Old Aug 11, 2012, 04:24 AM
rcfanfun is offline
Find More Posts by rcfanfun
Joined Aug 2012
New Product
EPO beginner airplane-55mm EDF or pusher prop
In the model show, I saw a great beginner airplane, after checking the video in the youtube, I think this airplane is more suitable for the person who is a little better than new hand.
The advertising post
I bought one, the EPO is quite good and the package is also OK.
When first assembly, I made it a EDF airplane.
Looks very good. the performace ,it is perfect
Next time, I will try the prop power system , see how it works, As I saw in the model show, it is very easy to change EDF into pusher. I want to try it.
I think , i just need to take the EDF cover off and put the pusher cover on it. asseble the prop and motor, then cable connection, it can be a pusher beginner airplane.
rcfanfun is offline Find More Posts by rcfanfun
Old Aug 11, 2012, 06:22 AM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
Looks okay, easy introduction to EDF, I suspect performance will be a bit better with pusher-prop config (more thrust likely). It's a similar design platform to other 'beginner' models, it has the usual attributes to minimise running-gear damage. I would say it will serve well as a stepping stone towards more complex models
RWData is offline Find More Posts by RWData
Old Aug 12, 2012, 10:22 PM
rcfanfun is offline
Joined Aug 2012
I found the video with EDF in the youtube.
ZETA Dolphin Jet 55mm EDF beginner airplane (3 min 58 sec)
It seems that EDF is also very good. As i have the same thought as you that the pusher prop will be better. so now, i am trying to get pusher setup and test it.
Question What is the Best Parkzone BNF or PNP Micro airplane for beginner? RcAirplaneNoob Scratchbuilt Indoor and Micro Models 26 Aug 27, 2012 12:37 AM
Sold Dons Wicked EDF 4800KV brushless and 55mm EDF UNIT hi2nr Aircraft - Electric - Jets (FS/W) 4 Mar 01, 2012 06:51 PM
Sold Dons Wicked EDF 4800KV 55mm EDF unit hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Mar 01, 2012 06:28 PM
Discussion to EDF or pusher prop a LSJS? monas Power Systems 1 Apr 12, 2008 04:22 PM
Sold AMD SU-27 glider, pusher prop, or EDF RCDad Aircraft - Electric - Airplanes (FS/W) 7 Dec 28, 2005 06:15 PM
