Old Aug 12, 2012, 10:51 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Aileron Differential
I am setting up my new SIG Rascal 72 EG and need some input of how much to program for the first flight. What do most of you use on semi-symmetrical airfoils?
RC Man is online now Find More Posts by RC Man
Old Aug 12, 2012, 11:16 AM
modbuilder is offline
Find More Posts by modbuilder
KJ4WFG
modbuilder's Avatar
United States, SC, York
Joined Dec 2007
It ought to fly OK without any differential. I'd start off with none and see how much yaw you get from aileron input. If you need any at all, it's probably not much more than 5% reduced deflection on the down ail. Just my $0.02
modbuilder is offline Find More Posts by modbuilder
Old Aug 12, 2012, 11:30 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Are control throws included in the assembly manual?
If not, consider contacting Sig directly - they have a little experience in the RC business' and a fair command of English
D
Dereck is offline Find More Posts by Dereck
Old Aug 12, 2012, 01:23 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Are you asking about control surface throw range, or differential throw?
Most manuals (and certainly a SIG manual) will have throw ranges. But differential information is rarely included. For a non-symmetrical wing, I offset the aileron servo arms so that up aileron gets a bit more up throw than down. But with a high wing plane that is stable, you may not notice the difference.
wuest3141 is offline Find More Posts by wuest3141
Old Aug 12, 2012, 02:24 PM
pdansalvish is offline
Find More Posts by pdansalvish
Lusby, MD 20657
Joined Mar 2001
Please post some pictures of your Rascal 72, along with some specs.
As for differential, on my original Rascal 40, no differential was needed.
pdansalvish is offline Find More Posts by pdansalvish
Old Aug 14, 2012, 08:51 AM
United States
Joined Feb 2001
I only had a chance to do a little flying and found that 15% was too much and 5% was close but it may need a little more. I need to testing to fine tune it. I am waiting for batteries and a Scorpion SII-3026 motor so it will be a while before I get back to flight testing.
After that I will post some photos in the other thread.
Old Aug 14, 2012, 11:02 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
The only time you "need" aileron differential, is when, at full aileron throw, it causes adverse yaw, that is, when the down aileron causes enough drag to "pull" that wing backward.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Aug 14, 2012, 11:39 AM
United States
Joined Feb 2001
Les
I have found that the best way to tune aileron differential is to do aileron rolls. If they are not axial around the center of the fuselage then you need to adjust the differential. Most airplanes do much nicer looking rolls with differential and I have it on most of my airplanes. If you donít do rolls it will help coordinate turns but itís hard to tune just watching turns so most that donít do aerobatics donít use it.
If your transmitter has that option next time you are out flying give it a try and you should have better looking rolls after tuning.
Old Aug 14, 2012, 12:16 PM
DustBen is offline
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
You hit the nail on the head; consecutive aileron only rolls will indicate the need for differential.
If the model does a barrel roll, the inboard aileron needs to raise more.
If it does an "outside roll" (model looks like it falls off a table), the inboard aileron needs less up throw.
One additional "fine tuning" recommendation and that is to do the rolls straight down with power off. Once the roll is tuned to accomplish tight axial rolls, then do them going up and down with power. If the model does barrel rolls, the thrust line needs to be pointed down. If it does the rolls "outside", the thrust angle needs to be pointed up.
DustBen is offline Find More Posts by DustBen
Old Aug 14, 2012, 12:59 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
High winged Cub type models need aileron differential and use of rudder with ailerons for smooth turns without "adverse yaw". Low winged warbirds can turn well with ailerons and elevator only , it's called "yank and bank" flying. Differential ailron movement ( mostly up,little down) is intended to reduce drag of the down-going aileron which resists turning in the desired direction.
E-Challenged is offline Find More Posts by E-Challenged
Old Aug 14, 2012, 03:08 PM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
Good question!!
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Discussion RC Tuning Guide- Gear Differential (Diff) & Ball Differential Tuning edwardchan80 Vendor Talk 1 Aug 06, 2012 09:35 PM
Discussion Aileron differential on a warbird? 10AE Electric Warbirds 4 Jul 10, 2012 07:39 PM
Question Aileron Differential Mr. Wiz Hand Launch 27 May 04, 2012 04:03 PM
Discussion 12FG setting dual ailerons with differential Roblister Radios 2 Apr 22, 2012 01:45 PM
Discussion Aileron Differential - Rudder FSD Slope 29 Mar 05, 2012 09:21 PM
