:53 AM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Velko.
From the video I can see that you are using Fanning and not FLAPPING movement. How are you doing the wing twist?
KJELL is offline Find More Posts by KJELL
Old Sep 23, 2012, 08:15 AM
Joined Sep 2007
Originally Posted by KJELL View Post
Velko.
Kjell,
I use not Fan-effect, but Wing-effect.
The movements are OSCILATING.
The wing twist thanks to its flexibility.
Old Sep 23, 2012, 08:34 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
What is the difference between Fan-effect and Wing-effect?
Old Sep 23, 2012, 09:02 AM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Regarding the only up/down motion on which this mechanism is capable IMO the wing twist along the span is nonsense.There isn't different flapping speeds along the wing span. Only flexibility needed is along the wing chord and probably will be helpful to implement your adaptive AOA system Velkov.
Good job. Reduce usage of aluminum ,it's heavy
seagull10 is offline Find More Posts by seagull10
Old Sep 23, 2012, 09:14 AM
Joined Sep 2007
Old Sep 23, 2012, 09:21 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
What happen when the wing moves upstroke?
Old Sep 23, 2012, 09:44 AM
Joined Sep 2007
Upstroke movement
Old Sep 23, 2012, 09:56 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The fan effects happen when the wing direction rotates or change the direction.
Old Sep 24, 2012, 01:27 AM
Joined Sep 2007
Velko.
Video - FLEXIBLE - ADAPTIVE ORNITHOID WING
FLEXIBLE - ADAPTIVE ORNITHOID WING (0 min 31 sec)
Old Sep 24, 2012, 02:11 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Thanks for demostration of pasive wing twist. I like to see it working with your machine.
Discussion Ornithoid with passive articulated adaptive wing 2 Velko Velkov Ornithopters 46 Feb 27, 2012 12:56 PM
Discussion Ornithoid with passive articulated adaptive wing Velko Velkov Ornithopters 3 Nov 22, 2011 11:24 AM
Help! Need some AA wings or foam with that flexibility Hopalong X Micro Ready-to-Fly 2 Nov 16, 2007 11:24 AM
FreeAir Streetfighters... wing flexibility? Lynxman Foamies (Kits) 3 Mar 13, 2005 09:06 AM
wing flexibility by design - why not? alligood Thermal 10 Apr 11, 2004 12:15 PM
