Old Aug 13, 2012, 05:31 PM
Creator of the 1st 6S HT-Flip!
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
THE ALL NEW FPV Dream Machine Tricopter is available NOW!!!
OK here it is everyone finally ready for the consumers (AKA) you guys/gal's
Luis the creator of the FPVDM tricopter and myself have been working hand and hand trying to create the ultimate FPV tricopter kit. I started with his v1.3 frame and from there i beta tested it and from there id tel luis what needed to be fixed and upgraded id get the next frame that had changes to it then test and test and test. untill i found what needed to be upgraded or changed until finally i wasnt able to make anything better. Luis and i feel the FPVDM v1.5 is hands down the best Tricopter FPV frame available. watch the video for more info thanks
get the frame at myrcbuild.com.
THE FPV DREAM MACHINE (FPVDM) Tricopter V1.5 (14 min 14 sec)
FPV video
FPV Dream Machine Tricopter V1.5 FPV flight video. (6 min 14 sec)
Description
**PRE-ORDER This frame  will start to ship in 1.5 weeks***
** Version with Pivot control will also be made available after further testing **
note: parts are interchangeable.
THE 1.5 FPV Dream Machine
Frame comes with all hardware needed.
And screws also for motors, ( 3mm or  2.5mm Just ask for what you need)
PRICE INCLUDES SHIPPING - WILL SHIP FOR FREE.  This items ships via POST (first class mail) **you may request EMS**.  ( Shipping world wide )
The FPVDM is simply a FPV Pilots Dream.. why ?  here is what is included.
Options,  Options and More Options.... did I mention Options ?
1. All hardware needed is included
2.  Booms are include wood ( 3/8 or 1/2 Wood booms)
     3/8 are clamped via screws - Only one hole to drill
     1/2 are secured via center hole ( tail screws are flush mounted - ie flat head screws)
3. Booms can be secured via screws or zip ties.
    Good to fold back quickly for travel
    Good for breakaway action in even of crash
4.  Front boom can be configured in a Yshape or  T shape
5.  Tail boom
      Can use clamp style mount ( 3/8 boom)
      Can use through bolt (1/2 boom) for flush mount so no screws stick into your battery
6. Tail control has been described as BULLET PROOF
      Construction is G10 and 1/4 in - Acetal
7.  Motor Mounts
      Bolt pattern for  ( 16x19mm motors - NX400 - DT750 - and more .. )
     Motor Cage - Life Saver - Protects your motor case in event of a crash
*****  will have two version  for  30mm size motors and 45mm size ***
Please let me know what size you like.
8. Landing Gear
     Allows for quick installation via zip ties.
     Allows for 1/2 boom install
     Allows for 3/8 boom install
9.   Frame  Body
       Top frame is made of 2.3mm thick G10
       Lower Frame is made of 1.5mm G10
       Connection of top and bottom is done via 1.5 in standoffs
       giving plenty of space for components to be mounted.
       ** Lower plate is soft mounted to top plate via foam shop  absorbers.
10.  Battery Slots
       Frame has battery straps in key locations, main sets are in the rear for two different
       size batteries both on lower and top plate
11.  Flight board Mounting
          Frame has bolt pattern for two different size board
          Board can be mounted on TOP or bottom.
12. Construction
         Booms are  Wood ( intended to break away while you learn to fly)
         Frame body  2.3mm and 1.5mm G10
         Frame body has vertical spars to make it super strong
         Motor Mounts and Cages -  G10  2.3mm
         Tail Control  2.3mm G10 and 1/4 in Acetal
13.  Screws
        90% of the frame uses  metric screws  ( Top Quality Socket head Screws)
         Standoffs are Aluminum and ( 4-40) socket head screws ( top Quality also)
14  Recommended Setup
While the frame allows for you to test with many diff rent components.
it has been tested with by many pilots, from them 80% of testing was done with  NX400 Motors on 10in props 4S battery,
flohio117 is offline Find More Posts by flohio117
Old Aug 13, 2012, 08:20 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Looks good. I've mentioned some other ideas to Luis...perhaps some other versions further down the road. Now how about some flight videos...
Vantasstic is online now Find More Posts by Vantasstic
Old Aug 13, 2012, 08:31 PM
flohio117's Avatar
Joined Dec 2011
thanks i have some flight videos im in the process of editing
Old Aug 13, 2012, 09:27 PM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
My friend Luis did a very nice job here..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Aug 14, 2012, 08:01 AM
flohio117's Avatar
Joined Dec 2011
hey dont forget me too lol you should get one.
Old Aug 14, 2012, 08:02 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes feedback is really important.
If you didn't help him it would not be in that stage now.
I won't get one.. i might cut one.. since i am working with Luis ..
Old Aug 17, 2012, 02:36 PM
32 ft/sec^2 sucks
yoadrian's Avatar
Joined Nov 2006
Where do you get the NX400? How do they compare to the DT750?
yoadrian is offline Find More Posts by yoadrian
Old Aug 17, 2012, 03:16 PM
flohio117's Avatar
Joined Dec 2011
You can get nx4008s from hobbyking or getfpv.com
I'm not sure how well dt750s work bc I've never used them but I'm sure someone else will be able to comment on those motors.
I'm in the process of editing the fpv flight video. It should be up by Sunday.
Old Aug 17, 2012, 04:18 PM
Joined Nov 2010
I have the DT750 .. running on 4S .. 3.3mAh pack.. 10in props.. I only get.. 6min of flying.. But I'm 3400 feet above see level..
From what Flohio.. has told me.. nx4008 have tons of power.. get longer flights..
and are made for.. 4S ..
I have some in the mail now what frame to put them on..
flyhigh300 is offline Find More Posts by flyhigh300
Old Aug 19, 2012, 11:21 AM
flohio117's Avatar
Joined Dec 2011
new fpv video of the frame is now up
Old Aug 20, 2012, 12:05 AM
Joined Nov 2010
Here is the video ...
Old Sep 13, 2012, 04:12 PM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
http://youtu.be/5lHL5uLW41w
Amazing!
Do you power your onboard FPV equipment with a separate battery?
LittleG is offline Find More Posts by LittleG
Old Sep 14, 2012, 09:17 AM
flohio117's Avatar
Joined Dec 2011
Originally Posted by LittleG View Post
Amazing!
yes i do because it flies on 4s so i have a 3s battery for video gear.
Old Sep 14, 2012, 09:19 AM
flohio117's Avatar
Joined Dec 2011
new video Heres what a flight looks like with a bunch of brown outs and a crasl landing in someones yard! check out how i get out of the yard
please thumbs up if you like it!
Tricopter FPV the brown out flight. (its crazy watch it!) (4 min 59 sec)
Old Sep 14, 2012, 11:14 AM
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
http://youtu.be/j7_FRTyW2zU
Yah, you're right that was some crazy flying, especially when the first brown out occurred on top of the trees. I was scared for you. I'm flabbergasted how you were able to recover from it remarkably or else it would have been an arduous search and rescue.
You're tempting me with this FPV Dream Machine airframe... Must resist the force.
For Sale 8 NIB JR Radio Systems (all new old stock!!!!) Available Seperately FNW Aircraft - General - Radio Equipment (FS/W) 7 Sep 09, 2012 07:46 PM
For Sale iconic-X FPV frame available now :) whosYOURdaddy - QuadAddict Aircraft - Electric - Multirotor (FS/W) 0 Jul 20, 2012 09:23 AM
Discussion FPVDM - FPV Dream Machine (Tricopter) by MyRcBuild airbagit13 Video Piloting (FPV/RPV) 14 May 18, 2012 12:56 AM
Build Log FPV/UAV/AP tricopter build log [Changed from "Got the stuff... I went all out"] slisgrinder Video Piloting (FPV/RPV) 47 Jul 25, 2011 09:57 AM
Now Available: 1/8" GWS Drilled Pinions and Machined GWS Boxes for Astroflight BL WJ Birmingham Parkflyers 5 Jul 28, 2003 11:17 AM
