Old Sep 09, 2012, 06:37 AM
Stuart Warne is offline
Find More Posts by Stuart Warne
Durafly Brand Manager
Stuart Warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
Good so where collectively making some progress then
S.
Stuart Warne is offline Find More Posts by Stuart Warne
Site Sponsor
Old Sep 09, 2012, 07:46 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Well folks, 50mm for me is the magic number.
Did the maiden today and only about four clicks all around and she made ME look like a good pilot.
50mm from leading edge{most outer side of wear wing fits with fuse}, GO TO HER BOYS.
Limited flyer is offline Find More Posts by Limited flyer
Old Sep 09, 2012, 08:11 PM
Joined May 2001
Good news indeed. Just a note for all out there. I'd recommend putting some thread lock on the motor mount screws, just to be on the safe side. On the Beta 1 version of the model one did works itself loose, so might be worth considering.
S.
Site Sponsor
Old Sep 09, 2012, 08:45 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Longer aileron& flap cables please!
Not sure if anyone mentioned this yet, the aileron and flap servo cables are a bit short and should be lengthened for later production runs,, they need to be slightly longer, especially since some of us are actually setting up the Walrus properly as a fullhouse sailplane, with separate channels for each of the aileron and flap servos, but the cables are too short to fish through the fuselage and then need a short extension to be able to position the receiver in the fuselage, so I had to provide myself 4 servos extensions. Finished setting up my Walrus today, on my Futaba 9CHP Super, with a 7 CH receiver, so I have full 7 channels, with fully cambered trailing edge, and mixed flaps to ailerons for enhanced roll response, and of course Crow Landing for precise spot landing even in tight spaces.
Doubletap is offline Find More Posts by Doubletap
Old Sep 09, 2012, 11:32 PM
Limited flyer
Joined Dec 2011
Mind telling the group here where you position your rx.
Don't really like the configuration i am using now.
How about the rest of you?
Old Sep 10, 2012, 01:10 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
S.
I did thread lock mine.
LF - Thank you for the 50mm - (is this at the servo wire slots?)
DT - This is a new one on me "mixed flaps to ailerons for enhanced roll response". I am intrigued.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Sep 10, 2012, 02:03 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Spar Joiner Dimensions
To me the spar joiner feels easy to break.
I'm looking over the solid rod
and grab both ends and give a breaking motion with it.
It audibly cracks fairly easily.
I have doubts it's carbon.
Mearsurements for replacement of spar joiner:
Small rod - 5.5mm OD 300mm L (just shy of 1 ft) - This fits inside the wing spars.
Larger center spacer rod - 8mm OD 20mm L (3/4") - Fits over above small rod, centered and glued. This center piece is probably made from a piece of wing spar.
Wing Spar Length - 482mm - 19 in.
I assume the spar ID is 6mm. The joiner flops around in it pretty good.
It appears the spar OD is 8mm. I can't get directly on one to measure.
Here's some solid 5.5mm carbon rod I found and need to order.
http://www.rcfoam.com/product_info.p...5cc12cf7910834
Here's a 8mm hollow rod with 6mm ID:
Is there such a thing as 5.5mm arrow shafts? just curious... this joiner looks like fiberglass rod to me.
NOTE: If you look under your wing and see the slots at each end running front to rear, that is the end of each spar.
Old Sep 10, 2012, 02:22 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Spar Reinforcement
The 5.5mm Solid rod sold above is 39" long.
The wing spars are 19" long.
19 + 19 = 38" + 1" center spacer =39"
Instant full length spar reinforcement!
Just glue a center spacer in place in the middle of the 39" rod.
WELL DUH!
You should not need the center spacer at all with the full length rod.
All it's for is to keep the short wing joiner from dropping into the wings.
TRUE?
Old Sep 10, 2012, 04:55 AM
Doubletap's Avatar
Joined Jul 2005
Yeah, this is fairly standard with sailplane setups, with this mixing , the entire trailing edge moves for roll control
Old Sep 10, 2012, 06:10 AM
sterob is offline
Find More Posts by sterob
Australia, WA, Collie
Joined Aug 2012
I pushed my Rx back behind the rudder and elevator servos. Not really happy with it but its out of the way...a bit.
I was going to velcro it down but I can't reach back there to fit the hooks.
Steve
sterob is offline Find More Posts by sterob
Old Sep 10, 2012, 07:49 AM
Joined May 2001
Steve
That's exactly what I did, no problems and it was as far away from the ESC as possible.
S.
Site Sponsor
Old Sep 10, 2012, 08:55 AM
Limited flyer
Joined Dec 2011
Steve
Good idea, thanks for that.I think i migh have a soloution for the not getting it stuck down part .Get your stuff plugged into your rx, apply the supplied velcro{or what ever you use},but you gotta put both bits of velcro on at the same time with the peel and stick part removed,grab a long set of neddle nose pliars, find the spot where you want it and press firmly with the tips of the pliars to ensure adhesion from velcro.
Sorry for going on
Limited
Old Sep 10, 2012, 11:29 AM
Buck Shot is offline
Find More Posts by Buck Shot
Joined Apr 2012
Three weeks today and still No Batteries from China!! If it goes much longer I will have to put Skis on the Walrus!!
Buck Shot is offline Find More Posts by Buck Shot
Old Sep 11, 2012, 05:49 AM
sterob is offline
Joined Aug 2012
Sorry for going on
Limited
Lateral thinking...I like it.....lol
Discussion Hobby King 2.1 FC and Hexcopter in y6? Need Help... g00bd0g Multirotor Talk 3 Nov 05, 2015 08:12 AM
Sold Submarine 1/60 Walrus w/ D&E 3.5 WTC BrittB Boats (FS/W) 1 Mar 29, 2012 06:16 PM
Sold (1) Hobby King 5A Balance Chargers rdcskkrose Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 18, 2012 01:36 PM
New Product Hobby King P-38 1.4m minirips2 Electric Warbirds 0 Sep 23, 2010 12:09 PM
