Old Aug 10, 2012, 05:26 PM
t-rexn8 is offline
Find More Posts by t-rexn8
United States, CO, Denver
Joined Jan 2007
Blade 130X Tail Grip Flip Mod.
So I have been flying the 130X since it came out and have tried all the "fixes" with some success.
Recently I have had a problem, 2 separate times (maybe 3 if I think back to some of the first in flight failures). What I found was happening was that the tail pitch links were coming off of the tail grip balls in flight during hard collective "pops" or left to right tail inputs. This resulted in the bottom pin on the slider breaking and of course the helicopter would piro out of control and hit the deck.
I hate trailing edge control, so between that and the 2 repeated failures, I decide to give the "grip flip" a try.
Basically I just reversed the servo in the holder, reversed the tail grips, reversed the pitch links in the slider, and bent the rod to clear the tail servo gears now facing rearward and correct the new geometry because it is off to the side slightly now.
Test flew it and was very impressed with the "feel" of the tail. It felt more responsive, precise and best of all did not fail in flight from links popping off
Give it a try
Blade 130 X Tail Grip Flip Mod (1 min 4 sec)
t-rexn8 is offline Find More Posts by t-rexn8
Old Aug 12, 2012, 07:10 PM
t-rexn8 is offline
Joined Jan 2007
Blade 130X Tail Grip Flip / Hard Flight Test (4 min 54 sec)
Old Aug 13, 2012, 12:31 AM
helikido is offline
Find More Posts by helikido
United States
Joined Aug 2009
Or buy a wk v120d02s
helikido is offline Find More Posts by helikido
Old Apr 08, 2013, 01:57 PM
nougiw is offline
Find More Posts by nougiw
Joined Jan 2013
Give it a try
Hi, why did you change the orientation of the tail servo instead of reversing the yawing channel? Wouldn't that have exactly the same result?
By "correct the new geometry because it is off to the side slightly now" you mean increase/decrease of the rod lentgh?
Thanks!
nougiw is offline Find More Posts by nougiw
Mini-HowTo Solo Pro 180 blade grip mod sqij Micro Helis 4 May 08, 2012 01:39 AM
Wanted Blade 450 Alum Tail blade grips wbefield Aircraft - Electric - Helis (FS/W) 0 Mar 04, 2012 03:36 PM
Data CP2 Blade Grip-Flip Mod Redux elan Micro Helis 30 Jul 23, 2009 08:29 PM
Discussion New Trex 450se 600 tail mod blade grips by G-Force!!! brovic777 Mini Helis 23 Jun 02, 2009 08:11 AM
For Sale Trex 450 Microheli Tail blade grips, tail shaft, bell crank, Align tail grips, heliup djdaveq Aircraft - Electric - Helis (FS/W) 5 Sep 05, 2007 05:44 AM
