Joined Feb 2007
Hi Richard,
By any chance did you accidentally reverse the lipo polarity on the fcb at any point? This sounds like a symptom of a bad pwm input/output from reversed polarity resulting in partial damage to the processor. Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index Quote:
Yeah I don't see anything wrong with that frame. I don't think it's vibration. I just checked my own quads and the board is actually loose on the frame and it still works fine. Or maybe it works fine because it's loose.
![]() So maybe a bad motor, bad board, or it's the TX... I guess
Joined Feb 2007
Richard,
Regarding your oscillations: Is the fcb directly on the wood, or did you place some isolation material such as foam or servo tape under it? I can't tell how well the rubber band is holding it to the center piece, but it could be allowing excessive vibrations to the fcb. Something to experiment with anyway... On your throttle...I know this seems obvious, but gotta ask. Is your throttle channel reversed?... It could be a Tx end point issue where there is a dead step at the high and low endpoints that are set.Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index |
Throttle channel is... pretty normal I guess . I fly airplanes, KK 3copter, MWC 3copter, v911, and no problem. Throttle is linear from min to max. I'll see what will expo do.
New York
Joined Oct 2008
when first trying a 9x i got "hit the ceiling syndrome" too. it required some tweaking of rates to get throttle and other sticks under control. the stock wlt radios have dual rate button and the defaults are nothing like a 9x. i went back to the v911/v939 units because 9x was just too big so dont have details on those settings handy.
as far as wobble a couple of my builds did that for no obvious reason. best solution was to make another frame with slightly different dimensions or weight. same motors, board, bat, etc but worked like a charm. no explanation. i suspect their control algorithms are not the same pid stuff used by kk, mwii, etc and one of the drawbacks seems to be instability at certain peculiar arm lengths and weight distributions. even tiny changes made a world of difference. longer arms always help with wobble too. specially with v929 board. my advice is throw together another quickie. maybe lighter and a little bigger dimensions but not putting a lot of work into it just in case. might try different lipo too. ive now had experience with 5 reverse battery boards both types and have yet to see flaky behavior. either they worked or didnt. ones that didnt got going by fixing blown run. in all cases the tantalum was burned to a crisp and although it seemed to work w/o i replaced with 10uf ceramic just to be safe. i also saw no difference between boards firmly fastened down or suspended loosely by wires. you never know though. theres so much going on in that mcu im amazed to see that almost all my attempts worked. could still be a bad board though. having two is a big advantage and imo considering $8 price tag no excuse not to. |
Great info Dave, thanks!
Expo didn't solve anything, quad responds to throttle maybe after first third of movement, what looks like linear part of expo curve anyway . However I got a little lucky, I could oppose "ceiling shot" ONCE. Man, this thing is touchy... .Some serious throttle curve tuning will probably be the cure.Other channles seem fine, I can fly it after voltage drops off a bit. I noticed it oscillates aroud one diagonal axis (running thru two arms), so, two motors are "still", and two see-saw about that axis. I'll give this frame another shot, I'll re-measure all arms, and maybe shorten one of wobbly ones, or something . I REALLY want this to work, I was waiting for postman like kids wait for santa
| Thread Tools | |
| Build Log Lets Build a DIY FPV Spider Quad Together | Nick_P | Scratchbuilt Multirotors | 151 | Mar 12, 2013 11:33 PM |
| Sold DIY Open Pilot CC micro/mini quad BNF for sale | Hamanu | Aircraft - Electric - Multirotor (FS/W) | 4 | Aug 03, 2012 07:29 PM |
| Discussion Any good premade DIY Centre plate for AP Quad? | redblur | Multirotor Talk | 2 | Jun 24, 2012 08:10 PM |
| Discussion DIY Quad Frame hits snafu... | srs5150 | Multirotor Talk | 5 | Apr 30, 2012 10:46 AM |
| Discussion Looking for a good DIY guide for a 450 sized Quad | nige838 | Multirotor Talk | 2 | Apr 28, 2012 02:44 AM |
