Old Oct 01, 2012, 01:52 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
I'm finding it difficult to hook up the wing wires to those dinky "Y" leads. And just how do you hide all that wire in order to get the wings together?
I did a short run of the motor to check things out and the ESC did get too warm IMO. I cut the plastic off the heat sink side in hopes it will help. More cooling air is a definite requirement, both in and out venting is needed. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Oct 01, 2012, 02:41 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Further to the above, after much fiddling, I got the wing mounted. Then slid the tail bits in. Nice fit. But check the picture of the alignment. This is just not good enough! Below average to P poor. Tex.
Old Oct 01, 2012, 03:00 PM
Buck Shot is offline
Find More Posts by Buck Shot
Joined Apr 2012
Originally Posted by sabrejock View Post
further to the above, after much fiddling, i got the wing mounted. Then slid the tail bits in. Nice fit. But check the picture of the alignment. This is just not good enough! Below average to p poor. Tex.
sad! Just sad!!!
Buck Shot is offline Find More Posts by Buck Shot
Old Oct 01, 2012, 03:35 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Well, the fix for the rotten tail alignment was easy. Just like I used to do with sheeted built-up wings when a warp developed. I put two longitudinal slits in the bottom of the fuse, right through the foam, from just behind the wing back to the tail. By twisting the fuse it comes back into alignment easily. I rubbed carpenter's glue into the slits and taped the fuse in the correct position.
But we shouldn't have to do this! Tex.
Old Oct 01, 2012, 04:03 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
There's a pic on the previous page of an identical twist!
http://www.rcgroups.com/forums/showp...&postcount=161
IFlyRCs is offline Find More Posts by IFlyRCs
Old Oct 01, 2012, 05:08 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
[QUOTE=IFlyRCs;22885699]There's a pic on the previous page of an identical twist!
They've got a big problem here. But at least the fix is simple and easy.
Flew mine briefly this afternoon. Very stable. I put a 1300 3s right up in the nose and it balances on the wires. It's a glider so doesn't need a lot of power-on endurance, just a few climbs. Tex.
Old Oct 01, 2012, 06:18 PM
Krycek W is offline
Find More Posts by Krycek W
Krycek W's Avatar
Canada, QC, Montreal
Joined Jun 2012
Very interesting method! Do you have pictures of the whole process? I'm not sure I figure it out correctly
Krycek W is offline Find More Posts by Krycek W
Old Oct 01, 2012, 06:41 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
I don't have pics, but there really isn't much to see. If yours is twisted be gutsy and just make a slice or two down the belly, mine are about an inch apart either side of the construction join. Slice right through the foam. Make them as straight as possible.You'll find that it twists straight very easily.
I used the carpenter's glue because it gives you time and the excess wipes off with a damp cloth/paper towel. Tex.
Old Oct 01, 2012, 07:00 PM
Joined Apr 2012
i don't have pics, but there really isn't much to see. If yours is twisted be gutsy and just make a slice or two down the belly, mine are about an inch apart either side of the construction join. Slice right through the foam. Make them as straight as possible.you'll find that it twists straight very easily.
genius!!!
Old Oct 01, 2012, 08:12 PM
Hz42 is offline
Find More Posts by Hz42
Hz42's Avatar
Joined Sep 2005
Nice! Thank you.
En garde!
Hz42 is offline Find More Posts by Hz42
Old Oct 01, 2012, 08:27 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Air Intake
FWIW, here's my treatment of the lack of cooling air. The outside is a "sorta NACA" style duct which is situated right in front of my ESC. Notice that I cut the plastic insulation from the heat sink as I always do. Why they put a heavy chunk of plastic over it I'll never figure out!
Now if we could only get the prop to stop with a brake. Tex.
Old Oct 01, 2012, 09:41 PM
Joined Apr 2012
The intake is nice. Is it on both sides? How are you venting it??
Old Oct 02, 2012, 12:20 AM
Stuart Warne is online now
Find More Posts by Stuart Warne
Durafly Brand Manager
Stuart Warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
Twist noted, this is the first I've seen of it, certainly none of our production samples had it. Fortunately I have a sample taken from stock this week that I'm going to be putting together this afternoon (I brought it for my wife to learn to fly on) and I'll be sure to check for this issue. I can also confirm the prop size.
Sabrejock, I am sorry that you had this problem, but am happy that you where able to fix it with ease and it flies well for you, she is rock solid isn't she.
S.
Stuart Warne is online now Find More Posts by Stuart Warne
Site Sponsor
Old Oct 02, 2012, 05:42 AM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Buck: I just put the intake on the one side in front of the ESC. I enlarged and shaped the existing exit hole.
Stuart: It seems I'm not the only one with the poorly aligned tail bits. See previous poster Hz42 at #161. Tex.
Old Oct 02, 2012, 06:56 AM
Joined Apr 2012
What exit hole??
Discussion Hobby King 2.1 FC and Hexcopter in y6? Need Help... g00bd0g Multirotor Talk 3 Nov 05, 2015 08:12 AM
Sold Submarine 1/60 Walrus w/ D&E 3.5 WTC BrittB Boats (FS/W) 1 Mar 29, 2012 06:16 PM
Sold (1) Hobby King 5A Balance Chargers rdcskkrose Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 18, 2012 01:36 PM
New Product Hobby King P-38 1.4m minirips2 Electric Warbirds 0 Sep 23, 2010 12:09 PM
