Old Feb 15, 2013, 11:22 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
dont forget to take pictures! and show us the v911 project. if its a plane post in that thread over at the indoor forum. if heli show it off in the v911 thread in micro heli forum.
dave1993 is offline Find More Posts by dave1993
Old Feb 16, 2013, 11:36 AM
6sharky9 is offline
Find More Posts by 6sharky9
6sharky9's Avatar
Joined Jan 2013
everything will be in my blog...The title is under my pro name..still waiting for parts and other things to arrive before i can start...not sure how long it will be..When i build a quad it will be in blog form as well...hope to see everyone there when i get started.
ill have pics and videos and tests and instructions...Will be a very in depth build from scratch on both the v911 and the quad.
6sharky9 is offline Find More Posts by 6sharky9
Old Feb 28, 2013, 12:58 AM
Richard_s is offline
Find More Posts by Richard_s
it WILL fly! someday....
Richard_s's Avatar
Slovakia
Joined Aug 2008
I got new 939 fc (from BG) and s107 motors from focalprice (came 7 black/white and 3 red/blue, in 10 pack) and built another quad. Seems trivial, but how to fix 939 props to those thin shafts? I used 2 strands of dental floss, so props fit tightly, but they are off-center, what causes really bad vibrations. Shaft are pretty loose in motor bushings, so this makes it ever worse. I balanced props as much as possible (some, but small vibrations felt when holding motor with fingers), but it still vibes, even gets into resonance. In the air fc freaks out. Shoots up, or even drops power intermittently, so quad almost falls down.
I think of epoxy drop on the shaft, filed down whit help of drill when hard. Is there anything less laborious? I cannot see how straightforward gluing props to shafts can be precise enough, so they are centered and perpendicular to the shafts.
Richard_s is offline Find More Posts by Richard_s
Old Feb 28, 2013, 09:58 AM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
I've been considering how to fit large hole props to a small shaft...
Cheap props/cheap method...
Center the prop in a small jig on the table of a drill press using a drill bit that fits well.
Raise spindle and replace with a larger bit that will fit some sort of plastic rod you have available. (perhaps a scrap from the tree of plastic model parts?)
Glue the rod in place.
Exchange drill bit for size that will fit you motor shaft.
Probably lube the cut with mineral oil???
Clean and balance.
Use a small drop of CA or other adhesive to affix upon motor shaft.
The question is... what will be the tolerance of your drill press spindle???
rustycase
rusty case is offline Find More Posts by rusty case
Old Feb 28, 2013, 12:54 PM
asanovrus is offline
Find More Posts by asanovrus
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
hi. after so much experimenting you must be able to answer the question: how length of booms matters if disregard other factors like weight?
asanovrus is offline Find More Posts by asanovrus
Old Feb 28, 2013, 01:13 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
I ran some simulations on a simple axis and varied the arm length, then swept through PID values comparing the controllability of the axis and found some interesting stuff.
If you disregard weight (and even if you regard it), extended the booms actually makes the frame react quicker. This means more maneuverability. However, you are generally limited by the response time of your controller and ESCs. This means, as you move the props further from the CG, you eat up your sensitivity margins. Too far, and risk destabilizing your aircraft completely. On the flip side, moving your motors closer to the CG improves your sensitivity margins, making it easier to tune your PIDs to gain a stable aircraft. Larger sensitivity margins also mean the less sensitive your aircraft will be to changes in performance, weight, control delays, or whatever.
ilektron is offline Find More Posts by ilektron
Old Feb 28, 2013, 01:19 PM
KlonWarz
Joined Dec 2012
Very good ilektron!
as an option, how abt tuning thrust with some sort of vector control?
rc
Old Feb 28, 2013, 01:26 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
Originally Posted by rusty case View Post
Very good ilektron!
rc
IMHO is why tricopters have such great yaw. A quick servo reacts quicker than spinning motors up and down.
Old Feb 28, 2013, 01:39 PM
6sharky9 is offline
6sharky9's Avatar
Joined Jan 2013
I agree..With a good aftermarket board you can tune for different variables like boom length and motors and weight and prop sizes etc...
With these pre programmed toy quad boards; were stuck with the parameters pre set from the factories..I wouldnt go farther than 1mm longer or shorter on boom size for a hybrid...id bet you can find the sweet spot somewhere within the length of boom the board was programmed for. Meaning within 1 mm shorter or longer at maximum
Old Feb 28, 2013, 01:55 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
i guess you havent read post #1 yet.
ive put v939 board on 60cm (2') frame. see video. and v929 fc on half size frame. there are advantages and disadvantages to various arm lengths but hard to say which is preferred. some like quick and frisky and other like slow and stable. i like both depending on mood and weather, indoor or outdoor. it is worth noting that the v929 fc on too small a frame will show minor oscillation and then theres the rebind issue for v939. pick your poison.
Old Feb 28, 2013, 01:56 PM
asanovrus's Avatar
Joined Mar 2012
very interesting! if this principle is right then putting v959 board on v939 will make it even more stable then v959? another question I have: why they put gears on v929 etc? gear reduces speed but it could be achieved reducing size of props
Old Feb 28, 2013, 01:58 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
a dap of polyurethane glue and eyeball the alignment it sets. if it ever does come off (unlikely) a touch of ca will keep it from ever coming off again. ever.
Old Feb 28, 2013, 02:13 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
i dont have a v959 but if its similar in size probably little difference. i do know putting fc from big quad in smaller frame makes for faster response but risks the "shakes". other way around increases stability but slows response big time. i think this accounts for lots of the complaints in the v939/v949 thread. they get used to one and might not appreciate benefits of the new toy or may develop unrealistic expecttions.
i have both and direct vs geared are completely different animals. the much heavier v929 has extreme lifting power compared to the smaller and quicker v939. just like in planes gearing is a way to allow use of bigger props with their increased efficiency and thrust. the different is not slight, sometimes an order of magnitude. for example putting a camera on stock v939 has dramatic effect on handling and flight time. not a positive effect either. and bigger battery also creates issues. my v929 pretty much ignores the 808 keycam stuck on there and lipo of 2x or 4x mah, no problemo.
Old Feb 28, 2013, 02:25 PM
asanovrus's Avatar
Joined Mar 2012
do you think it's not board that makes difference in power? I thought gear cannot give power, but it can reduce it by friction (one of gears on my v959 has imperfection that I can't fix causing more friction). what's the difference b/n big prop rotating slower and smaller prop rotating faster?
Old Feb 28, 2013, 02:27 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
Yeah, given the same motor, a larger prop allows for more thrust per watt, which makes up for the difference in weight and reduction in efficiency of the gears.
Also, a big prop spinning slower can be more efficient than a little prop spinning fast.
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 174 Jul 29, 2015 11:25 AM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
