Old Nov 28, 2012, 02:54 PM
RC beginner
New York
Joined Oct 2008
yes, and like i said im not sure whether it increases or decreases stability on these quads. it really blew my mine when somebody suggested lower cg dont help a heli. i kept thinking "pendulum effect" but thats only true for planes. there were two thread that went on for hundreds of posts arguing the point. one was in (i think) sr70 fellows jar (just aint right) megathread where one aerodynamic expert was piled on by 20 guys who refused to believe. another thread was about the ball type frames used in some japanese copters where it was also eventually explained convincingly but took some effort. finally most of us came to believe lower cg did not make it better. i still have to think twice about it though.
dave1993 is offline Find More Posts by dave1993
Old Nov 28, 2012, 03:05 PM
Joined Jan 2012
No wobbling with v929 (8 plug)/UDI hybrid!!!
I've just tested my new v929 8 plug replacement board from banggood.
There's no more wobbling anymore even if I use small motor diameters (115mm) !!!!
I've plugged UDI motorarms complete into the v929 frame as you can see.
The board is more stable than the v929 4 plug board, but it has slower yaw.
Speed is between the v929 4-plug and v939 yaw.
You can fly very agressive turns with this stability. Full Yaw stick doesn't let the quad crash like with the old v929 or the v939.
It does have same less lifting punch like the old v929 and I need more throttle to lift which seems to lead to shorter flighttime.
For Midelic: Weight is 28g / m2m diameter : 115mm
Ingredients:
* v929 8 plug replacement board
* v929 frame
* UDI 816 clockwise & anticlockwise motorarms
* MJX X100 props
mystman is offline Find More Posts by mystman
Old Nov 28, 2012, 03:33 PM
midelic's Avatar
Joined Apr 2012
@mystman
Look for my mod of V929 main frame and cut off 1.6 grams.
with UDI motors every gram counts.
Sorry!Job conditioning.Now you have it....at least on this page.
midelic is online now Find More Posts by midelic
Old Nov 28, 2012, 03:37 PM
Joined Jan 2012
Originally Posted by midelic View Post
@mystman
I KNOW ! It's just a try, if it works. You always must have the last words
Do you want to tease me ?
(After this try, I put the board back on a already weight reduced frame with 150mm m2m diameter)
Old Nov 30, 2012, 03:45 PM
RC beginner
New York
Joined Oct 2008
recently somebody asked me "what was the ten cent tach mentioned in diy quad thread?". i thought people read EVERY SINGLE post on rc groups. lol! anyway here is a link to that i started some time ago which is somewhat related to the current thread:
http://www.rcgroups.com/forums/showt...9#post23197098
below are a couple photos that might be of interest in case you missed them. first shows scope trace of tach signal from a "weak" aliexpress motor with udi props on 4v. the second photo shows an s107 motor under same conditions. you can see the pulses are farther apart in the first one indicating lower rpm. looks like 1.2ms per blade for 23k rpm vs 1.9ms at 16k rpm:
ps stop teasing your brother or I WILL TURN THIS CAR AROUND RIGHT NOW!
Old Nov 30, 2012, 03:51 PM
Joined Jan 2012
We're both fine again, DAD
Old Nov 30, 2012, 07:02 PM
RC beginner
New York
Joined Oct 2008
ok then. next stop... disneyland. ooh la la!
btw those are really fine constructions. i got couple meters of the square cf and considered canibalizing my v929 frame. but it does such an excellent job of lifting, far more than any of the direct drive quads, so i like to keep it in stock condition. maybe time to consider picking up a body from bangood. but i got half dozen goodies on the way now so probably will wait a bit. tgif.
Old Dec 08, 2012, 01:50 AM
Joined Aug 2004
Anyone got their Syma-X1 control board? Recommended?
Raj Quest is offline Find More Posts by Raj Quest
Old Dec 10, 2012, 11:00 AM
RC beginner
New York
Joined Oct 2008
its now over a month since ive placed my order for one. im getting worried. funny thing is they get to the usa from china in 2-3 days. then sit in some warehouse right here in ny while homeland security checks them for fissionable material.
thanks a bunch george bush....
Old Dec 10, 2012, 11:11 AM
midelic's Avatar
Joined Apr 2012
I got mine few days ago but unfortunately I'm not at home to test it.I'll test it in January.
Old Dec 10, 2012, 11:16 AM
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Gents,
My Syma X1 fcb's arrived a couple of days ago after about the typical BG month of so wait. The only thing I've had time to check so far is to confirm they will bind with a FlySky protocol.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is online now Find More Posts by jesolins
Old Dec 11, 2012, 04:50 PM
Israel
Joined Mar 2012
CW Motors Spinning Slowly
Hi All, I have finally received 2 v939 boards. After connecting all of the wires according to the drawing below, it looks like the CW motors are spinning much slower than the CCW and after raising the throttle to max once would take more than half throttle to start spinning again.
If I take one motor (doesn’t matter which) and connect it to connector 1 in the pic – it spins ok but when I connect the same motor to connector 2 it goes slow.
This happens on both my v939 boards. Has anybody seen this behavior?
gilcd85 is offline Find More Posts by gilcd85
Old Dec 11, 2012, 04:57 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swansea
Joined Apr 2010
My guess here is that you trim is set way off to the right, give it some left rudder trim.
I've still only had one DIY quad in the air so far so that all I can offer I'm afraid.
djdavies83 is offline Find More Posts by djdavies83
Old Dec 11, 2012, 05:02 PM
LittleMo's Avatar
United States, VA
Joined Dec 2006
Does it fly? I notice often motors don't spin until I actually put it in the air.
LittleMo is offline Find More Posts by LittleMo
Old Dec 11, 2012, 05:47 PM
Israel
Joined Mar 2012
Thanks all! Next time just tell me to switch RUD and AIL
Works perfectly now - what a great little quad!
My build:
- red/blue aliexpress 7mm motors
- v939
- bamboo frame (m2m 135mm) with PU enamel impregnated motor mounts
- LB props
- 260mah battery.
Overall weight including battery: 30g
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 151 Mar 12, 2013 11:33 PM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
