Old Aug 12, 2012, 05:55 PM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Build Log
Cartoon Fokker DVIII
Despite my best efforts to stay focused on my Giant Eurofighter project for NEAT. Gordon's sweet looking Nieuport got me thoroughly distracted. So I've started a DVIII the in the same scale to do battle with his.
Started with a 3-view, and stretched/skewed untill it looked right (err wrong?) enough. It's about the same dimensions of a Vapor now.
Got the CAD done today, which was expedited by using the DRI plans as a starting point. Should start cutting once my microlite gets here.
Toying around with the idea of making a little cowl, to add a bit more personality.
-Adam
AJWoods is offline Find More Posts by AJWoods
Old Aug 12, 2012, 07:08 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Adam,
That looks nice. I like the poportions. I like the cowl. That's what I don't like about my Dr.1, it has no round cowl. Now you've got me thinking about whether I should try a similar cowl for my Nieuport, of which I have yet to do any cutting. I'm going to start with the wings and work from there.
Any ideas how you'd do the cowl? Laser it out and glue it in place?
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Aug 12, 2012, 07:18 PM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
Ah, I just finished cutting out mine!! I'm presently putting guts in it- Geared 4mm motor, HingeAct and Plantraco .38g RX.
The cowl looks lovely on yours- I'm going to add it to mine What size is yours going to be?
Pete P is offline Find More Posts by Pete P
Old Aug 12, 2012, 07:19 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
I was going to make it out of 2 layers of 3mm and 1 of 6mm, laminated, lasered to rough shape, then sanded down. Similar to how I did the bumblebee nose. I was going to do a few test in the next day or two and see how it comes out.
-A
Latest blog entry: F-Zero Hovercraft
Old Aug 12, 2012, 07:21 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Same length as Gordon's Fokker, but 14.75 span. I've only got one wing after-all
Old Aug 13, 2012, 05:18 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Cowl test
Tried making a cowl this evening. 3 layers of 6mm depron aero. The first two have a 6mm wall and the last makes the face. I tack glued it to the dremel cutoff wheel and spun it down to shape (although it probably would have come out fine hand sanded. Cut the bottom off at an angle and installed a dummy ply radial. Less than a gram right now, I think it'll add some real character to the plane.
-A
Edit: The radial came out a bit too large, but it sort of looks like buck teeth now...
Old Aug 13, 2012, 06:15 PM
Boston, Mass
Joined May 2001
-A
Adam,
Very nice. I'm looking forward to seeing how it looks installed on the profile fuselage. I did something similar about four years ago when I started (but never got far) on a DVIII with Fiddlers Green printed tissue graphics. I made a cowl similar to yours by spinning it down on my lathe. My intention, which I never did, was to make the lower part of the rotary engine by lasering Depron to get the grooves to simulate the fins, and then spray it with a combination of grey and black paint to get a more engine look. Jin did something similar with a dummy engine on his Sopwith Tripe kit.
It's too late for me to put a cowl on my Dr.1 (I think) but you've got me thinking about it for the Nieuport. I'm working on the top wing right now, and graphics are really slowing that down. So, I have time to follow your lead.
Grdon
Old Aug 15, 2012, 05:37 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Got all the parts covered and painted this evening. 6.1g for the airframe right now. This is a fun little distraction
-A
Old Aug 15, 2012, 07:59 PM
Boston, Mass
Joined May 2001
Adam,
Wow, that's progressing, and looks super!
The color scheme looks so cartoon.
Gordon
Old Aug 15, 2012, 08:17 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Thanks!. Your skinning/painting technique before cutting the outlines works great. took a little longer to set up the cut files, but it produced much cleaner results, particularly on the fuse.
As a PSA to those also building with RA Microlite. I was worried about the hard wrinkles in the covering that were left from it being packed in its little pouch. I tried a couple different methods including tensioning the covering on the building board and letting it rest for an hour or so, tensioning then lightly heating with a blow-drier, and tensioning and immediately positioning the part. All produced comparable results, with very little visible wrinkling.
TLDR: Just pull the covering taught on the build surface, 77 the part, and put it in place. Nothing special.
-A
Originally Posted by Gordon Johnson View Post
Adam,
Gordon
Old Aug 15, 2012, 11:04 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
Your Fokker DVIII is looking beautiful! I can't wait to see her fly at NEAT.
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Aug 16, 2012, 09:43 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Well done very cool
Pete
mtflyr is offline Find More Posts by mtflyr
Old Aug 17, 2012, 06:04 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
LG and other ply stuff done.
I'm currently debating whether to stick with the BSD motor/GB Gordon used on the tripe, or swap to the standard vapor setup. I've got a lot less wing than the tripe, and the difference (with the props I have on hand) comes out to almost 4g. I should also have much less drag, so for general cruising I think the vapor setup might be sufficient (I'll be about 2g over stock vapor weight if I don't use too much glue).
Bonus points for guessing who the pilot is
-A
Old Aug 18, 2012, 04:03 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Finished it up this afternoon. 16g RTF with the Vapor power train and battery. I could prob loose a gram or more off the gear assembly, but I love big wheels.
Flies awesome, just like a vapor, but with slightly more rudder sensitivity. Short video in the hallway to prove it flies. I took it down to the lobby, to stretch its legs, and it looks just awesome cruising around.
Get building guys! Now back to the Eurofighter...
-Adam
Cartoon DVIII Maiden (0 min 40 sec)
Old Aug 18, 2012, 10:32 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
That would be Theo Osterkamp of Marine Field Jagdstaffel 11. The aircraft is an E.V flown in Belgium in 1918.
I happen to have that info handy since I'm working up a tissue-foam model in those markings using a skin from the computer simulation Rise of Flight (see below).
Nice work on the cowl (as well as the rest of the model) - I'll be using your technique.
Gene K
speedy01 is online now Find More Posts by speedy01
For Sale Partially built fokker dviii balsa usa 1/4 scale paulsullivan Aircraft - Fuel - Airplanes (FS/W) 3 Jul 31, 2012 08:01 PM
For Sale Partially built balsa usa fokker dviii paulsullivan Aircraft - General - Miscellaneous (FS/W) 2 Jul 04, 2012 11:01 PM
For Sale 1/4 scale balsa usa fokker dviii partially built paulsullivan Aircraft - Electric - Airplanes (FS/W) 0 Jul 04, 2012 10:33 PM
Wanted WTB Kavan Fokker DVIII ARF joeliny Aircraft - Electric - Airplanes (FS/W) 0 Apr 14, 2012 11:49 PM
Wanted Fokker DVIII. (D8) jricchio Aircraft - Fuel - Airplanes (FS/W) 4 Apr 07, 2012 10:49 AM
