Old Aug 12, 2012, 01:47 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Windows 7 won't load after using naza config tool?
Anyone had a problem with windows 7 not loading, it comes up with the welcome screen and the little blue circle spinning but will not go any further, I post here and am sure its not related but the last thing I did on my pc before this happened was use the naza dji config tool to set naza fc.
ripmax is offline Find More Posts by ripmax
Old Aug 12, 2012, 02:00 PM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
I have windows 7 64bit, and The NAZA software did not do that to my system. Everything works fine. I assume you've tried normal boot several time and it stalled several times. If that's the case I would boot up in safe mode (using F8 right after the BIOS screen) and if that works then you can run system restore.
Russ
rampa202 is offline Find More Posts by rampa202
Old Aug 12, 2012, 02:29 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Thanks for info, sure its not naza but was the last thing I did before it crashed, used it lots before with no probs, been trying to sort it all day! this post was a last resort before my pc either gets launched out the window or taken to a computer expert, it will boot up in safe mode and tried a restore point but still the same.
Thanks again for reply, I know this is the wrong place to post really!
Help! t6 config software for windows 7 stormheli Radios 4 Apr 01, 2016 03:15 AM
Discussion PowerLab 8 won't auto discharge after charge (won't cycle) martinwinlow FMA Direct 6 Apr 08, 2012 05:26 AM
Help! t6 config for windows 7 stormheli Electric Heli Talk 2 Mar 22, 2012 04:02 PM
Discussion After Naza upgrade motors won't start jforkner Multirotor Talk 4 Jan 02, 2012 06:45 AM
Discussion phoenix rc 3.0 won't fit screen HELP! windows 7 rlpolo Simulators 3 May 11, 2011 11:24 PM
