United States, TN, Knoxville
Joined Jun 2012
I'm a little confused on wiring those motors up to the board (from the first page). Is this what you use?
![]() http://www.hobbyking.com/mobile/view...dproduct=19565 Solder those onto the end of the S107 motors and just plug 'em up to the board? |
Joined Jan 2012
South Africa, GP, Johannesburg
Joined Dec 2011
So I had a few v929 spares and some old 8mm motors (from solo pro 328 tail) I put them together using 8.5cm bamboo arms, a v929 frame and v929 rx board.. And ladybird blades. It might not be $18 dollars if u bought all the parts now.. . But it sure is fun to fly
using a 500mah battery..I used the original 328 tail motor holders to hold the motors.. It's not very affected by slight changes in cog
Israel
Joined Mar 2012
Thanks mystman!
I have: - AliExpress 7mm - blue/red - 7mm Hollow Cup LB - blue/red & black/white (4 of each) So when connecting the AliExpress motors I just solder two in reverse & the hollow cup motors should be easy enough to figure out.. Now all I need is for my V939 to arrive - it was shipped almost a month ago ![]() Quote:
New York
Joined Oct 2008
of the 2 dozen quads built so far with paper tube/bamboo not a single one has sustained frame damage. and some crashes have been full speed into the asphalt. broken props...yes, bent shafts...yes, worn brushes...yes, broken wires...yes, damaged frame...not one yet. |
I'm sure the pu glue will stick excellent to the pu oil coating. That's surely what I will end up doing since it works so well for you. Thanks!
New York
Joined Oct 2008
im using parks "pro finisher" floor emanel from home depo. it was $15 a quart and $17 for a gallon so you might guess which way i went. its still good after 3 years now. every few months i fill a bottled water bottle to dip things in and coat things with.
somebody posted a photo of it along with a few other types earlier in this thread (mystman probably, if i know that guy ). i tried water base and it was no good. maybe other type of enamel or laquer will work but if it dries fast then not so tuff beacuse it donr sink in.
| Thread Tools | |
| Build Log Lets Build a DIY FPV Spider Quad Together | Nick_P | Scratchbuilt Multirotors | 151 | Mar 12, 2013 11:33 PM |
| Sold DIY Open Pilot CC micro/mini quad BNF for sale | Hamanu | Aircraft - Electric - Multirotor (FS/W) | 4 | Aug 03, 2012 07:29 PM |
| Discussion Any good premade DIY Centre plate for AP Quad? | redblur | Multirotor Talk | 2 | Jun 24, 2012 08:10 PM |
| Discussion DIY Quad Frame hits snafu... | srs5150 | Multirotor Talk | 5 | Apr 30, 2012 10:46 AM |
| Discussion Looking for a good DIY guide for a 450 sized Quad | nige838 | Multirotor Talk | 2 | Apr 28, 2012 02:44 AM |
