Old Nov 21, 2003, 11:42 AM
planeman is offline
Find More Posts by planeman
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
Photo Etching - a "How To" for PCB boards and making small metal parts.
In a couple of the recent threads about making your own IR receivers, IR transmitters, micro receivers, muscle wire actuators, etc., the subject of do-it-yourself photoetching has come up. This thread is to pull together all of the piecemeal photoetching discussions into one coherent thread and add more information and discussion in an area that has been overlooked until now.
I will direct some of the gurus over here.
Have at it, guys!
Planeman
planeman is offline Find More Posts by planeman
Old Nov 21, 2003, 11:55 AM
Marten is offline
Find More Posts by Marten
..teach monkeys to fly..
Marten's Avatar
Ottawa Intl, Canada
Joined Oct 2000
Excellent article on Stefan Vorkoetter's page. I've used it several times.
http://www.capable.ca/rcstuff/etching.htm
Marten is offline Find More Posts by Marten
Old Nov 21, 2003, 12:26 PM
planeman is offline
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
Thanks, Marten.
I read it and it is very good. What I have noticed is there seem to be quite a number of methods and tricks. Some photoetch using expensive setups and some seem to get excellent results with inexpensive and almost "household" chemicals and items. I hope we can learn what these are and learn from each other some neat tricks for a cheaper and quicker way of getting the job done.
Keep posting, folks!
Planeman
Old Nov 21, 2003, 12:42 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Planeman, good idea about the thread but a bit overkill to post about it in all those threads. If you want to bring attention to a particular thread, post a suggestion in the "Micro Thread Index"
Brgds
Michael
epilot is offline Find More Posts by epilot
Old Nov 21, 2003, 12:57 PM
planeman is offline
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
Sorry for the overkill. Just trying to get you, Bulent, J. Berg, et al over here.
Planeman
Old Nov 21, 2003, 01:21 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Thanks for making the thread.
I'm glad someone else did it besides me I have been starting too many threads lately and was waiting for this one.
Well anyways what are the advantages of photoetching over
say just ironing the pattern from a laserjet printout or plotting with a permanent marker? It seems much simpler to do the latter.
I have no experience with this stuff and have only read info here and a little more so please excuse my ignoramusness.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Nov 21, 2003, 01:29 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I would suggest that the thread should be etching in general, the method in which the pattern is made doesn't matter and it would be nice is all methods were here.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Nov 21, 2003, 02:10 PM
Joined Nov 2002
I second the suggestion Graham.
Now to get down to business what can be use as a resist for caustic soda if I were to want to etch some aluminium with it?
I have looked for this but came back empty.
Billy
Old Nov 21, 2003, 03:01 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
http://w1.859.telia.com/~u85920178/data/pcb2.htm
http://w1.859.telia.com/~u85920178/data/pcb.htm
DNA is offline Find More Posts by DNA
Old Nov 21, 2003, 07:12 PM
Sticky Shepherd
Oxford/England
Joined May 2001
Most paints will probably resist caustic soda. I don't think that photo resist will though as it is one of the components of some developers.
Graham
Old Nov 22, 2003, 11:01 PM
Bob Bailey is offline
Find More Posts by Bob Bailey
SpinsMakeTheWorldGoRound
Groveland, Florida
Joined Oct 2003
etching aluminum
Billy, I like muriatic acid for etching aluminum,found at pool suply stores. Most resists seem to work with it. I took the aluminum case off of a 45ma battery with it, reduced the weight to 1.1g, but it inflated the battery and burnt the anode through. So it was a total waste of time, so far. Bob
Bob Bailey is offline Find More Posts by Bob Bailey
Old Nov 22, 2003, 11:59 PM
Joined Nov 2002
Bob
I thought the outer layer of the lipoly was some sort of plastic.
If so will the battery work with just the aluminum casing?
Could possibly wrap it back up with something lighter weight.
I only have one at present so I will not mess with it.
Sorry for off topic but I have been wondering about the insides of the lipoly and wondering how dificult it would be to make one if you had the parts you could make your own custom sizes and stuff. Thanks for the tips on aluminum etching Graham and Bob.
Billy
Old Nov 23, 2003, 02:45 PM
epilot is offline
Joined Nov 2000
I have tried to make some brass parts by first spraying them with positive photo resist and then exposing them for 15 minutes with a 300W halogen spot. Did not work. All the resist came off in the developer. I will try a longer exposure time and see if that works. I would like a proper UV exposure box but they are very expensive. However the tubes used therein are quite reasonable. Does anyone know what is needed to hook up these UV tubes to mains?
Michael
Old Nov 23, 2003, 04:02 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I used to use a sunlamp. They used to sell them at Kmart, WalMart, etc, for women to get that 'winter skin burn', or 'fake bake'. You might be able to still get them. Or, rent some time in a suntan booth
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 23, 2003, 04:20 PM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Michael,
I believe a std fluorescent ballast and 15watt eraser or germicidal bulb can be used.
Dave
david_dewit is offline Find More Posts by david_dewit
Inkjet masks for PCB- small breakthrough crossup DIY Electronics 10 Dec 05, 2004 09:51 PM
Question Making small parts like control horns out of carbon fiber? DlgHucker Composites Fabrication 6 Jul 12, 2004 12:53 PM
CA vs epoxy for small layup parts A Monell The Builders Workshop 2 Apr 06, 2004 09:20 PM
What is the cheapest laser cutter in the world,suitable for making RC model parts? bipeflyer The Builders Workshop 7 Dec 03, 2002 01:45 PM
metal parts for elmh potifar Electric Heli Talk 6 Oct 02, 2001 09:08 AM
