Old Sep 23, 2012, 09:42 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Originally Posted by mstopps View Post
That is too bad and I was really looking forward to your review of this plane. I got the ez trainer 1280 after reading the ez style thread when I saw you liked it so much but I am now looking for something more aerobatic and faster. I was thinking about the axn clouds fly, bixler 2, this, or dynamic s.
I haven't flown my Walrus yet but,
B2 is bigger and perhaps not very sporty.
Dynamic S is a lot of plane. But a good plane. Look at the Blaze at Tower too.
A clipped wing Clouds Fly (Floater Jet) may be a winner.
Even a stock clipped wing Bixler would be nice.
Then there's lots of other options.
I enjoyed my RxR Super Sportster from Tower.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Sep 24, 2012, 12:08 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Actually there is no reason to "change" the existing ESC for those who already have the model, all you need to do is install a separate switch mode BEC to bypass the integrated BEC on the ESC.I'm sure that the stock 20A ESC itself should be just fine for the motor/prop/battery combination, that's why I didn't replace the ESC, I just added the external switching voltage regulator to provide 5V power to the radio equipment, that's all.
Doubletap is offline Find More Posts by Doubletap
Old Sep 24, 2012, 12:15 AM
Doubletap's Avatar
Joined Jul 2005
dynamic s.
It's not a problem, especially now that Stuart has announced that all Walrus will come with an uprated ESC, but an external BEC can be added to your existing ESC which will take care of the problem . I still think that the Walrus is a very nice full function but economically priced foam glider, as with all new designs there will be a period where kinks will be ironed out. I'll be performing the maiden in a few more weeks.
Old Sep 24, 2012, 10:32 AM
Buck Shot is offline
Find More Posts by Buck Shot
Joined Apr 2012
NO Problem?? Just finished mine. What are the first of us to do? Are we to fly it untill it catches on Fire or go out and buy a new ESC? They knew the ESC was Bad before they shipped the first ones! They cut the cover off of it to try to cool it! It is Sad when a Company as big as Hobby King uses its costormers for Reserch and Development!! It is nice they are changing it for it's New costormers. If they really give a D-m they would send the first costormers a New ESC!! Now I know why they say Never buy the first ones let them work out the bugs First !!! BUCK
Buck Shot is offline Find More Posts by Buck Shot
Old Sep 24, 2012, 11:52 AM
Krycek W is offline
Find More Posts by Krycek W
Krycek W's Avatar
Canada, QC, Montreal
Joined Jun 2012
+1 on that.
I had received mine more than a week ago, I just began to put it together last evening, if the ESC as a problem, HobbyKing have to send to his first customers a replacement ESC!
Krycek W is offline Find More Posts by Krycek W
Old Sep 24, 2012, 12:07 PM
Stuart Warne is offline
Find More Posts by Stuart Warne
Durafly/Avios Brand Manager
Stuart Warne's Avatar
Australia, NSW, Sydney
Joined May 2001
I have already explained the mix up with the ESC and that the example we saw in the final product sample was not, it seems, the same esc that went out to the first batch of customer, so I'm not going to go into this again.
I do however agree with the sentiment above and if indeed your ESC has actually failed, it should be replaced. I will follow it up with the guy's in the office in the morning regarding this.
S.
Stuart Warne is offline Find More Posts by Stuart Warne
Site Sponsor
Old Sep 24, 2012, 12:18 PM
Joined Apr 2012
S.
It should be replaced by whom?? What do you mean by failed?? Buck
Old Sep 24, 2012, 12:34 PM
mstopps is offline
Find More Posts by mstopps
United States, MO, Grandview
Joined Feb 2012
Stuart, if I order one that is in stock now will it still have the old esc? The description still shows 20amp. Also can you ask the guys at the office if there are plans to stock it in the USA?
mstopps is offline Find More Posts by mstopps
Old Sep 24, 2012, 12:44 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
There hasn't been an esc failure yet correct?
I think getting some airflow is going to be a big help.
STUART - Any word on prop size? replacement part?
Old Sep 24, 2012, 05:46 PM
Doubletap's Avatar
Joined Jul 2005
The original stock ESC current rating of 20A is just fine for this model with the stock power system. My watt meter shows that my stock Walrus will draw approx. 15.2A and generate 180W static using a freshly charged 3S 2200 mah lipo on WOT, which is well under the ESC continuous current rating of 20A. The issue has to do with the ESC's integrated linear BEC ability to supply 5v-6V to the radio equipment which includes all 6 servos without overheating. I found that isn't the case under the most extreme configuration, although most people will not setting up their Walrus like this where all 6 servos can/would be operating simultaneously and overload the built-in BEC, that's why, it is actually standard practice for modellers to bypass the integrated BEC when using a high performance control configuration installing a separate switch mode BEC which run much cooler when stepping down high voltage inputs from the battery pack.
If you only intend to fly the Walrus as a basic 4 or 5 channel model, you should be just fine with the stock 20A ESC with integrated BEC.
Old Sep 24, 2012, 06:01 PM
mstopps is offline
Joined Feb 2012
Thanks Doubletap that makes it more clear for me. I am pretty new to the hobby and I would definately like to be able to just "plug n play" as easy as possible and I have not yet learned about installing bec's or the various sailplane settings you mentioned but I am interested in someday. First I am going to order some servo extensions so I can set up flaperons on my et 1280 and flashing my 9x but I still have to learn exactly how to do all this stuff.
Old Sep 24, 2012, 08:19 PM
Joined May 2001
All Walrus's ordered from now will ship with a better ESC.
S.
Site Sponsor
Old Sep 24, 2012, 08:30 PM
Joined Apr 2012
S.
Great!! How about the first ones that bought one!! R&D Again??
Old Sep 24, 2012, 09:04 PM
Joined May 2001
I've just order a sample from the new batch, I'll be able to confirm when it gets here.
S.
Site Sponsor
Old Sep 24, 2012, 09:07 PM
Joined May 2001
@ BS.
Has your esc failed?
Site Sponsor
Discussion Hobby King 2.1 FC and Hexcopter in y6? Need Help... g00bd0g Multirotor Talk 3 Nov 05, 2015 08:12 AM
Sold Submarine 1/60 Walrus w/ D&E 3.5 WTC BrittB Boats (FS/W) 1 Mar 29, 2012 06:16 PM
Sold (1) Hobby King 5A Balance Chargers rdcskkrose Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 18, 2012 01:36 PM
New Product Hobby King P-38 1.4m minirips2 Electric Warbirds 0 Sep 23, 2010 12:09 PM
