Old Aug 12, 2012, 05:11 AM
tomplom is offline
Find More Posts by tomplom
Joined Mar 2012
Help!
micro t shim
hi iwas just wondering what a shim is in the micro t trany
tomplom is offline Find More Posts by tomplom
Old Aug 12, 2012, 10:15 AM
rcphreak is offline
Find More Posts by rcphreak
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
i just dug through my pile until i found one small enfugh LOL . some one will chime in with the correct answer for you maby parsons will know what most have used .
rcphreak is offline Find More Posts by rcphreak
Old Aug 12, 2012, 03:38 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I think he's asking what it is, not what thickness of shim to use?
The purpose is to remove the binding from the case being too tight. You can do the same thing by just loosening off the screws that hold the gearbox together slightly until the gears spin easier.
wparsons is offline Find More Posts by wparsons
Old Aug 12, 2012, 05:59 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
your right parsons have to slow my reading down . thanks as parson said if not the alloy gearbox no shim is needed just loosten the three screws until no binding is found .
Old Aug 13, 2012, 05:05 AM
tomplom is offline
Joined Mar 2012
thanks but if i do that then sometimes it striped the transmition
Old Aug 13, 2012, 06:16 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
if you hold the truck in the air set trim to half throttle hold one wheel and slowly loosten the screws one at a time and when i say slowly more like an eith of a turn per screw at any time equily . you will hear the truck gain rpm at the point it stops gaining stop . and every so often do this agin but you may need to tighten them as the gears wear . micros require alot of care and attention hair and other debris can make a huge affect on performance .
Old Aug 14, 2012, 05:16 AM
tomplom is offline
Joined Mar 2012
thanks for etherything
Avionik D-99 - To shim or not to shim. Meneer High Performance 6 Jul 13, 2004 02:27 AM
