Old Oct 20, 2012, 05:41 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Walrus Help
I've spent a lot of money at HK [please don't tell] and have always had good products delivered. My Walrus ESC went pear-shaped and I contacted them. All they needed was a vid of the funny stuff the ESC was doing and they gave me the appropriate points for my next purchase. [As I had requested, BTW]
I did not have to mail the faulty unit. It was a $6.00 or so item so I would have just trashed it and ate the loss. Thanks HK, Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Oct 21, 2012, 02:08 PM
Krycek W is offline
Find More Posts by Krycek W
Krycek W's Avatar
Canada, QC, Montreal
Joined Jun 2012
Originally Posted by Doubletap View Post
WOW! Walrus maidened, exceptional performance and value! Finally got a chance to maiden my Walrus,it is stock except for the addition of a 5A Switch mode BEC, and one wing servo was replaced immediately as the original servo was defective. My Walrus is setup as a 7 channel, 4 servo wing sailplane, the stock power system with 3S 2200mah lipo has ample power with no evidence of ESC overheating with external sbec, my maiden flight was flawless with all components landed with only slight warmth, although my7 minute flight consisted of mostly 3/4 to full throttle hard aerobatics, and the Walrus will do happily anything you throw it, yet, it comes slow and steep when full crow is deployed for a near pinpoint landing. BTW, the roll rate with mixed full span trailing edge ailerons is awesome, my Walrus does axial rolls in a blink of the eye with no elevator compensation needed.
Good for you! I'm waiting for more than one week to maiden mine. Here snow will come soon but now it's rainy and windy! 3 week-end back to back
Where did you set your CG?
Mine is on the wire channel, 3-4mm forward from the manual CG(71mm), so it's at 67-68mm from the location according to the picture in the manual.
Krycek W is offline Find More Posts by Krycek W
Old Oct 21, 2012, 02:16 PM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
... My Walrus is setup as a 7 channel, 4 servo wing sailplane[...] it comes slow and steep when full crow is deployed for a near pinpoint landing.
I plan to program CROW too, I will use my DX7s, in the 6 channels mode (2 channels for the aileron, one for each).
Somebody have the "CROW" program for a DX7s?
Old Oct 21, 2012, 08:18 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
My CG is right around the servo wire channel also, but depending on which pack I use, it can be a few mm behind,
Doubletap is offline Find More Posts by Doubletap
Old Oct 21, 2012, 08:22 PM
Doubletap's Avatar
Joined Jul 2005
Try asking in the radio forum, or the electric sailplane forum for DX7 programming for crow:
http://www.rcgroups.com/radios-135/
http://www.rcgroups.com/electric-sailplanes-19/
Old Oct 22, 2012, 08:34 PM
Cajin_Rye is offline
Find More Posts by Cajin_Rye
Friend of Bill's
Joined Oct 2012
My Walrus is on it's way. I am returning to the hobby so I would like advice.
I'll be using it as an advanced trainer. Have DX6i, plan on incorporating CROW for the 6th channel.
Just want a rock solid ship, so I am thinking of installing a
Turnigy dlux 30A SBEC Brushless Speed Controller w/Data Logging (2s~4s).
Any thoughts or suggestions? Thanks Wayne
Cajin_Rye is offline Find More Posts by Cajin_Rye
Old Oct 23, 2012, 02:46 AM
ainslorn is offline
Find More Posts by ainslorn
Joined Oct 2012
Yes it has a carbon fibre spar. Flew mine yesterday and goes like a dream very stable and flaps make it a breeze to land at a very slow speed. A great model
ainslorn is offline Find More Posts by ainslorn
Old Oct 23, 2012, 02:52 AM
ainslorn is offline
Joined Oct 2012
I have CG at around 60 mm not 71 as per book. Thermals great too. Just the right size to leave assembled cannot fault for a foamy.
Old Oct 23, 2012, 07:00 AM
sterob is offline
Find More Posts by sterob
Australia, WA, Collie
Joined Aug 2012
Great stuff. Glad you like it. I am happy with mine too.
Just curious, are you mixing any elevator in with your flaps and rudder with the ailerons?
sterob is offline Find More Posts by sterob
Old Oct 23, 2012, 08:51 AM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Trimming
There is a great deal of info about trimming and "C of G" placement available.
Just Google: Trimming RC Gliders Most sites agree that the box stated point of balance is too far forward for good performance.
Tex.
Old Oct 23, 2012, 11:41 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Tex.
Aren't these contradictary?
What is the best Visual reference point for CG guys?
I'm finishing setting mine up this week.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Oct 23, 2012, 12:15 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Originally Posted by IFlyRCs View Post
Aren't these contradictary? [sic]
Not at all. A nose-heavy plane will thermal, an optimally balanced one will thermal better. Tex.
Old Oct 23, 2012, 12:27 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Everyone is giving measurements moving the cg point forward but you're saying stock is too far forward.
Old Oct 23, 2012, 12:52 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Here's the thing: This plane is very stable at stock balance. It's a given that moving the balance point rearward improves efficiency. Of course you can move it back to a point where it becomes unstable, and difficult to control,but that's a different discussion.
You realize that any nose-heaviness requires up some elevator deflection adding a down force on the plane, in effect adding load. A slightly tail heavy plane requires a downward deflection of the surface in effect adding to total lift. Both of these situations add drag. So we should aim for a neutral position of the stab/elevator for least drag and reasonable wing loading.
You might like the way the nose-heavy plane flies. It would be stable, for sure, but for best efficiency you should ease the balance point rearward as much as possible keeping the plane enjoyable to fly.
The above is very simplistic and not meant as the last word on trimming. Tex.
Old Oct 23, 2012, 01:52 PM
Krycek W is offline
Krycek W's Avatar
Joined Jun 2012
Just for the record... I find my answer here:
http://www.rcgroups.com/forums/showt...434584&page=59
My Walrus with CROW, Flaps and mix aileron-rudder (for test) is ready for is maiden flight!
Discussion Hobby King 2.1 FC and Hexcopter in y6? Need Help... g00bd0g Multirotor Talk 3 Nov 05, 2015 08:12 AM
Sold Submarine 1/60 Walrus w/ D&E 3.5 WTC BrittB Boats (FS/W) 1 Mar 29, 2012 06:16 PM
Sold (1) Hobby King 5A Balance Chargers rdcskkrose Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 18, 2012 01:36 PM
New Product Hobby King P-38 1.4m minirips2 Electric Warbirds 0 Sep 23, 2010 12:09 PM
