Espritmodel.com Heli Air
Old Aug 28, 2012, 09:46 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Hey guys,
The HET 240-15-4800 (4800kv) for 3s-4s are now instock.
http://www.effluxrc.com/HET-240-15-4...40-15-4800.htm
My Screamer also showed up today. It has a nice big battery compartment.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Aug 28, 2012, 09:55 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by www.hobbyb.com View Post
Screamer and Katana are back in stock.
www.hobbyb.com
Great news. So many Jets and not so much time.
Yep. A light fan / motor and the lipo moves to the very rear for the proper CG. The heavier the fan /motor combo, the larger the lipo needed and this model will definately take a good sized lipo. This will handle one serious weight fan and motor combo as the wing loading is so low.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 28, 2012, 10:07 PM
Joined Feb 2009
Yes, I agree with all of that, but do learn from my experience. With the HK 4S alloy housing fan unit, a Sky Lipo 1300mah 4S battery moved as far back as it will go still required 1 oz of lead on the back. So I recommend getting a slightly smaller battery than mine.
However, It still flys great with all that weight! Still slows down fine and has great handling. I'm really glad I got this.
Tom77 is offline Find More Posts by Tom77
Old Aug 28, 2012, 10:32 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Thanks for the tip Tom.
I'm not aware of the weight of the HK setup, but If need be, I'll move the fan aft. The stock fan can move back about 1/2". Any more than that will require some foam removal. That should help a bit.
The battery can probably be moved further aft as well, with some foam removal.
Site Sponsor
Old Aug 29, 2012, 08:29 AM
Joe 1320's Avatar
Joined Feb 2006
yeah, 4s 1300 is a bit much unless you use a really heavy fan combo.
I have a hoffman / hyperflow combo that is pretty heavy and at 540 Watts would need a decent lipo for the 50+ amps required. I'm not sure I would want to go that route, it's already plenty quick on a light weight combo. I may use that for the Katana. 540 Watts would move it along nicely.
Old Sep 10, 2012, 08:34 AM
Joe 1320's Avatar
Joined Feb 2006
For those wanting even more power in the screamer, here's the solution.....
http://www.rcgroups.com/forums/showthread.php?t=1720667
Old Sep 10, 2012, 08:59 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
So after seeing the screamer fly 2 weekends in a row....I need one!! And I need a Katana as well!! The Screamer is a fast little jet!!!
gooniac33 is offline Find More Posts by gooniac33
Old Sep 10, 2012, 09:01 AM
Joe 1320's Avatar
Joined Feb 2006
I kept telling everyone that it's the fastest of the lot, I guess seeing is believing!
Old Sep 10, 2012, 09:10 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Seeing is believing and your video was the first bit of me seeing it! This little thing flies like an EDF Stryker!! Great little plane with a wide flight envelope! Must have....
Old Sep 10, 2012, 10:32 AM
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Finally stumbled onto this thread. Looks pretty impressive Joe. Makes me wish I didn't have so many irons in the fire already. I will be starting my trip back south at the end of the month. Should be there by the end of Oct.
John
pmpjohn is offline Find More Posts by pmpjohn
Old Sep 10, 2012, 10:36 AM
Joe 1320's Avatar
Joined Feb 2006
John
Cool. Can't wait to get some of the "other" projects in the air.
Wait to you see this in person, it rips pretty good.
Old Oct 09, 2012, 04:56 PM
United States, OH, Cleveland
Joined Sep 2012
Joe,
I have a spectrum receiver AR400,It has 2 antenna
Where and how to fix this on skeleton?
Pls send few snaps if you have.
Ravi
RaviM is offline Find More Posts by RaviM
Old Oct 11, 2012, 07:00 AM
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by RaviM View Post
Joe,
Ravi
I'll have to take some pics, but there is plenty of space available behind the battery in the fuselage for the AR400. You could probably put 4 receivers of that size in there.
Old Oct 23, 2012, 08:08 PM
gilford, new hampshire, usa
Joined Nov 2003
I bought the kit. Using AEO ADF50-300L 5800KV and Detrum 30A ESC and an older Hextronic 860 mAh 15-20C battery. Decorated with self stick holographic paper. Maiden this evening and she flies real sweet! Very happy with it.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Oct 23, 2012, 09:11 PM
Joe 1320's Avatar
Joined Feb 2006
Congrats! I'll bet it sounds sweet.
Something tells me your lipo is not going to keep up with that motor and fan. My AEO fan with the 5800 kV motor draws 31A peak, that's going to kill that of lipo of yours pretty quick. I suggest a 3s 1000 mAh 40C. It will balance OK if the lipo is shoved all the way to the rear of the battery tray and the back angled upward. I flew my maiden flight with that lipo and all was well.
New Product Skyangel NEW PRODUCT Screamer 50mm EDF Sport Jet www.hobbyb.com Australia 27 Jan 21, 2013 06:48 AM
Help! 50mm MIG-15 (skyangel/ FMS?) EDF wont work Remy130 Foamies (Kits) 4 Jul 03, 2012 11:31 PM
Sold Skyangel/J power F-8/A-7 Crusader 50mm Fan Jcopter Aircraft - Electric - Jets (FS/W) 2 Apr 13, 2012 01:26 AM
Rant J Perkins Distrib - Why no 50mm J Power/Skyangel in UK????? Jacques.Eloff Foamy EDFs 10 May 16, 2011 04:29 AM
Discussion J-Power/Skyangel/X-FLIGHT 50mm edf failures gdimonte Foamy EDFs 7 Dec 28, 2010 09:49 PM
