Old Aug 16, 2012, 12:24 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Originally Posted by ara25demayo View Post
maybe there is a balance because the 130 x is harder to fly but is small so it can be beaten up a lot more than the 450 but this one is easier to fly?
Looking at the two helis, the 130x isn't much cheaper than the 450. The 130x is flybarless, which is a more expensive option which is why it's priced just under the 450. Flybarless is kind of a luxury in my opinion. I personally would buy the 450, but that's just me. I don't mind and actually like mechanical flybars vs flybarless (electronic stability). Plus, the 450 is bigger, so you'll be able to keep track of it more while flying.
While the 130x has less parts, I feel the same amount of damage will be done to both helis in your average crash. As long as you kill power really fast, in most crashes the only thing you'll have to replace on both are blades, main shaft, maybe feathering shaft, and the actual flybar on the 450 (usually pretty cheap).
Here's a flybar vs. flybarless (FBL) discussion you might want to take a look at, good points from different sides. http://www.rcgroups.com/forums/showthread.php?t=1703012
finguz is offline Find More Posts by finguz
Old Aug 16, 2012, 01:56 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
There are many people that insist the small flybarless helis are lots easier to fly. My experience is they certainly are easier to start to fly. They don't have the intimidation factor, you don't worry much about damage and the directness of the response and stability are very reassuring. I was never a fan of flybarless systems in the past, but I'm sold on them now.
With respect to damage, I've never crashed a 450 that didn't require replacing feathering shaft, blades, flybar or some combination of these things. I've crashed a Genius and MCPx more times than I can count and have yet to replace any of those things. I've broken a few tail rotors on each, but that costs about $1 and takes 10 seconds to fix. Of course the tail of the 130X will be more complicated and less durable.
Balr14 is offline Find More Posts by Balr14
Old Aug 16, 2012, 02:15 PM
ara25demayo is offline
Find More Posts by ara25demayo
México, MOR, Jiutepec
Joined Oct 2011
well i think ill be geting the 130x due i have no much space of training i have a backyard of about 10 m x 5m and in my rc club they dont have a suface good for training
ara25demayo is offline Find More Posts by ara25demayo
Old Aug 16, 2012, 02:46 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Cool, good luck man.
Old Oct 09, 2012, 05:03 PM
fooferdoggie is offline
Find More Posts by fooferdoggie
United States, OR, Happy Valley
Joined Aug 2012
I have the 130x the mcpx and the nano. I thought the 130 was more reactive but then I found the settings for the other two were way too low. once I fixed them I found the 130x is easier to fly and smoother. so far at least one bad landing and usually two or three per flight and it is fine. landing in a field as long as I hit TH it is fine.
fooferdoggie is offline Find More Posts by fooferdoggie
Discussion The thing about aerospace workers is almost none of them still work in aerospace Jack Crossfire Life, The Universe, and Politics 1 May 24, 2007 11:17 PM
Wanted any 4-6 ch helicopter in the 0-90$ range. will buy almost any heli!!!!!! newbieflyer12724 Aircraft - Electric - Helis (FS/W) 8 Oct 19, 2006 06:58 PM
