Old Jan 05, 2013, 12:26 AM
ArchillesElbow is offline
Find More Posts by ArchillesElbow
South Africa, GP, Johannesburg
Joined Dec 2011
Thanks Sirius... Just reading up on it now
ArchillesElbow is offline Find More Posts by ArchillesElbow
Old Jan 07, 2013, 04:20 PM
ztoon13 is offline
Find More Posts by ztoon13
Gone with the Mistral
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
Ice cream sticks...
Hi,
As I did not have barbecue sticks on hand (what an excuse...), I try to make a kwkqd (my first "homemade" quad at all ) with ice cream sticks : to my surprise, it flies pretty well, but is anyway overweighted (32g says my balance, but maybe not accurate at all...)
There is no landing gear so the first gyro init was not really level, but I managed to keep it steady, really surprising.
In fact, the 2nd battery flight show me how this little thing is stable (less than 5" = 11,5cm M2M), most of time was in a 1 square meter, very little correction.
But maybe trouble will start when I try a loop (not tested yet). I'll see that.
So here is my version of Dave1993 <20$ quad (thanks for your DIY thead, that's really cool)
FC = v939 (fly with my 9X)
motors = 7mm (dont remember where they came from, was last month...)
prop = mjx100 (not sure either...)
battery = 300mAh (WL v939 stock batt)
4 ice cream sticks = pick your favorite (black chocolate)
Will try a video tomorrow
Olivier
ztoon13 is offline Find More Posts by ztoon13
Old Jan 07, 2013, 10:52 PM
siriusflier is online now
Find More Posts by siriusflier
GOT WINGS
siriusflier's Avatar
United States, TX, Wilbarger
Joined Apr 2012
ZToon, I like it. Good first effort, probably better than my first. My first weighed 46 grams wo battery and was 14 cm M2M. Could only get its weight down to about 38 grams, so I am trying again. Have a frame almost finished that will be 9 cm M2M. Part of my weight problem might be that I am using a board from a bigger quad, the Syma X1 board, but it did work well with my T9x tx. I will try to post pictures when I get it all together.
siriusflier is online now Find More Posts by siriusflier
Old Jan 07, 2013, 11:38 PM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
Ztoon, that looks fantastic. Much better than the bamboo skewer quads. I may have to reconfigure one of my U816's into something like that. Please post a video.
variantman is offline Find More Posts by variantman
Old Jan 08, 2013, 08:45 AM
xardinen is offline
Find More Posts by xardinen
Joined Aug 2011
Yesterday I received the parts that I ordered from Banggood, putted it together and flew it. What a blast, but on mysecond flight the quad crashed and landed on one of the props (ofcourse) and pushed the motor shaft through that poor motor. So here I am, waiting on a new order from BG to arrive. I did order some extra batteries besides replacement and spare motors.
It's the v939 board and 300mah battery. What flight times can I expect with an AUW of ~27g?
xardinen is offline Find More Posts by xardinen
Old Jan 08, 2013, 08:56 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi X,
At that typical ~30g micro AUW, expect 5-9 minutes with varying quality ~240-350mah lipos: Micro quad OEM and Turnigy Nano-Tech lipo tests 101 Do the Motor saver mod on your motors to keep the motor landings from pushing the bottom of the motor apart: Micro motor saver guards
More info can be found int he Mini and Micro Multicopter section of the Quadrocopter and Tricopter Info Mega Link Index
Cheers,
Jim
Originally Posted by xardinen View Post
Yesterday I received the parts that I ordered from Banggood, putted it together and flew it. What a blast, but on mysecond flight the quad crashed and landed on one of the props (ofcourse) and pushed the motor shaft through that poor motor. So here I am, waiting on a w order from BG to arrive. I did order some extra batteries besides replacement and spare motors.
jesolins is offline Find More Posts by jesolins
Old Jan 08, 2013, 09:22 AM
ztoon13 is offline
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
Hi,
My guess is you can start with a 5min flight and see how low goes your batt at the end. Maybe you can have a 7min flight time, your quad seems to be in the "light" range I think. Btw, my balance says 34g today (same configuration as yesterday, ready for flight with batt, maybe I'll find less tomorrow)
Originally Posted by jesolins View Post
Hi X,
I was not aware that the shaft could possibly move in case of crash. Did I understand well ? I suppose the mod keep the prop from pushing down, right ? if yes, this mod must be done quickly...
Find a short video of my version
short hover test flight (1 min 8 sec)
Olivier
Last edited by ztoon13; Jan 09, 2013 at 12:49 PM. Reason: video insert instead of link
Old Jan 08, 2013, 09:50 AM
jesolins is offline
Joined Feb 2007
Hi Z,
Nice work on your DIY frame
Yes the motor bottoms can be pushed out in an upside down crash with obviously bad results in damaging or ruining the motor. Here is a Traxxas video on how that can sometimes, but not always be fixed: Coreless motor bottom fix video
That link can also be found in the Mini and Micro Multicopter section of the Quadrocopter and Tricopter Info Mega Link Index
Cheers,
Jim
Find a short video of my version here
Olivier
Old Jan 08, 2013, 11:12 AM
xardinen is offline
Joined Aug 2011
Yes, right after the crash I did that mod to the remaining motors. I hope this mod will make the copter last a little longer.
Old Jan 08, 2013, 01:14 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
There is no need to do battery timing with the V939 board because it has auto-shutoff when your battery is approximately 80% used. Just fly until it forces you to land and won't start again then your battery will be discharged a safe amount.
LittleMo is offline Find More Posts by LittleMo
Old Jan 08, 2013, 03:20 PM
Joined Jun 2012
That's neat. I wonder if all the micro nd mini quads do this? It would make sense.
Old Jan 08, 2013, 03:29 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
I'm not sure but my Genius CP does it too. My V911 does not but you can tell when it's low because it won't fly.
Although many people don't trust these auto-shutoff mechanisms, in my experience it has been very accurate judging by how much charge the batteries take afterwards.
Old Jan 09, 2013, 04:25 AM
xardinen is offline
Joined Aug 2011
Given the price on these 1s lipos I gladly trust the auto-shutoff on my v939 board.
Any updates on the micro MWC board? I'd love to have accelerometers and MWC on a quad this small, it would be a great platform for a computer vision based control system that I have in mind.
Old Jan 09, 2013, 07:03 AM
ztoon13 is offline
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
HI,
I did not know that...
You're right, these lipos are cheap, let's try the auto-shutoff. I ended with 3,65V after a 7min flight time, which is just 0,1V below my favorite value. Given the accuracy of charger/multimeter and the fact I'm lazy, I guess it's about the same .
Best part is that it seems (only 1 batt test) to be a "soft" cutoff, it does not fall like a rock.That's important for me as I'm not sure yet how my quad will take a hard crash (already had some, still survive).
I wonder if it is the same for my v929..?
Thanks for sharing
(edit) I add a second (boring) video of my build
desktop hover training (8 min 24 sec)
Olivier
Old Jan 12, 2013, 03:14 PM
GOT WINGS
Joined Apr 2012
ok, I have been working on this DIY quad for awhile, first attempt was kind of heavy, second attempt still is-weighs about 38g without battery, canopy, or landing skids, so I am not really happy with it, but it flies, and was cheap as far as parts go. $9.51 for Syma X1 board, 1.68 for MJX X100 rotor blades, and 5.16 for nylon elbows. So cost of parts bought and used equals $16.51. Cost of design, engineering, time spent, and labor would be....a lot Amount learned and challenge...great!! I bought 4 syma x1 motors for about $11, but I decided to use or V929 motors and save the x1 motors as replacements for my V202. Pinions were wore out on V929 motors, so I removed them for direct drive application. I put x100 blades on v202, so this one has V202 blades. There is an aluminum crossbrace underneath and a velcro strap to mount the battery. I have only been able to fly it inside for a brief period, but I think it will fly fairly well.
I used bic pens for booms because I wanted to be able to run motor wires inside and use the nylon elbows, but that frame combo is too heavy and the wires are only iside for an inch or so, and they are difficult to align. The x1 board adds weight, and the 8.5mm diameter motors also contribute to making it too heavy, only advantage was they were inexpensive. My next build will use wood to reduce weight an ease alignment and assembly.
The diagonal diameter from front right motor center to back left motor center is 9mm. I still need to add some kind of canopy and some legs, but here are some pictures. Most of my inspiration came from reading this thread.
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 174 Jul 29, 2015 11:25 AM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
