Old Aug 11, 2012, 06:34 PM
Scrauper is offline
Find More Posts by Scrauper
Joined Aug 2012
How do I conect up retracts and sequencer Hobby King P40
HELP PLEASE!
Just bought a giant Scale Hobbyking P 40. Typically the instructions are pants but the worst is they do not tell you how to connect all the spagetti from the various servos, retracts, flaps ,ailerons etc up to the receiver.
Its my first go at retracts etc and I would be very grateful if any experts out there could tell me which plug to put in which socket in case I burn something out!
I've tried Hobbyking but they are useless as usual.
Many thanks
Scrauper
Scrauper is offline Find More Posts by Scrauper
Old Aug 11, 2012, 07:15 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Scrauper -
On the sequencer, plugs will go white wire to the inside of the unit, black to the outside.
Be sure to check out the "Big, big, big ..." Hobby King P-40 thread. If this is your first airplane of this caliber, you'll need more information. This P-40N is a gem in some ways but tests even seasoned modelers due to the work needed to get it flight worthy, especially the retracts.
I messed up getting the plugs correct at the sequencer, didn't harm a thing. One way it works, the other it doesn't. It has a monitor l.e.d. to help.
Edit : The feed wire from the sequencer goes into ch. 5 on your rxr. The labelled wires from the retracts and gear doors go into the labelled ports on the sequencer, black wire to the outside.
They furnish "Y" harnesses to combine the wiring from the two wings. Thus, both ailerons will "Y" into one and it will go to the ail. port on your rxr. Same for the flaps ("Y" into port #6), retracts, and gear doors. All are pretty well labeled.
gnats82 is offline Find More Posts by gnats82
Old Aug 11, 2012, 07:22 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Here is the thread.
http://www.rcgroups.com/forums/showt...&highlight=big
TripleW is offline Find More Posts by TripleW
Old Aug 12, 2012, 08:14 AM
Scrauper is offline
Joined Aug 2012
Thanks guys, thats a big help, I think I may have sussed it out now. Couldn't have done it without you!
Discussion How does hobby king get away with falsifying invoices for US Customs import taxs? spacecase HobbyKing 10 Apr 15, 2012 03:08 PM
Discussion Hobby King Tx & Rx set up help, please? Refrik FPV Talk 2 Apr 15, 2012 02:26 PM
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Discussion intermittent retracts on hobby lobby/freewing super hornet..how do i fix them? jb0005 Foamy EDFs 3 Aug 01, 2011 10:52 AM
