Old Aug 15, 2012, 09:49 AM
Wylie Shaw is offline
Find More Posts by Wylie Shaw
Clearlake, CA. USA
Joined Jun 2000
BOLT ON WING MOUNTING (converting from rubber band)
in reference to my future building projects, I want to convert from rubber band to bolt on wings... projects are a Paragon and OLY IIs..... please post drawings, links, pictures of conversions.. Would like simple super strong & light mounting systems to resist strong winch launches... thanks for your help.
Wylie
Wylie Shaw is offline Find More Posts by Wylie Shaw
Old Aug 15, 2012, 01:38 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
One popular system is to make a reinforced hole in the forward bulkhead, and put a mating pin, very securely, in the l.e. of the wing. Then you slightly reinforce the t.e. and put a nylon bolt there. It probably doesn't take much of a bolt, particularly if you are willing to replace it often. Maybe #8 for the Oly and #10 for the Paragon? (Probably more for wings with some sweep or even just straight trailing edges.) However, I suspect you'd have to extend the bulkhead with the aircraft you are talking about. And not so great in a cart wheel.
Graupner used to use two M5 nylon screws for the wings in the Electro Junior, as I recall. (maybe 90 inch span?) That's similar to a #10 in english threads. This was a two piece wing, and the screws were near the joiner rod and only a couple of inches apart. Guaranteed to shear in a bad cart wheel, which might save the fuse. I suspect you might want to go a bit larger, and you'd want to change the screws now and then.
For any nylon screw, if it breaks you can use a heated screwdriver to melt into it so you can back it out.
If memory serves, there is a discussion of how to do a bolt on wing for a Chrysalis over at D J Aerotech.
No need for a super strong wing mount unless you are making the wings much stronger than stock.
lincoln is offline Find More Posts by lincoln
Old Aug 15, 2012, 04:10 PM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Please be care full of nylon screws.I've had two sets fail on me causing some maddening damage.Once on landing, and once on a tap tap winch launch.The screws were 10/24's I finally converted to steel.If I do it again I'll use 1/4 20 nylon.
doc993 is offline Find More Posts by doc993
Old Aug 15, 2012, 07:01 PM
R2R is offline
R2R
Find More Posts by R2R
R2R
R2R's Avatar
United States, FL, St Johns
Joined Nov 2009
I've used this setup: install a 3/8 in ply block in the fuselage butted against the fwd bulkhead and fuse sides under the LE. Install a 1/4 in thick ply block under the TE. Drill and tap both blocks for a 1/4-20 bolt. Reinforce the drill points in the wing with thick ply blocks at the LE and TE. Drill matching holes in the wing. Bolt down with two 1/4-20 nylon bolts for crash forgiveness, steel for bullet-proofness.
R2R is offline Find More Posts by R2R
Old Aug 15, 2012, 07:43 PM
Ray Hayes is offline
Find More Posts by Ray Hayes
United States, IN, Fort Wayne
Joined Apr 2003
What size sailplane ?
Ray Hayes is offline Find More Posts by Ray Hayes
Old Aug 15, 2012, 08:39 PM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
I use two 1/4 wood dowels in leading edge and a single 1/4-20 nylon bolt in TE for my E-Paragon. Also use a nylon flat washer under the bolt head to spread forces and protect film covering. Works like a charm...
Piper J3 is offline Find More Posts by Piper J3
Old Aug 15, 2012, 08:52 PM
lincoln is offline
Joined Dec 2001
How old were the screws, how many times flown, and what kind of glider?
While I've had very good luck with nylon screws, any data on where the limits are is good to have.
My Cumic (100 inch version) had a 1/4-20 nylon bolt on the trailing edge that survived many crashes. IMHO, that's TOO strong.
Old Aug 15, 2012, 09:24 PM
atmosteve is offline
Find More Posts by atmosteve
Joined Nov 2007
Hey there Wylie,
Don't know if this is much good to you, it was a one piece wing and I will assume you won't be doing that with a Paragon or Oly?
Skybench 2m Lil Bird, which had a very similar wing build as the gliders you mentioned but I did it as a one piece, being only 2m. This system took really punishing launches of open F3J competition type pressure (yeah the whole wing was very modified for high launch and zoom pressure, spar carbon etc) and worked nicely with nylon bolts, of course. It was a terrific little thermal sailplane and will be sorely missed.
The pics aren't that great but give an idea, the front bolt mounting plates were laminated ply/epoxy and butted against the mainspar centre join. With a two piece wing your mounting plates could be on opposing wings and slightly offset of centre, the plates and bolts need not interfere with the wing joiner system.
Other ways to skin thy cat though. like a reinforced LE front dowel through a fuse bulkhead/former and a rear nylon bolt fastener as mentioned already.
atmosteve is offline Find More Posts by atmosteve
Reply With Quote  (Disabled)
Old Aug 15, 2012, 09:46 PM
doc993 is offline
doc993's Avatar
Joined Dec 2009
Hi all .It was on my crimson.And they were bought at the hard ware store so age ?Tapping into hard wood or ply works very well, but consider the weight of your plane, and the strength you need to launch.I think !/4 20 should be enough for most planes. The poor landing was clearly my fault, and the damage was not too bad.But the failed launch cost me some down time It was a real learner.My next plane will be lighter.
Old Aug 16, 2012, 02:35 AM
lincoln is offline
Joined Dec 2001
A mounting system I'ce used is one large bolt right next to.the spar. This can go into a tee nut in the same block of wood that th tow hook goes into. It's a good idea to use something high friction on the wing saddle so that a twisty launch won't skew the wing. Flying with a wing twisted 30 degrees is upsetting, though it can be done if you have ailerons and not much dihedral. Advantage is far less stress in cartwheel.landings. Mantis uses 1/4 inch steel bolt. (3 meter span).
Old Aug 16, 2012, 07:18 AM
Clearlake, CA. USA
Joined Jun 2000
Thanks all ...for the info
Steve that is what I'm looking for,,, ways to design or copy from previous builds... Thans mate
Wylie aka The Coyote
Old Aug 16, 2012, 10:53 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Nylon screw tip
Most of us have learned this by example or (me) experience it the hard way.
Tip #1
Do not over tighten nylon screws. Screw them down until in place then just a 1/4 (or less) turn to snug.
Tip#2
Dropping your stored nylon screws in hot water once in while is good for 'em.
Nylon works better with a certain amount of moisture. Guys do this with nylon props all the time. Why not with hardware?
ozmo01 is offline Find More Posts by ozmo01
Old Aug 17, 2012, 03:00 AM
Joined Nov 2007
Ozmo01; Tip#2, never thought of that one!
Does the liquid heat help re-form bent threads for people who were naughty with their screwdriver? Blind nuts are usually metal and it is easy for folks to overtension their screws.
Old Aug 17, 2012, 12:40 PM
lincoln is offline
Joined Dec 2001
If you messed up the threads, replace the screw!
Old Aug 17, 2012, 03:37 PM
ieyasu is offline
Find More Posts by ieyasu
ieyasu's Avatar
USA, CO, Fort Collins
Joined Sep 2010
Here's an old RC Groups post with some bolt sizing advice.
I have included some photos of what I did for my Paragon. It's got a 10-24 forward of the trailing edge and a 1/4-20 in front of the spar. I used hard balsa gussets to reinforce things. I'm not sure it's as strong as it would need to be to winch, but I didn't build a winchable spar, either. The plane hasn't had a hard landing yet, but it's doing okay so far... If I had it to do again, I would've put a 10-24 behind the leading edge instead of going over the spar--I *want* the screws to break, not the wing or fuse. The wing on my Paragon is too thick at the spar for a #10 screw to reach down to the thread block in the fuse though, so I had to go with the 1/4" size.
I'll note also that my DJ Aerotech 2m Chrysalis uses 2x #8 nylon screws as per the design, located near L.E. and T.E. That thing has had hard landings, and never broke a screw.
ieyasu is offline Find More Posts by ieyasu
Question Rubber band to bolt on wing purcilas Fuel Plane Talk 19 Jun 27, 2011 10:11 PM
Question Rubber band to bolt on wing conversion. 2m EP sailplane spook123_uk Sailplane Talk 5 Jun 25, 2011 09:30 AM
Discussion Rubber band wing to bolt on spots25 Fuel Plane Talk 9 Nov 18, 2009 10:34 PM
Help! Converting rubber banded to bolt on wing Oian Thermal 8 Aug 03, 2008 06:19 PM
Discussion Converting wings to bolt-on from rubber-banded? Senior Telemaster Greg McNair Glow to Electric Conversions 4 Jan 22, 2006 11:12 PM
