Old Aug 12, 2012, 07:03 AM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
3s Lipo, whats safe for LVC? 9.6v -9.9v? 11.0v?
Hello, Just wanted to know when you guys are ready to land with enough time for Low Voltage Cutoff (LVC).
I fly with 1 battery setup (3s-2200mah Lipo). I power everything on plane with it.
I use HobbyKing simpleOSD. What is the save LVC to safe land with enough time?
9.6v-9.9v? or too low? I've read some are landing when its 11.0v?
LexusFPV is offline Find More Posts by LexusFPV
Old Aug 12, 2012, 07:33 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
3.5/3.6V per cell is the minimum a cell should be discharged to.
It depends how far you fly. If I wanted another 10% of flight time after the alarm, I'd choose 11.5V.
Zen09 is offline Find More Posts by Zen09
Old Aug 12, 2012, 10:27 AM
snelan is offline
Find More Posts by snelan
snelan's Avatar
Joined Jul 2012
I land at 11v, but I haven't really done any research into this so Zen09 might have a better idea.
snelan is offline Find More Posts by snelan
Old Aug 12, 2012, 10:34 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
It depends, open circuit or under load?
I can suggest a pretty good website: http://www.rchelicopterfun.com/rc-lipo-batteries.html
Ceros007 is offline Find More Posts by Ceros007
Old Aug 12, 2012, 10:36 AM
p_daniel_santos@ is offline
Find More Posts by p_daniel_santos@
Portugal, Viana do Castelo, Viana do Castelo Municipality
Joined May 2006
Zen09,
That is not true. You can safely discharge a lipo till 3.2V (or even lower but not lower that 3V). Just be careful to leave at least 20% of the charge in the pack. So, if the pack is 1000mAh, there should be no more than 800mAh charged back in, meaning that 200mAh remained at the end of the flight (20% of capacity). You should also store the battery with 60%~70% capacity (3.78V~3.92V resting voltage per cell). Never store the lipo fully charged. You should only fully charge it before the flight. Hope this helps.
Pedro
p_daniel_santos@ is offline Find More Posts by p_daniel_santos@
Old Aug 12, 2012, 10:53 AM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
Beware that under load, there's a big difference in voltage, much lower.
Old Aug 12, 2012, 12:05 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
3volts per cell is ok as long as you stop using motor and land soon
Your video should cut in and out to tell you hit lvc
Batteries bounce back up in voltage so set lvc to 3 volts and when video craps out stop motor and land ASAP
This is one reason I like separate battery for fpv video because I can fly around and not have to land
Castle creations as an example set stockmsettingsmat 3 volts per cell
If you really want to be safe set lvc to like 3.8 volts and don't charge to 12.6
But really batteries are cheap these days so have fun and slightly abuse them
Some planes I shut off lvc so I can get high bursts and high watts without lvc
3 to 5 second burst with high powered systems , using a switch for 100 percent wot
Lvc has to be turned off, there is a reason why the esc can be programmed
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Aug 13, 2012, 02:34 AM
Zen09 is offline
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Originally Posted by p_daniel_santos@ View Post
Zen09,
Pedro
I haven't said it's not safe. It just shouldn't be done, because there's almost nothing to gain doing it yet it would shorten battery life.
See this graph to understand what's going on. At 3.6V per cell you already have nothing left.
Old Aug 13, 2012, 10:06 AM
Joined May 2006
Zen09,
Your graph confused me! At 3.7V per cell (resting voltage), the lipo have more that 50% of its charge! So I'm not understanding the graph when at 11.1V (3s - 3.7V per cell) you write 0%.
In a normal battery pack, at 3.2-3.4V you should have more that 20% of the rated capacity. Discharging to 3.2V would not shorten the battery life. At least this is valid in standard quality lipo's.
Pedro
Old Aug 13, 2012, 10:49 AM
Zen09 is offline
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
You're having it wrong, sorry. I haven't said 0%, but I meant it's nearly empty.
Another graph:
Old Aug 13, 2012, 11:41 AM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
'An 80% discharged LiPo cell, will give an approximate open circuit voltage of 3.75 volts. A 3S LiPo pack therefore would show about 11.25 volts after a flight when it's 80% discharged, a 6S pack would be about 22.5 volts.'
Might be able to run down to 3.2V, but there won't be a lot of run time available from when the cells are at 3.7 until 3.2
I am no expert. I prepare to land when the OSD says 11.2V, even though that is voltage under load (maybe .1A to the motor and 0.1A to the video system when I cut the throttle to check it) and probably well above 20%. When I check on the ground afterwards I typically have 3.8V measured, which means I had a little safety in reserve for FPV flying. Makes it possible to fight some unexpected wind or do a couple go-arounds as needed.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Aug 13, 2012, 12:07 PM
Joined May 2006
Another graph:
Zen09,
I'm not wrong. I have performed discharge tests in Zippy, Turnigy and Hyperion, both under high discharge and low discharge.
At 3.3V the lipo is not empty as your graph show. I've seen some competition model aircrafts to cut-off at only 3.0-3.1V/cell. I don't recommend this, but they could draw out more 5-10% of energy (but reducing the battery lifetime).
The storage voltage of lipo packs is 60%~70% capacity (3.78V~3.92V resting voltage per cell). So looking at your graph the data does not match. Where did you took the graph from? 333V pack is huge. Probably a very low discharge lipo that performs completely different from the high discharge lipos you use. That could explain the differences.
I propose you a test. Fully charge a battery pack. Discharge a pack till 3.7v per cell (resting voltage). Then charge back it again. Then you know how much energy you have consumed.
Pedro
Old Aug 13, 2012, 12:34 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The graphs and interpretations of them just don't match reality.
My practical "must land" voltage is 3.466V/cell (10.4V for a 3S pack) and
there's quite a lot of juice to be had between 11.1V and 10.4V.
After 10.4, the pack voltage curve goes over the "knee" and
starts to drop pretty quickly. If you want to always land with
20% of your battery capacity unused, then by all means land
at nominal voltage.
Looking at the OSD stats from a recent flight where I got caught
out downwind on the return leg, voltage was down to 11.0
at cruise throttle (little over 1C) 3.7 miles away, having used
3850mAh out of 5000. I made it 2.7 miles (against the headwind)
on 900mAh before hitting my normal must land voltage of 10.4V.
Only then did the voltage start dropping quickly under cruise
load and I made it all but the last 150 yards home
using another 100mAh or so and chopped the throttle at 3.2V/cell.
The way I fly, I can land almost anywhere without power, so if I have
the height to glide home, I'll do so from 10.4V (on 3S). If I need a
reserve for a go around or two, then maybe 10.8V or so. I set my ESC's
LVC around 3.1V/cell to protect the pack itself.
ian
Daemon is online now Find More Posts by Daemon
Old Aug 13, 2012, 01:23 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
1) dont fly FPV with a low voltage cutoff enabled
2) batteries in fpv planes are inconsequential. the question isn't what's safe for the battery, it's how far will it drop before your video goes out.
do like Daemon. be down by 10.4. if you fly around like a LOS plane until it hits 9-9.4v you'll get bit by it in fpv eventually. one day youll be flying on a hot day & suddenly that VTX that use to work fine at 9.Xv cuts out at 10...
and now you're a half away without video...
ask me how i know. been there. got the plane back off shear luck that it was a very windy day and i was flying up-wind.
Toysrme is offline Find More Posts by Toysrme
Old Aug 13, 2012, 01:26 PM
Zen09 is offline
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Pedro
http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
"For long-term storage, manufacturers recommend a 40 percent charge."
That matches very well with 3.85V on the graphs.
Discussion 3S for a 9.6V Nikko Turbo Panther Bugman Jeff Off-road Cars 8 May 09, 2012 08:03 PM
Question how can i make a 3s lipo to 9v output voltage regulator? kicekilla FPV Talk 5 Mar 09, 2012 10:01 PM
Question What LVC setting to use for TP 3s 11.1v lipos arukum17 Beginner Training Area (Aircraft-Electric) 5 Dec 14, 2009 05:16 PM
9.0V or 7.2 for Cuttoff Voltage on 3S Lipoly?? Orion_V Batteries and Chargers 5 Jun 27, 2004 06:24 PM
LVC selection for 3s LiPo (Phnx35) - 7.2V or 9v? Peter Khor Castle Creations 3 Apr 09, 2004 01:51 PM
