This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Aug 10, 2012, 07:27 PM
unclegeorge is offline
Find More Posts by unclegeorge
Trader Rating: 241
unclegeorge's Avatar
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 241
Sold
WWII Hamilton Scale spinner for your Warbird!
WWII Hamilton Warbird spinner for Corsair or Skyraider types.
NIB Aluminum Spinner Nut for 30-111cc engines. This has the standard 6 hole pattern used on a DA-100, DLE-111 etc. It is very easy to make it also fit a standard 4 hole pattern like used on a DA-50, DA-60, DLE-55, etc. To make it fit the 4-hole pattern simply line 2 of the 4-holes up using a 4-hole drill jig. Then drill 2 additional holes into the back plate. These two holes will be center between the unused holes. This does not affect the balance or the strength. This is a quick and easy retrofit. It can be made to fit a 30-40 cc engine which has the smaller 4-hole pattern. Again simply line up two of the 4 holes the best you can. They will not line up perfectly, but it will not make a difference in the performance. Those two holes that almost line up need to be drilled along with the 2 new holes. It works great.
Specs: Weight: 2.4 oz, Diameter: 1 3/4", Length: 2 1/4"
I will sell this for $19.50 Plus shipping of $2.00. Compare at $39.95 for TT!!!
Please give me your mailing address and please help me keep track of you order by typing in the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase.
My account in Pay Pal is under uncgeorge@comcast.net
Uncle George
unclegeorge is offline Find More Posts by unclegeorge
For Sale WWII-3 blade Scale Hamilton adjustable pitch prop!!! unclegeorge Aircraft - Fuel - Airplanes (FS/W) 11 Feb 21, 2014 09:22 AM
Sold WWII 3 blade scale Hamilton adjustable pitch prop!!! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Aug 03, 2012 07:50 PM
For Sale NIB-WWII Hamilton Spinner for your Warbird unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 01, 2012 10:39 AM
Sold Adjustable Pitch 3 blade Warbird Scale Hamilton Prop unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 15, 2012 02:08 PM
WarbirdColors - Authentic WWII Colors for your Scale Warbird Chuck Graves Product Announcements 0 Mar 01, 2005 12:20 AM
