Old Sep 27, 2012, 01:24 PM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Pulse witdth=1-2 ms with 20ms cycle =50hz........400hz =2.5ms.... but it needs to keep standard pulse width max 2ms ....so only 0.5ms between pulses.
Vey nice explanation here.
http://wiki.openpilot.org/display/Doc/TurboPWM
midelic is online now Find More Posts by midelic
Old Sep 27, 2012, 01:25 PM
bigtruck169 is offline
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
can't believe someone actually build and fly this little guy. thanks for thread.
bigtruck169 is offline Find More Posts by bigtruck169
Old Sep 27, 2012, 01:47 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
by any chance they made a board for spektrum radio? urs look promising, with $18, really can't beat that.
hope you dont mind a reply here because i have pm overflow problems.
the horizon mqx contol board is dsm compatible but costs around $36 which is more than enough to buy a couple v939 boards and a compatible radio and have money left over. however if you want to do that this thread shows how to put an mqx board in a ladybird frame:
http://www.rcgroups.com/forums/showthread.php?t=1647401
i think you can save a lot of money by using that board in a diy frame like mine and end up spektrum compatible.
dave1993 is offline Find More Posts by dave1993
installerblizz is offline
Find More Posts by installerblizz
This is a hobby. READ UP!!!!!!
installerblizz's Avatar
United States, FL, Bradenton
Joined Jun 2012
Noob question - motor amp draw must be less than what the ESC can put out, right?
OK so this motor: http://www.hobbyking.com/hobbyking/s...er_7700kv.html
This ESC:
http://www.hobbyking.com/hobbyking/s..._ESC_3_5A.html
But which prop? GWS 5030 is only comes as one direction.
installerblizz is offline Find More Posts by installerblizz
Old Sep 27, 2012, 01:52 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
yes, you are right. the 400hz jesolins mentions are only available with special high speed i2c and spi protocols. not possible with servo pwm. i think 4ms/250hz is the fastest for most servos and escs. even then it causes trouble with some and i vaguely recall having to drop down to 8ms/125hz for compatibility reasons.
Old Sep 27, 2012, 02:00 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Dave,
Yes I am speaking of PWM update rates form the FCB to the ESC which then has to properly handle that rate, so 400hz or 2.5Ķs. From my large multicopter experience multicopters just start flying OK at about 200hz update rates in no wind conditions. However there is definitely a positive improvement in flight performance stability in wind of 10-15kts with update rates closer to 400hz or above. Examples of multicopters that are top of the line in stability and performance that use even higher ESC update rates are the Mikrokopter and the Astec multicopters. The MK uses 500hz I2c ESC update rate. The Astec designs use I2c ESC update rates of 1khz. They are the ones you see in the now famous University lab videos.
The standard PWM ESC CopterControl, Mutiwiicopter, Kapteinkuk, Autoquad AQ6, and UAVX32 all use 400hz PWM update rates or higher, which is also configurable in some of their setups, for the best stability performance in wind too. The Simonk ESC firmware makes this possible in off-the-shelf ESCs as well as making them multicopter friendly by turning off LVC and making the throttle linear with no smoothing, etc. The Bill Nesbit AutoQuad ESC32s that are designed specifically for standard PWM multicopter use start at 400hz update rates.
I know...in my mind the physics of it is like measuring with a micrometer(gyros and accelerometers) and marking with a grease pencil(FCBs) than cutting with an axe(ESCs/motors/props) ..but operationally does increase multicopter flight performance.
ESC update frequency thread
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by dave1993 View Post
if you mean frame rate iirc its 4ms (250hz). from my experience with full size multicopters there is little practical difference between 200hz and 400hz anyway. even the 50hz of standard rc radios performs ok in most cases. many will dispute this. few unmodified esc and servos work at those speeds and they are its intended use so no extreme rates here. its designed to work with off-the-shelf components but of course will work with those hotrod flashed escs too.
jesolins is offline Find More Posts by jesolins
Old Sep 27, 2012, 02:03 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
This ESC:
this cw/'ccw thing is a problem. in any case im sure a gws 5030 will burn up that motor and the esc too. even 3" is pushing it imo. also dont forget that bigger props will draw HUGE current and youll need a really big battery. i think the props we use here are best choice for that motor. the 1mm hubs fit that 1mm shaft perfectly. and they are available cw/ccw and cost 20 cents instead of a buck.
Old Sep 27, 2012, 02:09 PM
Joined Jun 2012
Ah crap I meant 3020. That's what is recommended according to HK. It also says 36g thrust. How much less would we get with the ladybird props?
Old Sep 27, 2012, 02:20 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
first of all i think you have to stop believing these chinese ad specs. iirc the best you can do reliably with that combo is 24g. and mine got REALLY hot even at that point. i havent actually tried these props on those yet so not sure but im guessing 15-20 grams? its really not how much thrust you can get but how much you can get reliably for reasonable duration w/o cooking the windings. since i am going to dig out the bl motors and escs to check that converter i might as will hook up the test stand too. ill try to anyway.
Old Sep 27, 2012, 02:23 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Maybe this 5g inrunner (1mm Shaft) for $5.99 (free shipping) could be interesting for the brushless project :
http://www.aliexpress.com/item/Free-...581262389.html
mystman is offline Find More Posts by mystman
Old Sep 27, 2012, 02:28 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
Originally Posted by jesolins View Post
Dave,
its been couple years since i played with the big ones so maybe they have decided to 400hz pwm is ok after all. i thought back then most reflash was for i2c or spi. i know my kk controllers do not produce anything close to those rates. no matter what these are not an optrion here where we want to use off the shelf components like the hk 1g esc. and you can always use a high rate esc with low rate fc but not the other way around.
since ive actually spent very little time flying these i will definitely assume you know what your talking about regarding wind etc.. for me staying up for 60 seconds w/o smashing the fame to pieces was a major accomplishment.
Old Sep 27, 2012, 02:34 PM
Joined Dec 2009
i haven't read through the whole thread. by any chance u find any board that can use spektrum radio? thanks for the least expensive toy. mike
Old Sep 27, 2012, 02:37 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
Old Sep 27, 2012, 02:44 PM
jesolins is offline
Joined Feb 2007
Dave,
Yes and if the HK 1g ESCs use an ATMEL processor and we can get to the pins, we might be able to interest Simonk in assisting us with proper multicopter firmware
Probably a bit off-topic in this great $18 scratch build quad thread, but here is a good example of what high PWM udate FCB/ESC rates and a well designed and coded multicopter can do today..in case you might have missed it
Autoquad v6.6r19 Position Hold in gusty and turbulent breeze. (2 min 45 sec)
Cheers,
Jim
Old Sep 27, 2012, 02:45 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
that is a pretty good deal. i hate to think what i paid for my 1st hk 5g motor. and only $4.79 for ten. and that 1mm shaft is very attractive. hmmmm...
Build Log Lets Build a DIY FPV Spider Quad Together Nick_P Scratchbuilt Multirotors 174 Jul 29, 2015 11:25 AM
Sold DIY Open Pilot CC micro/mini quad BNF for sale Hamanu Aircraft - Electric - Multirotor (FS/W) 4 Aug 03, 2012 07:29 PM
Discussion Any good premade DIY Centre plate for AP Quad? redblur Multirotor Talk 2 Jun 24, 2012 08:10 PM
Discussion DIY Quad Frame hits snafu... srs5150 Multirotor Talk 5 Apr 30, 2012 10:46 AM
Discussion Looking for a good DIY guide for a 450 sized Quad nige838 Multirotor Talk 2 Apr 28, 2012 02:44 AM
