Portugal
Joined Feb 2011
Maiden flight of Walrus
This glider is really nice for is value. The stock power is enough for all basic stunts. The flaps helps a lot for land in small areas. I also made a video of the flight, hope you like
Happy landings, G.Santos |
I have seen many fly this like a conventional plane ,but how about catching a thermal what are its characterisics then ?,
it looks good to me I have examined one closely and would only add a bit of carbon fibre flats strips along the inside of the cockpit sides right up and attaching to the motor mount , I havent looked closely at the motor used but if its like many others I would probably use something else that would swing a 10" to 12" folder at slower revs. I havent checked the folder hub diameter to see if any of the turbo vented HK folder hubs could be used, personally I dont like plastic folder hubs I have had them throw blades in the past, the german ones are an exception but the choice of plastics used in a lot of chinese products are suspect.imho.
Latest blog entry: For motor builders
and with a hobby knife cut away the heat shrink to expose the chips and glue rails along the sides to allow some air to keep the chips cool , I have in the past glued (heatsink adhesive) a long copper foil to those chips and cut a slot so that the foil can be attached to the outside of the fuselage. most ESC regulator chips are rated at 3 amps into a (theoretical)infinite heatsink, I have cut open a few that claimed to be 5 amp and checking the spec sheet only to find they were 3 amp.
Perth, Western Australia
Joined Jan 2010
setting the brake
Hi All,
Love my Walrus. However I am having problems with setting the brake on the ESC. Initially it was set. Somewhere along the line it seems to have changed its mind and now the prop windmills so I need to know how to set the brake back on. My esc is unlabelled, covered in black heat shrink and has no cooling fins. If anyone can tell me how to set the brake I would be appreciate it. |
Italy, Toscana, Orbetello
Joined Mar 2012
@MikeRobey42:
Switch on the radio tx. Set throttle on the radio to maximum. Connect the battery to the ESC; You'll ear a series of five "BEEP", then set throttle to minimum. Disconnect battery from ESC. Now You ESC has the brake on. If You want to set it off, do the same again.
Joined Jan 2010
from the initial bind I got the brake on simply by reducing few points the throttle trim. ciao. |
Thanks for the heads up, I ordered a replacment, here is the link
http://www.hobbyking.com/hobbyking/s...inner_Set.html |
| Thread Tools | |
| Discussion Hobby King 2.1 FC and Hexcopter in y6? Need Help... | g00bd0g | Multirotor Talk | 2 | Apr 11, 2012 12:17 AM |
| Sold Submarine 1/60 Walrus w/ D&E 3.5 WTC | BrittB | Boats (FS/W) | 1 | Mar 29, 2012 06:16 PM |
| Sold (1) Hobby King 5A Balance Chargers | rdcskkrose | Aircraft - Electric - Batteries & Chargers (FS/W) | 5 | Mar 18, 2012 01:36 PM |
| New Product Hobby King P-38 1.4m | minirips2 | Electric Warbirds | 0 | Sep 23, 2010 12:09 PM |
