Old Aug 22, 2012, 06:36 PM
rabdooley is offline
Find More Posts by rabdooley
rabdooley's Avatar
USA, NH, Center Ossipee
Joined Apr 2010
Could you give me the distance from the firewall to the hinge line at the rudder? I will add 125mm to this measurement. This is the first measurement needed to start the float plans. (prop to hinge line)
Thanks.
P.s. I will be ordering the plane this paycheck !!!! Physched......
rabdooley is offline Find More Posts by rabdooley
Old Aug 22, 2012, 07:49 PM
bicyclemonkey is offline
Find More Posts by bicyclemonkey
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
Thanks.
945mm, from rudder hinge line to the firewall.
bicyclemonkey is offline Find More Posts by bicyclemonkey
Old Aug 22, 2012, 07:52 PM
Fayetteville, AR
Joined Jan 2010
I got the inside and outside of the firewall fuel proofed. It had some sort of gray primer on it but it was very dry.
Old Aug 22, 2012, 08:17 PM
Fayetteville, AR
Joined Jan 2010
Tru Turn spinner. Got the engine mounted.
rabdooley's Avatar
Joined Apr 2010
Thanks for the measurement.
Old Aug 23, 2012, 08:00 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Just curious, do the instructions give control surface travel recommendations? The shorter horn you chose would reduce the amount of movement of the ailerons.
scootrb4 is offline Find More Posts by scootrb4
Old Aug 23, 2012, 08:26 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Closer to the hinge (short control horn) gives more throw. At the servo, closer to the shaft gives less throw.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Aug 23, 2012, 08:33 AM
Fayetteville, AR
Joined Jan 2010
Aileron travel is +/- 40mm per the manual. I'm serious, the included aileron control horn was absolutely ridiculous. The shorter versions they included for the elevator and rudder are usable I just chose not to use them so I could keep all the horns the same, I'm just OCD (anal, if you will) about that.
*edit*
I had spoken with a guy from Troy Built (where I purchased the ARF) and discussed the aileron control horns with him. I sent him photos so we'd be on the same page. He emailed me this update to my photo I sent him with his recommendations. They were to enlarge the slot in the aileron to accommodate the size of the horn and to drill a hole for the push rod that was in-line with the hinge line.
One has to remember just because it's the hardware that was included with the kit doesn't mean it's the correct hardware. This is not only a Chinese manufactured ARF, it's a Chinese company. It's not like Sig where the ARFs were designed in America and tested and then manufactured by China. So one should probably not use any of the included hardware anyway.
Old Aug 23, 2012, 09:52 PM
Fayetteville, AR
Joined Jan 2010
Any suggestions?
Old Aug 23, 2012, 11:06 PM
edwin1 is offline
Joined Sep 2003
Two sided steering tiller connected by springs to the rudder control horn. Or aftermarket tail gear.
Edwin
Old Aug 23, 2012, 11:51 PM
Crowfly is online now
Find More Posts by Crowfly
Crowfly's Avatar
United States, MO, Belton
This works very well.
http://www.advantagehobby.com/24624/SUL860/?cat=690
But then looking back on page one,it looks like you would have to remove the fin from the fuse to make it work. Iduno. That fin doesn't look like a good place to mount a tail wheel in the first place. But I can't tell if the tail wheel I have a link to would even work because the rudder might drag the ground
I would use my dremel and make my wheel fit, even if I had to cut off the bottom of the rudder,and get out the white ultracoat. But it isn't my airplane
Fred
Crowfly is online now Find More Posts by Crowfly
Old Aug 24, 2012, 07:10 AM
edwin1 is offline
Joined Sep 2003
Looking at it some more, you could probably make a new tail gear without the coil. For a plane that size, it would work just as well. You really have a lot of options available, not a disaster.
Edwin
Old Aug 24, 2012, 08:35 AM
Fayetteville, AR
Joined Jan 2010
Done, last night I bent a new tail wheel out that's the same just without the coil.
The next problem I ran into was that the plastic tab on the tail wheel there is way larger than the wire so I had to dremel the rudder and the rear of the fuselage so the rudder would stay aligned.
There were only two pre-cut CA hinge slots on the vertical the other that was shown in the manual was not cut and there was hard wood there. I just used some small Robart point hinges.
Old Aug 25, 2012, 02:46 PM
Fayetteville, AR
Joined Jan 2010
By far the worst part of the build so far was the tail wheel. This part would have sucked even if the factory tail wheel hadn't broke.
I should've used a bracket that screws to the bottom of the fuselage instead of trying to make the factory method work. Like this one on my Tiger Moth:
This way seems like there's more slop in the tail wheel gear with the factory setup.
And because of this, I couldn't get the hinge line any closer together than this:
Old Aug 25, 2012, 05:00 PM
rabdooley's Avatar
Joined Apr 2010
I ordered my "Miss Elaine".
Sorry to read about your tail wheel problems. My build should go a bit easier, since I will be making mine a seaplane and won't need a tail wheel.
While trying to design floats for this bird, I referenced the manual online. Page 58 has the CG location and is some what confusing. It shows both an 87mm and a 150mm cg. Is the 150mm measurement a lateral measurement?
Any thoughts on this?
Also, if you know the correct cg location, could you give me the measurement from it to the firewall. This will help me in designing the floats.
Thanks again!
http://www.troybuiltmodels.com/ns/ma...SELA-73AAF.pdf
New Product New ECOMRC Pilatus PC-21 from TBM scatsob Scale ARF/RTF 474 May 15, 2016 03:28 AM
Sold ECOMRC Wilga hmarshall Aircraft - Fuel - Airplanes (FS/W) 8 Aug 12, 2012 05:53 AM
Help! Ecomrc fokker dv11 ? BRUTUS2238 Fuel Warbirds 0 Aug 01, 2012 07:40 AM
Discussion ecomrc from troybuilt for tug duty? balsabozo Scale Sailplanes 1 Feb 06, 2012 05:20 PM
Discussion Elaine died March 3 RD Blakeslee Life, The Universe, and Politics 27 Oct 07, 2010 06:22 AM
