Old Nov 12, 2012, 10:45 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
I've tested the MJX props the first time last weekend.
Wow I'm very impressed. They are more silent (maybe better balanced) than the UDI and have much lifting power.
I will go on testing in real life situations when flying outdoors.
For now the MJX and the LB props are my favorites!
mystman is offline Find More Posts by mystman
Old Nov 12, 2012, 11:08 AM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
MJX blades are bigger than Walkera's.What is the difference in flight time between those two?
I also ordered MJX blades and waiting for them.
I'm searching and trying now to fit some new light canopies.I have these light polystyrene spheres from Crystmas tree ornaments.Anybody have an ideea how to paint polystyrene(light paint)?I tried something but it disolves it.EPS is easy to carve using a soldering iron easier than cutting soft butter.
My v939 hybrid.I'm very pleased about it.Atm it plays nice and stable.I've installed some plastic props/motor guards(an ideea I found on some rcgroups posts) to prevent motor shaft/brushes being damaged when crashes occur.
midelic is online now Find More Posts by midelic
Old Nov 12, 2012, 12:19 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Airbrushing works, you can also use rattle cans of Krylon H20. Anything that you read works with Depron or FFF will work on EPS.
acetech09 is offline Find More Posts by acetech09
Old Nov 12, 2012, 02:32 PM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
One thing on my list to try for colouring foam is spraying on Sharpie......
What am i on about? Well back when I was a kid I had this thing call a "getset air spray", it was a cheap plastic footpump like you would get with a air bed, a length of rubber tube and a thing that looked like an airbrush, it held a felt tip pen and hen you pumped it would spray the ink off the tip of the pen, I'm gonna try and mount a Sharpie to my airbrush and have a go at spraying with it.†
djdavies83 is offline Find More Posts by djdavies83
Old Nov 12, 2012, 02:35 PM
acetech09's Avatar
Joined Apr 2012
Warning: SHARPIE WILL MELT EPS. It works fine on EPP but it'll melt styrene-based products.
But a sharpie airbrush would be pretty cool
Old Nov 12, 2012, 05:08 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Would that be Sharpie specific or permanent markers in general, I used a permanent marker on my XPS foam frame and it was fine, or is XPS different from EPS?
As soon as I finish my DIY mini compressor I'll start SharpieSpray experimenting.
Old Nov 12, 2012, 05:52 PM
acetech09's Avatar
Joined Apr 2012
It's both PS, polystyrene.
I don't know if it's sharpie specifically, but I've tested both black and silver sharpie on some depron, and it melted it. Just try on some scraps and see.
Old Nov 12, 2012, 07:35 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
I thought E and X both meant EXpanded, the piece of XPS I coloured a week back using a Brand X CD marker pen is till fine, I wonder if CD marker pens have a different chemical makeup so that they don't damage CDs (or PS foam).
Old Nov 12, 2012, 07:40 PM
acetech09's Avatar
Joined Apr 2012
Probably.
Old Nov 13, 2012, 04:08 AM
Raj Quest is offline
Find More Posts by Raj Quest
Joined Aug 2004
Originally Posted by midelic View Post
Raj,
How do you stick the canopy to the wooden arms?It is not clear from the photo.
midelic
please see these pictures - I think they are self explanatory....
Hope this helps....
And AUW = 30gms
Yes motors are 7x16 aliexpress
Raj Quest is offline Find More Posts by Raj Quest
Old Nov 13, 2012, 04:18 AM
Joined Aug 2004
Originally Posted by djdavies83 View Post
Looking good Raj!
I've had another idea for frame and/or motor mounting....
............ I'm thinking about also making a PCB as a frame.
dj....
I thought of the fuse holder too, but couldn't figure out how to fix it to the boom ... and also wasn't sure of the weight.
Do post a pic when you try it out. I'd certainly would like that detail.
I'm not a frequent flyer, so some day I don't wan't to pull out my quad and find that all elastic bands have gone soggy!!
PCB Frame would be a fantastic think to do...
Hope you get it done soon.
R
Old Nov 13, 2012, 04:24 AM
midelic's Avatar
Joined Apr 2012
Raj,
I'm impressed.Interesting ideea.
I get it.I have 7x20 mm motors.It weighs more than 7x16 motors.
Old Nov 13, 2012, 04:29 AM
mystman is offline
Joined Jan 2012
Raj,
But they also have more power for lifting.
Old Nov 13, 2012, 04:30 AM
Joined Aug 2004
Just For Records::::
1) All 4 motors together produce a static thrust = 34gms with a freshly charged Lipo
2) Each 7x16 (The one I got from Aliexpress) Motor Draws about 0.75A current at full throttle
3) Each Motor (My Aliexpress) Weighs = 2.45gms
4) With a 300mAh battery, run time is around 10 mins (simple flying)
5) Each Ladybird prop is 55mm dia & weighs 0.26gms
6) Take off is at approx 60% of throttle
Old Nov 13, 2012, 04:36 AM
Joined Aug 2004
has anyone noted the weight of a hollow cup 7x20 motor?
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 174 Jul 29, 2015 11:25 AM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
