Old Jan 27, 2013, 07:49 PM
ukionz is offline
Find More Posts by ukionz
Malaysia, Sarawak, Kuching
Joined Jun 2011
wonder why they cover up the distance & attitude?
ukionz is offline Find More Posts by ukionz
Old Jan 29, 2013, 08:45 AM
Jantjezandje is offline
Find More Posts by Jantjezandje
The Netherlands, NH, Zandvoort
Joined Mar 2011
I think its not allowed to fly that high. Commercial planes don't like foamy's in their engines.
He is looking around several times.
Jantjezandje is offline Find More Posts by Jantjezandje
Old Jan 30, 2013, 04:25 AM
RocketMouse is offline
Find More Posts by RocketMouse
mucho FPV
RocketMouse's Avatar
Joined May 2011
NO RSSI?
ARE YOU KIDDING?
That's really an epic fail!
RocketMouse is offline Find More Posts by RocketMouse
Old Jan 30, 2013, 04:34 AM
Dogdude is online now
Find More Posts by Dogdude
Joined Aug 2012
Originally Posted by RocketMouse View Post
NO RSSI?
ARE YOU KIDDING?
Really ?
Where's the need for RSSI if you have RTH ?....
With RSSI:
RSSI get's low you manually turn around to fly home or adjust your TX position
With RTH and no RSSI
Signal strength gets weak, autopilot turns the plane around to fly home or you see it's gone to RTH and adjust your TX position
In most cases with my basic OSD/RTH (Nova OSD) if the plane loses signal it kicks into RTH, plane banks and picks up signal and I continue to fly, it all happens in a brief second or two
Dogdude is online now Find More Posts by Dogdude
Old Jan 30, 2013, 11:17 AM
mucho FPV
Joined May 2011
Then why do you need OSD at all?
You can use timer to know the battery discharge. You don't need altitude, because you can see it. You don't need arrow home, cos you can use a flare gun. You actually even don't need RTH, just fly around yourself.
I have conditions, when RTH is not acceptable. Flying low, or between the trees. Or whatever... Not everybody fly your style.
Old Feb 01, 2013, 05:00 AM
ZaksterBlue is offline
Find More Posts by ZaksterBlue
Australia, ACT, Gungahlin
Joined Dec 2012
Hi, has anyone tested the fence mode? I'm wondering whether this makes the plane fairly 'safe' to hand to a beginner?
ZaksterBlue is offline Find More Posts by ZaksterBlue
Old Feb 01, 2013, 08:26 AM
Joined Aug 2012
Numerous reasons
Last known position in case of a crash
Pure interest (it is a hobby after all isn't it)
Staying level in the clouds (built in gyros and/or artificial horizon)
Home pointer, I get lost easily up there
Battery condition/useage information
Oh and of course built in RTH in case I lose radio signal strength
Bottom line is that I preer to fly my planes myself ratehr than have an autopilot run missions for me but I also wnat the built in safety features of a reliable RTH system and the information it can provide via OSD
No you cannot, not accurately and on longer flights not even close
Now someone is just being silly aren't they
If you really really MUST have RSSI then go and buy a system that has that
Seems to me that someone who prefers to fly tight amongst the trees and therefore doesn't need RTH or autopliot due to the obvious hazards is probably just in a thread about an autopilot system with rth to complain just for the sake of complaining
Old Feb 03, 2013, 08:37 PM
ukionz is offline
Joined Jun 2011
Someone in China using this on Heli!
http://bbs.5imx.com/bbs/forum.php?mo...CC%B6%A8%D2%ED
It is Simplifies Chinese site, sorry. with pictures. Maybe Google translate will help.....Just add more complications to this thread
But I will only use this on a fixed wing.
Old Feb 04, 2013, 01:49 AM
ukionz is offline
Joined Jun 2011
I was so boring waiting the postman to send my Arkbird. Searching the web for more info......not much on this thing, so go to Chinese site to learn more.
Ok, found this, the Arkbird designer share his thought on design & finetune of this system. Again it is Simplified Chinese site (Google translate is your friend)
http://bbs.mx3g.com/forum.php?mod=vi...uthorid=224318
I wouldn't go off topic, if linking Chinese site here is bad, let me know.....I will stop doing this.
Old Feb 07, 2013, 08:11 AM
ukionz is offline
Joined Jun 2011
Is it ok to put the gps antenna inside an epo plane?
Old Feb 07, 2013, 08:58 AM
Joined Aug 2012
It should work fine, it's radio waves remember so don't allow it to be blocked by metal, try to make sure there are no wires above it etc
I have one of mine inside the fuselage and it has no trouble at all (not an Arkbird mind you)
Old Feb 08, 2013, 07:59 AM
su_chinhui is offline
Find More Posts by su_chinhui
Joined Mar 2008
I have owned this product for several weeks, it's much easier to setup than eagletree. I put the gps antenna inside my epo plane, and it works very well. Here's my videos:
Gopro Hero3:
River, Mountain Surfing (9 min 25 sec)
On board camera with OSD information:
River, Mountain Surfing, On board camera with ArkbirdOSD. (0 min 0 sec)
su_chinhui is offline Find More Posts by su_chinhui
Old Feb 08, 2013, 09:04 AM
ukionz is offline
Joined Jun 2011
Thanks for the replies. Mine still on test bench, video flickering when I plug in the fat shark camera. I hava try both pal and NTSC on arkbird with no luck. My set up are Fpv raptor with Turnigy plush 40a esc, orangerx 6 channel full failsave receiver (going to use orangerx lrs soon when I upgrade the firmware) for my ground station I have 7"LCD,immersionRc UNO video receiver, VCR comming soon. And fat shark predator rtf with camera. Going to try other camera that is 12v......any ideas welcome. Thanks
Old Feb 08, 2013, 11:33 AM
Hmerly is online now
Find More Posts by Hmerly
Hmerly's Avatar
United States, AL, Huntsville
Joined May 2012
This thing has no ppm and no rssi?
Hmerly is online now Find More Posts by Hmerly
Old Feb 08, 2013, 12:33 PM
Blom is offline
Find More Posts by Blom
Tri-Quad and EDF flyer
Blom's Avatar
SWEDEN
Joined Oct 2010
Thats correct
Blom is offline Find More Posts by Blom
Sold New Nova Cyclops OSD/Autopilot Nobert Aircraft - General - Radio Equipment (FS/W) 0 Aug 14, 2012 07:29 PM
For Sale cyclops OSD F16 v5.0 system autopilot for planes UK SALE hexa Aircraft - General - Miscellaneous (FS/W) 0 Jul 10, 2012 08:41 PM
Sold FY-31 autopilot with Hornet OSD willi_m FPV Equipment (FS/W) 2 Jun 26, 2012 12:31 AM
Sold Dragon OSD+ V2 GPS (RTH, Autopilot, Waypoints) NEW crd FPV Equipment (FS/W) 1 Mar 16, 2012 09:17 AM
Sold Dragon OSD+ V2 GPS (RTH, Autopilot, Waypoints) NEW crd FPV Equipment (FS/W) 0 Mar 11, 2012 09:55 AM
