Old Aug 15, 2012, 08:48 AM
mikegbogh is offline
Find More Posts by mikegbogh
Upwardly Mobile
mikegbogh's Avatar
Roodepoort, South Africa
Joined Aug 2007
Build Log
Free Style scratch build sailplane
Hi There,
So Summers on its way and time to build another glider, this one is scratch built out my head ,improvising as I go, it is going to be used primarily on new slopes, and with the electric motor will also allow launching off a flat field.
I have designed it so the wings come apart as well as easy attachment of the wings and tailplane using a cutting edge technology"rubber bands"
A few weeks back I started cutting ribs and now 3 weeks later have a much better idea of the final outcome, guestimate around 2kgs and a huge wide wing 3.2 mtrs in length should make it a stable flyer and good camera platform.
Anyway a couple of pics of the build, also toying with a name for this beast .
cheers
mikegbogh is offline Find More Posts by mikegbogh
Old Aug 15, 2012, 09:21 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Hi All,
A few weeks ago I started so here are some more pics of work already done.
regards
Old Aug 15, 2012, 09:24 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
looking nice
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Aug 15, 2012, 09:59 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Hi All,
I had started this build thread on my blog but moved it here as it makes sense here, so a couple more pics to try get up to date .
cheers
Old Aug 15, 2012, 10:39 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
And yet more pics , this project was started about two weeks ago.
Old Aug 16, 2012, 02:59 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Hi There,
Some more pics attached.Hopefully get to painting on the weekend,
regards
Old Aug 16, 2012, 03:05 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
NIce T tails rulez
EZ
Old Aug 16, 2012, 11:44 AM
Titus ZA is offline
Find More Posts by Titus ZA
Hunting for Goat Lifters
Titus ZA's Avatar
South Africa, GP, Randburg
Joined Jul 2012
great work Mike! I'm really loving this build. I cant wait to see it take to the air.
cheers
T
Titus ZA is offline Find More Posts by Titus ZA
Old Aug 17, 2012, 08:34 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Finishing
Hi There,
I have water papered down the primer and time to shoot the first base coat of white 2k, any pinholes that appear, will get a touch up of paint from a small brush.
The next step will be cutting the nose cowl off and making it match the spinner, once the motor is in place.
regards
Old Aug 17, 2012, 02:26 PM
mhodgson is offline
Find More Posts by mhodgson
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
If I may ask, what are the motor spec, pro and battery you are planning to use?
mhodgson is offline Find More Posts by mhodgson
Old Aug 20, 2012, 05:38 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
The motor is a E-MAX GT 2820 850KV 11/12 INCH PROP and the box claims 2300gr thrust if it can produce about 570watts which I read as a spec elsewhere then it should do the job nicely, if not I have a slightly bigger motor I can fit.
regards
Old Aug 20, 2012, 05:54 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Some more progress
Hi There,
So some more work on the motor cowl, wingtips and hatch.
Once I get the motor , spinner and cowl to all line up nicely then I can start to plan some final paint finishing.
Looks like I need to move the motor up a few millimetres but that is no big deal.
I also fiited some ply surpports for the aileron servo's.
regards
Old Aug 20, 2012, 05:57 AM
Titus ZA is offline
Titus ZA's Avatar
Joined Jul 2012
Great work Mike. Now it's just the smaller details that tend to take up the most time.
Cheers
T
Old Aug 22, 2012, 06:51 AM
Upwardly Mobile
mikegbogh's Avatar
Joined Aug 2007
Finishing
Hi There,
Started with the covering and final coats of paint, still undecided about final scheme.
This morning I put the pieces together and added a 5oo gram weight to the nose, it balanced so the estimated all up weight will be a tad over 2kgs
and it will balance with the motor , esc, batteries and servos and probably not need any nose weight at all.
Some pics attached.
Old Aug 22, 2012, 06:57 AM
Titus ZA is offline
Titus ZA's Avatar
Joined Jul 2012
Looks fantastic Mike. And it certainly does look neat. Also glad to see that it will need little to no extra weight to balance it.
Keep up the brilliant work.
Cheers
T
Discussion My Scratch Built FPV Simitar Build - Bill Evans Style TexasClouds FPV Talk 3 Jul 18, 2012 02:06 PM
Build Log scratch build, ww1 style Charlie ricker Blimps 53 Jun 27, 2012 12:11 AM
Sold Like New not a scratch Futaba 10 c cartridge style bhood Aircraft - General - Radio Equipment (FS/W) 3 Apr 14, 2012 07:50 PM
free detailed warbird diagrams for scratch building GIEric Scale Kit/Scratch Built 11 Jun 27, 2005 01:16 PM
