Old Aug 13, 2012, 01:15 PM
Nashville_Guitar is offline
Find More Posts by Nashville_Guitar
Joined Aug 2012
brookstone silver bullet helicopter lower blades won't turn
I've crashed my brookstone silver bullet helicopter and the lower blades won't turn. The upper blades turn fine, but no take off. Does anyone have a clue as to how to fix this? Thanks!
Nashville_Guitar is offline Find More Posts by Nashville_Guitar
Old Aug 13, 2012, 03:35 PM
TucsonFlyer is offline
Find More Posts by TucsonFlyer
Joined Nov 2011
Can you turn the lower blades by hand? Co-ax helis have 2 motors, one for each pair of blades. Check the motor wires and solder connections. More than likely you broke one of those. If the lower blades won't turn by hand then you likely broke a gear somewhere in there.
TucsonFlyer is offline Find More Posts by TucsonFlyer
Old Aug 13, 2012, 04:18 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Take it back. They'll swap it out for a new one. Brookstone is great with their warranty.
Daryoon is offline Find More Posts by Daryoon
Old Oct 01, 2012, 12:47 PM
Plasticjungle is offline
Find More Posts by Plasticjungle
Joined Oct 2012
Pull off the motor cover (3 screws on the bottom)...there are two white plastic gears in there independent of each other...in your case, the upper master gear (the small one that turns the large one), has slipped down its shaft...simply push it back down till it meshes with its slave. (the large one) reassemble, then attempt to fly the copter good luck mine won't fly for $#IT
Plasticjungle is offline Find More Posts by Plasticjungle
Wanted Brookstone Silver Bullet Helicopter snackdaddy185 Aircraft - Electric - Helis (FS/W) 1 Nov 04, 2011 07:54 AM
Discussion Brookstone R/c Heli Silver Bullet ikarah Beginner Training Area (Heli-Electric) 19 Dec 21, 2010 11:09 PM
Discussion Brookstone Silver Bullet is a POS ARCHER7153 Micro Ready-to-Fly 0 May 31, 2010 02:55 PM
Cool Brookstone Silver Bullet tippytoe Coaxial Helicopters 9 Apr 27, 2010 10:19 PM
Discussion Brookstone Silver Bullet a67ems Coaxial Helicopters 4 Oct 06, 2009 03:45 PM
