Switzerland
Joined Sep 2008
Maybe something usefull for using our TX
http://www.hobbyking.com/hobbyking/s...mpatible_.html They should sell the board and the tx maybe under another name. At the end of the manual there are listed as spares |
New York
Joined Oct 2008
im almost willing to do it though just to see what protocol is used. |
I use a 9x also but no special settings other than I set the aileron and elevator rates to something like 75% so it won't auto-flip. |
Canada, QC, Montreal
Joined Nov 2008
Hi, that's great to know. I thought my board was defective or sth. Yeah I have a real quad too but I was under the impression that all these micro quad are stable like the ladybird. obviously not. I'm still learning to fly my real quad so learning to fly 939 is definitely helpful. the ladybird is way too easy to fly haha.
thanks for the info |
Australia, VIC, Chadstone
Joined Dec 2011
This allows you to safely land, but it also prevents you from over discharging the batteries. Unless you do what I did once, continue to fly the quad with it's two front legs skating along a smooth floor. You can continue to do this for a surprising amount of time and can probably over discharge you battery in the process. The LVC sounds low but you need to know how much the voltage dips on these little packs under high load. Do not believe the ridiculous C-ratings, especially the nano-tech ones which are outrageous. These packs struggle to hold 5A (16C) constant let alone the claimed 13A (45C)! As you noted, if you check the battery voltage after the first 'throttle cut' is normally around the 3.6-3.67V mark. This end value will vary depending on the IR of the battery and how hard you were flying it when the voltage dropped below 3.00V. ie) If you were doing high speed full throttle runs with hard banked turns then you'll dip below the cutoff voltage much earlier than if you a just hovering around in your living room. Or if you have an old battery with high IR then you will find the voltage can quickly crash below the cutoff value under a high load maneuver. |
| Thread Tools | |
| Build Log Lets Build a DIY FPV Spider Quad Together | Nick_P | Scratchbuilt Multirotors | 151 | Mar 12, 2013 11:33 PM |
| Sold DIY Open Pilot CC micro/mini quad BNF for sale | Hamanu | Aircraft - Electric - Multirotor (FS/W) | 4 | Aug 03, 2012 07:29 PM |
| Discussion Any good premade DIY Centre plate for AP Quad? | redblur | Multirotor Talk | 2 | Jun 24, 2012 08:10 PM |
| Discussion DIY Quad Frame hits snafu... | srs5150 | Multirotor Talk | 5 | Apr 30, 2012 10:46 AM |
| Discussion Looking for a good DIY guide for a 450 sized Quad | nige838 | Multirotor Talk | 2 | Apr 28, 2012 02:44 AM |
