Old Jan 20, 2013, 04:57 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Not found on banggood.com.
But on massiverc, but only for US guys :
http://www.massiverc.com/PrestaShop/...n-2-cwccw.html
mystman is offline Find More Posts by mystman
Old Jan 20, 2013, 08:01 AM
siriusflier is online now
Find More Posts by siriusflier
GOT WINGS
siriusflier's Avatar
United States, TX, Wilbarger
Joined Apr 2012
djdavies 83, mystman gave a good link for the green props but you are not in US. I recieved two sets with my v202 and haven't looked for spares. I have had good results spray painting props - on my gw 9958. But it is a different plastic, I think. Just go where they sell V202s and look for parts.
siriusflier is online now Find More Posts by siriusflier
Old Jan 20, 2013, 10:03 AM
AirBladeUAV is offline
Find More Posts by AirBladeUAV
AirBladeUAV's Avatar
Canada, BC, Vancouver
Joined Nov 2008
Originally Posted by rusty case View Post
Gosh, BCF... if you had put the arms on the opposite side of your platform, impact would not drive the arms directly into the circuitboard !
Nothing wrong with lashing the booms to your platform... Some spiderwire with a drop of CA or epoxy over it is probably better than the common metallic fasteners!
rc
hey good thinking, I'll try to glue them on the opposite side once this frame is broken. so far it's quite resistant to crash so I'm happy.
I'm sure ppl have tried this before but how do you mount the 808 on your ladybird/939? I mean in terms of weight and stuff, do you just take off the casing? can the 808 be plug into one of the two open ports on the ladybird board?
thanks
Nguyen
AirBladeUAV is offline Find More Posts by AirBladeUAV
Old Jan 21, 2013, 03:55 AM
xardinen is online now
Find More Posts by xardinen
Joined Aug 2011
Damn you Banggood. My order with the spare parts I need to be able to fly again has been stuck at "Flytexpress" now since 8/1. I wonder what is going on.
xardinen is online now Find More Posts by xardinen
Old Jan 28, 2013, 02:23 AM
dumb_thumbs is offline
Find More Posts by dumb_thumbs
wrong descision, wrong time
United States, WA, Maple Valley
Joined Sep 2010
Here is my first attempt. Sad to say, but it did not really fly at all . I think it is just too heavy at 46g all up weight. It tries to take off when I give it full throttle, but I don't think there is enough power to keep it level and straight. It spins off and dives to one side. I'm using the 7mm motors with the short 1mm shaft, so I think they have enough power. Also, I'm using a 600Mah single cell battery. You can't tell from the pictures, but under the foam is a basswood stick frame, that is where the weight is coming from. I'll make another frame here soon that's much lighter.
-Heath
dumb_thumbs is offline Find More Posts by dumb_thumbs
Old Jan 28, 2013, 05:57 AM
midelic is offline
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
It is too heavy.Max 40 grams
midelic is offline Find More Posts by midelic
Old Jan 28, 2013, 07:32 AM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
Gotta look at the brite side, DT...
That basswood stick and long, wide foam booms have kept you from crashing it!
Can't wait to see your V2 !
rusty case is offline Find More Posts by rusty case
Old Jan 28, 2013, 11:51 AM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
-Heath
Does it dive in the direction on the orange blades?
I could be wrong but it looks like you orange blades are in the wrong position so it's pushing down on that side, leave the black blades as they are and try and swap the orange blades with each other.
Swap your two orange bladed motors (do not take blades off orange motors).
Description:
Blades and motors should be diagonal pairs, see below...Name: ImageUploadedByTapatalk1359395074.938738.jpg
Description:
See my black and white motors are diagonal from each other and your are on the same side (rear)?
Look at the angle of my X4 blades and the arrows on the V929 PCB.
Description:
Along the centre line of the craft the inner blade edges of the left/right motors should be the same angle (look at how the light is shining on my blades).
Your flying weight is a little a little heavy but it should take off, my X4 flew for 5 mins at this weightName: ImageUploadedByTapatalk1359395418.692113.jpg
Description:
See?
Hubsan X4 Quad with onboard 808 #8 FPV (5 min 21 sec)
Swap your orange blades motors and your good to go, happy flying dude!
djdavies83 is offline Find More Posts by djdavies83
Old Jan 28, 2013, 12:45 PM
midelic is offline
midelic's Avatar
Joined Apr 2012
I tested myself an hybrid with Syma X1 board.The conclusion is....big s**** ever, waste of money.I have no control on full 100% rate, the quad is not moving, ail/ele full stick, only throtle up down....and that's it.
Old Jan 28, 2013, 12:49 PM
rastsaurabh is offline
Find More Posts by rastsaurabh
Joined Apr 2012
ANYONE TRIED WITH mjx200 FC ??
rastsaurabh is offline Find More Posts by rastsaurabh
Old Jan 28, 2013, 02:22 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Ok this IS what you need to do...
step one.
Attachment 5488792
Swap blades only.
Step two.
Attachment 5488439
Swap these motors and their plug positions but keep the blades where they are, this will give you diagonal pairs of motors and rotation, if the blades spin the wrong will will have to swap around the wires for that motor.
Description:
Old Jan 28, 2013, 02:26 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Swap blades
Description:
Swap motors and plugs leave blades where they are
Description:
Old Jan 28, 2013, 04:33 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
a friend has built a diy quad using that board and it flies very nice. be aware it only works with the stock tx though. not 9x or any other quad radio. in fact the tx is not even compatible with his brothers mjx.
dave1993 is offline Find More Posts by dave1993
Old Jan 28, 2013, 06:47 PM
KlonWarz
Joined Dec 2012
to DT...
my complaint about the foam is that it is obviously blocking 25% of the motor thrust.
rc
well, maybe less than 25%, but quite a bit...
Old Jan 28, 2013, 07:25 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
The foam underneath may not affect thrust as much as you may think, as long as the air can flow around it. Coanda effect!
GFS Fenstar 'flying saucer' Coanda-effect UAV (1 min 30 sec)
ilektron is offline Find More Posts by ilektron
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 174 Jul 29, 2015 11:25 AM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
