Old Aug 30, 2012, 07:55 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Was putting mine togeather today, was binding my ar 600 to it and when i plugged in the battery i got a solid light{should be blinking when ready to be bound}, so i thought i did something wrong, i quickley dissmissed that thought when i thought to my self, ar 600s are all i run, so i know i did'nt do any thing wrong, which is when i discovered, one of the motor leads to the esc{bullet connector}was snapped at the solder joint, so watch out for that folks.
You have been warned.
Limited flyer is offline Find More Posts by Limited flyer
Old Aug 31, 2012, 07:21 AM
sterob is offline
Find More Posts by sterob
Australia, WA, Collie
Joined Aug 2012
Walrus instructions
Hi, I bought one of these but didn't get any instructions with it. Its all pretty self explanatory, but one thing I'd like to know is where the C of G is ?
If some one could post that for me it would be fab.
Anything else I should be aware of?
Steve
sterob is offline Find More Posts by sterob
Old Aug 31, 2012, 08:48 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
71mm (edit: INCORRECT? in manual)
And nothing else special...
Good luck on your maiden!
What are your plans to keep the battery from being able to shift around in the cavernous fuse? I'm thinking of gluing a foam block or 2 in it.
IFlyRCs is offline Find More Posts by IFlyRCs
Last edited by IFlyRCs; Sep 09, 2012 at 02:07 AM. Reason: later finding out manual is wrong
Old Aug 31, 2012, 02:15 PM
Buck Shot is offline
Find More Posts by Buck Shot
Joined Apr 2012
Walrus just swam through the door!! Gave it a through inspection and it looks great!! Took 11 days to get here. Now I know why they call it a Walrus! It is Big and Fat, but Beautiful and needed a home!! I'm Happy BUCK
Buck Shot is offline Find More Posts by Buck Shot
Old Aug 31, 2012, 02:18 PM
Stuart Warne is online now
Find More Posts by Stuart Warne
Durafly Brand Manager
Stuart Warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
Re: the battery I used a turnigy 2650 3s lipo in my one. It fitted very snugly between the elevator and rudder servo's, so much so that no velcro or tape was needed. Never had a problem with it shifting. The model will happily take the extra weight over a 2200 and you'll get longer flight times. That being said, with a 2200 3s, velcro alone will be fine. CG with the 2650 3s is basically on the spar, if a fraction forward of it.
S.
I'll see if i can get the instructions uploaded to the product page for future reference.
Stuart Warne is online now Find More Posts by Stuart Warne
Site Sponsor
Old Aug 31, 2012, 04:10 PM
Limited flyer
Joined Dec 2011
Be careful of stretching that foam,it will get looser in time.
Old Aug 31, 2012, 06:53 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
and the white folding prop blades kinda look like a couple of tusks when handing down.
Doubletap is offline Find More Posts by Doubletap
Old Aug 31, 2012, 10:53 PM
sterob is offline
Joined Aug 2012
Originally Posted by IFlyRCs View Post
71mm
Thanks for that. I haven't got that far yet. Will probably use a lot of velcro even if it is a snug.
Steve
Old Sep 01, 2012, 08:45 PM
sterob is offline
Joined Aug 2012
Can someone post the recommended throws of the control surfaces and the pitch of the prop. ( measured it as 9" dia. )
Steve
Old Sep 02, 2012, 01:19 AM
Joined May 2001
These are the daul rates and expo settings I have for my Walrus on the DX8 with all surfaces set to neutral:
Ail:
Pos 2 (low rates), D/R 45% EXPO 15.
Pos 1, D/R 60% EXPO 20.
Pos 0 (high rates), D/R 100%, EXPO 25
ELE:
Pos 2 (low rates), D/R 60% EXPO 15.
Pos 1, D/R 85% EXPO 20.
Pos 0 (high rates), D/R 125%, EXPO 25
RUD:
Pos 2 (low rates), D/R 70% EXPO 15.
Pos 1, D/R 95% EXPO 20.
In low rates the response is ideal for anyone learning to fly IMO, though some may find it a little too unresponsive for there liking. Mid rates (Pos 1) is a good 'standard' setting, and high rates are ideal if you want to be able to chuck her around a little.
hope this helps.
S.
Site Sponsor
Old Sep 02, 2012, 08:56 AM
sterob is offline
Joined Aug 2012
Thanks Stuart. A great help.
Old Sep 03, 2012, 08:29 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Anyone have tested flap rates and mixing?
Old Sep 03, 2012, 12:31 PM
Joined May 2001
I have my flap rates and servo speeds if that helps, but I don't think I used any mixing.
S.
Site Sponsor
Old Sep 03, 2012, 07:44 PM
Joined Apr 2012
Servo Arms??
Almost finished the Walrus. Having a problem with the controls. The servo arms lay flat in the wings so I can't hook the rods to the controls. Do I have to hook up the radio to get the arms to stick out of the wing?? I assume they are like that for shipping. Thanks Buck
Old Sep 04, 2012, 12:24 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Yes, when you apply power, the arms will center themselves.
Discussion Hobby King 2.1 FC and Hexcopter in y6? Need Help... g00bd0g Multirotor Talk 3 Nov 05, 2015 08:12 AM
Sold Submarine 1/60 Walrus w/ D&E 3.5 WTC BrittB Boats (FS/W) 1 Mar 29, 2012 06:16 PM
Sold (1) Hobby King 5A Balance Chargers rdcskkrose Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 18, 2012 01:36 PM
New Product Hobby King P-38 1.4m minirips2 Electric Warbirds 0 Sep 23, 2010 12:09 PM
