This thread is privately moderated by Dave Barrow, who may elect to delete unwanted replies.
Old Aug 10, 2012, 06:39 PM
Dave Barrow is online now
Find More Posts by Dave Barrow
Trader Rating: 97
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
Trader Rating: 97
Sold
Servos,Charger,Motors, ESC's,BEC's,EDF's,Wheels
I have way too much stuff laying around to use these any time soon. All items are plus shipping $3 minimum, $8 maximum. I will combine shipping to save you money.
GWS pushrod connectors $3 Each pack NIP
2 packs Sold to cmelton11
Sold 2 - Hobbyking SS Series 18-20A ESC (card programmable) $5 each- used
SOLD 18-11 2000kv Micro Brushless Outrunner (10g) $8 nip
Spec.
Model: 1811-2000
Kv: 2000rpm/v
Weight: 10g (With wires and mount)
Suggested Prop: 7x5
Suggested Power: 7.4v
No Load Current: .4a
Thrust: 130g / 5000rpm
7.4v no-load speed: 15000rpm
Peak Eff Current: 5.5A
Shaft: 2mm
Diameter: 18mm
Length: 30mm (including mount & shaft)
http://www.hobbyking.com/hobbyking/s...nner_10g_.html
SOLD Two -- 70mm Electric Ducted Fan Units $5 each - nip
Look like Freewing
Propeller Qty :5-Blade
Motor Shaft Diamete: 4.0mm
Motor Diameter:28mm
SOLD
HK2839 EDF Outrunner 2800kv $15 nip
for 70mm fans
Specs:
Kv- 3800
Dimensions: 28 x 64 mm
Shaft diameter: 4.0mm
Shaft length: 15mm
Voltage: 14.8V (4 cell Lipo)
Weight: 95g
Output Power: 550w
Max Current(<60s): 36A
Thrust: 1200g(42.33oz.)
Recommended model weight: 800-1200g
Recommended model fans: 70mm Fans
Mounting Hole Bolt Circle: 18mm & 20mm
Mtg. Hole Number & Size: 4 x M2
http://www.hobbyking.com/hobbyking/s...dProduct=11162
SOLD
HXT 900 servos NIP $3 each All 10 for $27
Size : 21x12x22 mm / 0.74x0.42x0.78 in
Voltage : 3v ~ 6v
Weight: 11g / 0.39oz
Speed : 0.12 sec/60(4.8V)
Torque : 2.5 kg-cm
Working Temp : -30C~60C
Carbon composite Bushing, 25cm wire, coreless motor
Servo arms & screw included
http://www.hobbyking.com/hobbyking/s...?idProduct=662
SOLD HXT 500 servos $3.50 each
SOLD 2 - Scale alloy hub rubber wheels 4.0 inch $13 pair still available
SOLD to Hossinarizona4 - Scale alloy hub rubber wheels 2.25 inch $7.50 1 pair $14 both pairs
2 - Scale alloy hub rubber wheels 2.0 inch $7 pair
2 - Scale alloy hub rubber wheels 1.75 inch $6.50 pair
The wheels have a strong brushed finish alloy hub which is made from 1 piece lathed aluminum. The rubber is of excellent quality and has an increasing resistance when compressed as it has a foam insert for cushioning.
SOLD
Digital Servoless Retracts $15 nip
1 pair
Features:
Robust landing gear strut and mounting bracket
Built-in 10 seconds over current and jamming protection
Integrated electric motor with a micro PCB
Double shock absorption design, completely protect the gears
Auto 90 degree twist when retracted
Spec.
Working voltage: 4.8~6V
Speed: .08s/60deg 4.8v - 0.6s/60deg 6v
Angle limit: 90 degree when retracted
Operating temp: -10~50C
Dimensions: 73.5x44x28mm
Weight: 54g
Shaft size: 5mm
Mounting area size: 44mm x 41mm
Length: 74mm
Not suitable for a plane heavier than 4.7kg
http://www.hobbyking.com/hobbyking/s...m_1pc_54g.html
SOLD
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories $25 nip
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~17v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~6.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 355g
This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT, TURNIGY and any pack with a JST-XH adapter.
http://www.hobbyking.com/hobbyking/s...dProduct=18066
Sold EDF: 64mm Pulled from a new shark jet $12
Has been tested and runs good (usual rub marks on housing from blades seating)
39L Brushless Outrunner Motor 3900kv
ESC: 25A w/BEC
SOLD10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) $4.75 a set(1o pieces)
One set to speanut other set SOLD
Ideal for connecting your reciever to Quadcopter Control board.
http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
SOLD E sky EK2-0704A head lock gyro $5 used
Watt Age 1 3/16” aluminum wheels with rubber tires $3 pair
SOLD
Nose Gear Steering sets $1 each
SOLD XM Hobbies Head Lock Gyro $8 used
Dave Barrow is online now Find More Posts by Dave Barrow
Old Aug 10, 2012, 06:46 PM
cmelton11 is offline
Find More Posts by cmelton11
Trader Rating: 57
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
Trader Rating: 57
pm sent on a few items
cmelton11 is offline Find More Posts by cmelton11
Old Aug 10, 2012, 07:20 PM
JFS is offline
JFS
Find More Posts by JFS
Trader Rating: 25
JFS
United States, TX, Mission
Joined Jun 2007
Trader Rating: 25
I'll take the XM Hobbies Head Lock Gyro $8 used
Same as HK 401G
Works good
http://www.hobbyking.com/hobbyking/s...ock_Gyro_.html please PM paypal address!!
JFS is offline Find More Posts by JFS
Old Aug 10, 2012, 07:24 PM
Trader Rating: 97
Joined Feb 2003
Trader Rating: 97
Old Aug 10, 2012, 07:44 PM
bigtruck169 is online now
Find More Posts by bigtruck169
Trader Rating: 88
United States, NY, New York
Joined Dec 2009
Trader Rating: 88
pm for HXT 900 servos NIP $3 each All 10 for $27 and EDF: 64mm Pulled from a new shark jet $12
bigtruck169 is online now Find More Posts by bigtruck169
Old Aug 10, 2012, 08:36 PM
Trader Rating: 57
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
Trader Rating: 57
pm sent on the gws rod connectors
Old Aug 10, 2012, 09:38 PM
Trader Rating: 97
Joined Feb 2003
Trader Rating: 97
2- 18-20A ESC's and 2- HXT500 servos sold to cmelton11
XM Hobbies Head Lock Gyro and EK0704a Gyro sold to JFS
HXT 900 servos NIP and EDF: 64mm Pulled from a new shark jet sold to bigtruck169
Old Aug 10, 2012, 10:18 PM
lmphiddenacres is offline
Find More Posts by lmphiddenacres
Trader Rating: 56
farmflyer
United States, KY, Sacramento
Joined Jan 2009
Trader Rating: 56
male to male leads and the turnigy acucel 6 charger
1 pack left to sell 2 packs Sold to cmelton11
TURNIGY 8-15A UBEC for Lipoly $15 nip
Spec.
Output (Constant): 5v/8A or 6v/8A
Input: 6v-12.6v (2-3cell lipo)
Weight: 34g
Quiescent current: 60mA
Type: Switching, however because of the noise reduction (thin metal case & filter) this unit gives the same noise as a Linear BEC.
LED indicator (2 or 3 cell)
Full : 7.8~8.4v / 11.7v~12.6v
Incrementing down to;
5.4~6.6v / <9.9v
http://www.hobbyking.com/hobbyking/s...or_Lipoly.html
Two Turnigy BEC's for large planes MEGABEC 8 $12 each nip
http://www.hobbyking.com/hobbyking/s...EGABEC_8_.html
Zero-interference linear BEC.
This unit can handle up to 8A constant.
This unit comes with an LED, warning of low battery voltage.
Input: 7.2v (2 cell Lipoly)
Output: 6v or 5v selectable.
Max Load: 8A
Weight: 46g
8-10A Hobby King Esc $6.50 nip
Weight: 6g
Cells: 2-3S (Auto Detect)
Max Current: 8A
Burst: 10A
BEC: 1A
http://www.hobbyking.com/hobbyking/s...idProduct=6455
FC 28-05 Brushless Outrunner 2840Kv 1 new $7 1 used $6
Two
1-new & 1 used
Spec ;
Weight: 26g (with wire & sticker etc)
Shaft: 3mm
Motor Length: 37mm
Diameter: 28mm
Stator Size: 22x5mm
Suggested prop: 5~6inch
Voltage: 7.4v (2S)
Kv: 2840 RPM/KV
Data ;
Prop (APC) 6x4
RPM 13000,
MAX current (<60d) 12A
Thrust 413g(0.91lb)
Prop (APC) 7x4
RPM 9900,
MAX current (<60d) 14.4A
Thrust 381g(0.84lb)
http://www.hobbyking.com/hobbyking/s...idProduct=5353
Spec.
Model: 1811-2000
Kv: 2000rpm/v
Suggested Prop: 7x5
Shaft: 2mm
Diameter: 18mm
Look like Freewing
Motor Diameter:28mm
for 70mm fans
Specs:
Kv- 3800
Shaft length: 15mm
Weight: 95g
Output Power: 550w
SOLD
Voltage : 3v ~ 6v
Torque : 2.5 kg-cm
1 pair
Features:
Spec.
Weight: 54g
Shaft size: 5mm
Length: 74mm
Features;
Time limit function
Spec.
Weight: 355g
TR 35-36C 1100kv Brushless Outrunner $25 used
Input Voltage : 7.4V~11.1V (2~3S Li-po)
Kv : 1100rpm/V } within 10%
Current capacity : 35A/30s
Dimentions : 35mm X 36mm / 1.38in X 1.41in
Shaft diameter : 4mm / 0.16in
Weight : 106g / 3.74oz
Number of poles/magnets : 14
Recommended model weight : 1000~1900g / 35~67oz
Power equivalent : .25 to .30 IC glow engine
Stator Dimentions: 28x14mm
Power: 400W+
ESC: 25A w/BEC
Don's Wicked JR motor 2200KV $10
Motor Specs:
KV= 3200 rpm/volt
Weight: 29 grams (1.02oz)
Shaft diameter: 3mm
Outside Diameter: 26.1mm (1.03")
Length: 23.37mm (.92")
Shaft length: 13.7mm (.540")
Here is some test data I took using a 3S1320 lipo (readings takes about 30 seconds into the pack):
APC 6 x 4, 15500 rpm, 12.8 amps, 59 mph pitch speed, 135 watts, 16 ounces thrust measured.
APC 5.5 x 4.5, 15500 rpm, 12.5 amps, 135 watts, 66mph pitch speed
APC 5 x 5, 16000 rpm, 12.5 amps, 135 watts, 75 mph pitch speed
APC 4.7 x 4.7, 17000rpm, 11.5 amps, 120 watts, 75 mph pitch speed.
Motor weight: 29 grams
KV ~2200
Shaft size: 3mm
Wicked JR 3200 KV motor $10
Motor Specs:
KV= 3200 rpm/volt
Shaft diameter: 3mm
Here are test results on 3S 1300 lipo
4.1 x 4.1 prop at 24,000 rpm, 14 amps, gave about 12 ounces of thrust, 93mph pitch speed
4.5 x 4.1 prop at 22,000 rpm, 16 amps, gave about 16 ounces of thrust, 85 mph pitch speed
For the Wicked Jr on a 3S lipo about 16-18 amps is about the max you want to go when settled or about 180 watts.
Hobby King Battery Monitor 3S $4 each - nip
Two to sell
This unit will give a warning buzzer when the3S Lipo pack drops below 9v.
http://www.hobbyking.com/hobbyking/s...onitor_3S.html
Two sets to sell
Cyclone PG-03 Gyro $5 nip
Two - E sky EK-0704 Gyros $5 each new
DigiMix ll $8 nip
External Elevon mixer (for use with radios that do not have that capability)
M72 Indoor Rx Antennae $3
Micro 72 mhz antennae
Watt Age 1 3/16 aluminum wheels with rubber tires $3 pair
Wheels 2 yellow plastic with rubber tires $3 pair
I would like one set (10) of the 10cm male to male leads and the Turnigy Acucel 6 charger. Send me your paypal address and the total price for the items. Thanks, Larry
lmphiddenacres is offline Find More Posts by lmphiddenacres
Old Aug 11, 2012, 12:10 AM
Trader Rating: 97
Joined Feb 2003
Trader Rating: 97
10cm male to male leads and the Turnigy Acucel 6 charger sold to lmphiddenacres
1 pack 10cm male to male extensions sold to speanut
Old Aug 11, 2012, 01:51 AM
Doubledog is offline
Find More Posts by Doubledog
Trader Rating: 54
To build or fly today?
Doubledog's Avatar
United States, AL, Gulf Shores
Joined Feb 2008
Trader Rating: 54
I'll take these below. Send me a PM with your info and total shipped via 1st class postage.
Doubledog is offline Find More Posts by Doubledog
Old Aug 11, 2012, 08:39 AM
Trader Rating: 97
Joined Feb 2003
Trader Rating: 97
Doubledog, I have a sale pending on those wheels. I'll let you know if it falls through.
Old Aug 11, 2012, 09:31 PM
tailskid2 is offline
Find More Posts by tailskid2
Trader Rating: 21
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Trader Rating: 21
Very nice ad!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Aug 12, 2012, 07:36 AM
donfl3344 is offline
Find More Posts by donfl3344
Trader Rating: 50
New Guy
Simpsonville, SC
Joined Sep 2007
Trader Rating: 50
paypal sent for:
Nose Gear Steering sets $1 each - 5 ea -$5
donfl3344 is offline Find More Posts by donfl3344
Old Aug 12, 2012, 12:55 PM
Trader Rating: 97
Joined Feb 2003
Trader Rating: 97
Originally Posted by donfl3344 View Post
paypal sent for:
Payment received. Will mail topmorrow.
Thanks, Dave
Sold Complete edf setup...esc, motor, fan, bec, lipo The Juice Aircraft - Electric - Jets (FS/W) 9 Aug 18, 2012 02:38 PM
For Sale 64mm EDF Setup, Motor, Fan, BEC and 60A esc Bonestockz06 Aircraft - Electric - Jets (FS/W) 3 Jun 01, 2012 05:52 PM
For Sale 64mm EDF Setup, Motor, Fan, BEC and 60A esc CHEAP Bonestockz06 Aircraft - Electric - Jets (FS/W) 0 Jun 01, 2012 05:51 PM
Discussion Use of Switching BEC with twin EDF motors/esc's E-Challenged Electric Ducted Fan Jet Talk 0 Jan 07, 2010 12:41 PM
For Sale Pair of 64mm EDF units BL motors and ESC's w/bec Steve_C Aircraft - Electric - Jets (FS/W) 3 Dec 29, 2007 06:59 AM
