Old Aug 13, 2012, 11:25 PM
bicyclemonkey is offline
Find More Posts by bicyclemonkey
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
ECOMRC Miss Elaine
I just got this in today and there's pretty much nothing online about it so this is probably the first discussion/viewing lol. It comes equipped for glow or electric power so there is a battery/fuel tank hatch. It calls for a .52 thru .70 4c glow so I have an ASP .65 four stroke I plan on using. this will be my first glow plane btw. I'll get some more photos up tomorrow of the contents as I unbox it.
http://www.troybuiltmodels.com/items...ELA-73AAF.html. Not a bad deal, $159 for a 73" plane.
[IMG][/IMG]
bicyclemonkey is offline Find More Posts by bicyclemonkey
Old Aug 14, 2012, 09:11 AM
Gray Beard is offline
Find More Posts by Gray Beard
Joined May 2012
I like it, it's an Old Timer Free Flight design that was modded for RC. Go to Wattflyer.com if you want to learn anything about it in electric, it's a good web site and all they speak is electric.
I just got myself a set of plans for an old timer that has that rakish stance but that is typical of the old school free flights. I will be going from free flight to three channels but they lend themselves well to that too.
Good looking little plane.
Gray Beard is offline Find More Posts by Gray Beard
Old Aug 14, 2012, 09:13 PM
Fayetteville, AR
Joined Jan 2010
I've been all electric since I started in RC a few years ago. This will be my first glow plane, a 4c at that.
Old Aug 15, 2012, 08:52 PM
Fayetteville, AR
Joined Jan 2010
It was packed very well with no damage.
Old Aug 16, 2012, 06:07 PM
rabdooley is offline
Find More Posts by rabdooley
rabdooley's Avatar
USA, NH, Center Ossipee
Joined Apr 2010
I am thinking of ordering one also.
Can you post more pictures of this model?
rabdooley is offline Find More Posts by rabdooley
Old Aug 16, 2012, 07:46 PM
Fayetteville, AR
Joined Jan 2010
Sure. Nicely packed.
I'm diggin' the retro looking cream covering over what I thought was going to be white.
The covering over the whole model was stretched tight with not a wrinkle in sight.
Old Aug 17, 2012, 11:30 AM
Fayetteville, AR
Joined Jan 2010
What do you guys make of this? This is the control horn provided for the aileron is ginormous! It doesn't line up with the hinge line and is way tall to the point of the push rod being at a high angle.
It's also too wide to fit in the slot.
Here's the step in the manual.
Old Aug 17, 2012, 11:54 AM
Joined May 2012
Nothing strange about it at all, keep in mind it is just an ARF made in China and minor errors like that are just common problems. Things like this are not only found in the lower end ARFs but even in some of the high dollar products too.
Just use a sander or grinder to get it sized correctly, make it a nice tight fit too. If this is your only problem you find count yourself lucky.
I just helped a friend assemble a new little ARF and it was the first one I recall being perfect without any errors. I think it is an Eflight Taylor Craft, it's small but at $150.00 it's not cheap. I was looking for a problem with it but it went together without even a little problem, well, locating the wire push rods was a thrill, we thought they left them out of the box but we finally located them taped on the side of the box. Only found them by accident!!
Old Aug 17, 2012, 12:06 PM
Fayetteville, AR
Joined Jan 2010
I was thinking of doing this instead to prevent the push rod from being at too high an angle but it had been mentioned to me that the included horn may be designed for differential and to go ahead and use it.
Old Aug 19, 2012, 07:09 PM
Fayetteville, AR
Joined Jan 2010
Here ya go. Sorry for the wait.
Old Aug 19, 2012, 08:50 PM
rabdooley's Avatar
Joined Apr 2010
Thanks!
I am considering making this a float plane.
Old Aug 19, 2012, 08:55 PM
Fayetteville, AR
Joined Jan 2010
Thanks!
That would be awesome! I need a pond to fly from.
Old Aug 21, 2012, 09:34 AM
Fayetteville, AR
Joined Jan 2010
Control horns attached. I decided not to use the ones that came in the box. I plugged the factory cut slot, drilled the new holes + hardened with thin CA, then put a dab of thick CA on the screws.
Old Aug 22, 2012, 07:02 AM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
You did what I would have done. I have certain ways that work for me and I pretty much stick with them no matter what the barf says in the instructions.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Aug 22, 2012, 08:28 AM
Fayetteville, AR
Joined Jan 2010
Yeah those aileron horns were like three inches tall. First time setting up a glow engine, getting those holes drilled was pretty tedious.
It's right on the money. 125mm from prop backplate to firewall.
New Product New ECOMRC Pilatus PC-21 from TBM scatsob Scale ARF/RTF 474 May 15, 2016 03:28 AM
Sold ECOMRC Wilga hmarshall Aircraft - Fuel - Airplanes (FS/W) 8 Aug 12, 2012 05:53 AM
Help! Ecomrc fokker dv11 ? BRUTUS2238 Fuel Warbirds 0 Aug 01, 2012 07:40 AM
Discussion ecomrc from troybuilt for tug duty? balsabozo Scale Sailplanes 1 Feb 06, 2012 05:20 PM
Discussion Elaine died March 3 RD Blakeslee Life, The Universe, and Politics 27 Oct 07, 2010 06:22 AM
