Old Nov 13, 2012, 11:49 PM
ArchillesElbow is offline
Find More Posts by ArchillesElbow
South Africa, GP, Johannesburg
Joined Dec 2011
Originally Posted by Raj Quest View Post
WHICH MOTOR:
For my next build I'll go with a V939 board....
I already have ladybird props....
But this time I need a bit more power and faster response.
So which motor should I go with...
1) Hollow cup 7 x 20 (with ladybird prop mounted direct drive)
2) S107 main motor (with ladybird prop mounted direct drive)
3) WLtoys V929 Beetle (with ladybird prop mounted direct drive)
Personally I like #3 as it does have power in tap.. And the quad is not so finnicky about the cog etc.. But I had to fiddle a bit to get the arms and holders just right so they don't twist with the additional power.. I am not sure if a foam frame would hold up.. But if it did it would be even better
ArchillesElbow is offline Find More Posts by ArchillesElbow
Old Nov 14, 2012, 01:10 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
WHICH MOTOR:
for $18 quad there is no chance with #1 or #3 but for more power and faster response the s107 is not a choice. obviously v929 8.5mm motor will do that but probably best with a bigger prop. 5mm instead of 3mm bamboo or even cf may be needed. it will be heavier and flight times shorter. also more crash damage comes with more speed and weight. so maybe the 720 is your next step.
even if you dont hit the $18 mark these things are still cheap and frames are almost free so why not try them all.
dave1993 is offline Find More Posts by dave1993
Old Nov 14, 2012, 01:27 AM
Raj Quest is offline
Find More Posts by Raj Quest
Joined Aug 2004
Dave,
OK I think I'll go with 7x20.
But for V929, 8.5mm motor, which prop is best recommended (direct drive).
With what you said, I think, ladybird props will turn out to be smaller?
I would like to order all material at one time now..... second build with 7x20, and third build with V929-8.5mm motor.
I believe V939 board works best with them all?
My first miniquad is already under 18$.
So for the second one, it doesn't really matter! (Although I know I'm writing in the 18$ thread, LOL!)
Raj Quest is offline Find More Posts by Raj Quest
Old Nov 14, 2012, 03:19 AM
Joined Dec 2011
Firstly with the v929 motors u def not going to hit $18... Unless u have these lying around or someone gets em really cheap..
I tried using cf arms both 2mm solid tubes and 3mm squares, and there was just too much shifting and torsional movement, but this maybe due to the motor holders being 3mm rounds so it wasn't a great fit.. The bamboo was just the easiest to manipulate.
I also tried using bigger props, just to see the lift power, I tried using the tail prop of a solo pro 328, which is about a cm bigger than the walkera... And got some funny results. When throttling up with this prop, the board just resets.. It's a new board a v929 8 plug rev 02... So I went back to the smaller walkera... But want to try the mjx..
Old Nov 14, 2012, 03:22 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
But you can get cheaper Syma X1 motors ($2.59 pc) :
http://www.banggood.com/Wholesale-Sy...4-p-54187.html
mystman is offline Find More Posts by mystman
Old Nov 14, 2012, 03:30 AM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Raj,
Go for 7x20 ,U816 motors.
Motors 3.20 USD each with motor/arm holder and plugs.It has the best price(considering the other accessories coming with motor).No need to fabricate any holder.
I ordered myself another batch.
http://www.banggood.com/Wholesale-Ud...4-p-48836.html
http://www.banggood.com/Wholesale-Ud...3-p-48839.html
WHICH MOTOR:
midelic is online now Find More Posts by midelic
Old Nov 14, 2012, 03:31 AM
mystman is offline
Joined Jan 2012
Originally Posted by midelic View Post
raj,
go for 7x20 ,u816 motors.
Morotors 3.20 usd each with motor/arm holder and plugs.no need to fabricate any holder.
http://www.banggood.com/wholesale-ud...4-p-48836.html
http://www.banggood.com/wholesale-ud...3-p-48839.html
+1 !!!
Best Deal !
Old Nov 14, 2012, 04:20 AM
Joined Aug 2004
midelic:
Raj,
mystman: +1!!!
UDI Motor is the same as ladybird-hollowcup-7x20? just that it comes with the boom? is it like that?
This should work equally good with ladybird props??
What is the dia and weight of the udi prop?
Raj
Old Nov 14, 2012, 04:24 AM
mystman is offline
Joined Jan 2012
Yes. can't tell the difference of the motors. Maybe compareable with a LadyBird booms.
I'm using them on several of my plug'n'fly microquads. Nice punch
Yes
dia : 55mm
weight: 0.4g
Old Nov 14, 2012, 04:33 AM
Joined Aug 2004
Thanks....
any suggestions on which prop to use with
V929 8.5mm motor for optimum performance?
Old Nov 14, 2012, 04:40 AM
mystman is offline
Joined Jan 2012
Thanks....
If directdrive I would sugest original QR LadyBird or MJX 100 props
MJX props
http://www.banggood.com/Wholesale-Mj...t-p-48888.html
Old Nov 14, 2012, 04:43 AM
midelic's Avatar
Joined Apr 2012
Raj,
You can use UDI motors with Walkera QR props.No problems at all.I used like that.Or with Mjx 100 props.UDI props are ok., but it was reported that Walkera and Mjx 100 have more lift.The motor shaft is 1 mm size the same for all these motors/props.
mystman you are faster than me.
Old Nov 14, 2012, 04:45 AM
Joined Aug 2004
Thanks-a-lot....
one last...
anyone knows dia and weight of MJX prop?
Old Nov 14, 2012, 05:30 AM
mystman is offline
Joined Jan 2012
Thanks-a-lot....
one last...
Dia : 58mm
Weight: 0.4g
Old Nov 14, 2012, 07:11 AM
Joined Dec 2011
Has anyone tried using a syma x1 board yet?
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 174 Jul 29, 2015 11:25 AM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
