Old Aug 10, 2012, 05:02 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Hobbyking 50mm alloy no thrust?
Hi
I purchased one of these 50mm alloy 4800kv 3s version EDF's for my T-33.
Link- http://www.hobbyking.com/hobbyking/s..._Version_.html
I'm running it on a 1300mah 3s Nanotech.
I've got a strange problem though in that it sounds like its screaming but has little thrust. At first I thought the intake/exhaust was too small so I carved out some foam, but it was the same. Then I pulled the fan off and looked at the adapter thinking the fan might be slipping so I added a locking washer and tried again but no joy there either. Slipping fan seems like the logical answer though. Yesterday I measured the current draw and it was a little odd. As I increased throttle the amps only came up to around 3.7amps at mid throttle, then as I passed mid throttle you could hear the motor increasing rpm to a scream, but the the current draw fell away to 1.7amps as it approach full throttle?
Does anybody have any thoughts on this? fan slipping? or something else?
input appreciated
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Aug 10, 2012, 05:08 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
make sure the fan is spinning in the correct direction
jcdfrd is offline Find More Posts by jcdfrd
Old Aug 10, 2012, 09:31 PM
Bravo47 is offline
Australia
Joined Jun 2010
We can cross that off the list, thx. Anybody else have any experience with this EDF?
Old Aug 10, 2012, 10:00 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Mick
which direction is it spinning if your in front of the fan looking at it?..........clockwise or counter clockwise
this is a common problem with edf nubies, and their is a comment in the HK comments section about this rotor needing to run in an opposite direction which is why I asked but from the pics it looks like a normal rotation direction which if your in front of it looking at it you will want to see a counter clockwise direction
if the fan is slipping you should take off the rotor and shaft adapter and inspect for slippage it should be quit easy to detect
good luck
Old Aug 11, 2012, 01:13 AM
Bravo47 is offline
Australia
Joined Jun 2010
Mick
Looking at the intake its a CCW rotation. Looking at the curvature of the blade viewed from the side, the rotation appears correct to me.
Mick
Old Aug 11, 2012, 11:23 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
ok that sounds correct, you could make a short video of whats its doing we could probably help better but if it sounds like the rotor is slipping then it has to come apart and see whats going on
Old Aug 11, 2012, 06:30 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
is it possible your motor has been damaged/demagnetized?
kelberts is offline Find More Posts by kelberts
Old Aug 11, 2012, 08:33 PM
Bravo47 is offline
Australia
Joined Jun 2010
Hobbyking 50mm Alloy 4800kv EDF, 1300hah 3s nanotech. The unit barely has enough thrust to get my T-33 air born. I've pretty much ruled out fan slipping, and running out of idea's. I ruffed up the inside of the prop adapter and marked with texta. No slip noted. Note the current draw falls away beyond 50% throttle? Amp draw peaks out under 4amps. Perhaps its the inrunner? Input appreciated.
Heres the video. Check it out
50mm Alloy no thrust problem? (0 min 43 sec)
Old Aug 11, 2012, 08:44 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
what wire do you have the amp clamp around?
Old Aug 11, 2012, 10:30 PM
Bravo47 is offline
Australia
Joined Jun 2010
positive off the battery lead
Old Aug 11, 2012, 10:41 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
ok just checking thats fine I thought possibly that you may have had it around one of the motor wires and that would give some goofy readings as it is a/c on that side of the esc, so that is a strange reading your getting, the fan sounds ok to me but only getting 4amp draw..........is that correct those have to draw more than that, I guess that would be the reason for your thread hmmm ....have you tried a diff battery? have you checked your end points in the radio on the throttle channel and/or calibrated the esc throttle?
Old Aug 12, 2012, 12:41 AM
Bravo47 is offline
Australia
Joined Jun 2010
Yeah tried a couple of batteries, and once you rule out slipping I guess that only leaves me with a faulty motor. The rest of the electrics works OK and the throttle is calibrated. I only fitted this upgrade after the stock EDF blew its blades out the back end during a pass. Oh well I guess I'll order another motor as chasing a waranty from HK is to tedious.
Mick
Old Aug 12, 2012, 02:08 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
hmmmm, thats wierd...I have two of those with Red Brick 20 amp ESC's, both work awesome, one is in an A-6 Intruder I scratchbuilt and it flies like a pylon racer! you should be pulling 16-18amps at full throttle. have you got a different ESC you can connect to and see what happens?...
the only other thing I can possibly think of is the impeller might be on upside down...dont know if that is even possible I'll have to look at the one that is not in anything yet, should be rounded airfoil profile forward sharp side rearward... your motor "sounds" like its screaming...not to sure thats the problem, if your motor screams and your amps are low, its usually a prop/impeller problem. I'll go look at it.
here is a vid of my Intruder flying with that same fan (3s version)
Flight of the Intruder (3 min 43 sec)
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Aug 12, 2012, 02:14 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
The magnet rotor may have come loose from the shaft. It's usually glued on.
Steve C is offline Find More Posts by Steve C
Old Aug 12, 2012, 02:40 AM
Dizz is offline
Find More Posts by Dizz
Dizz's Avatar
Brixham, Devon, England
Joined Jun 2004
If you have a second ESC I would try swapping that before getting bogged down dis-assembling fans and motors. Would be a strange failure, but at least it could be ruled out (or not).
Pete
Dizz is offline Find More Posts by Dizz
Discussion HobbyKing Mercury Alloy 64mm 4700KV EDF Unit lipoflyer Electric Ducted Fan Jet Talk 292 Dec 14, 2014 12:02 PM
Sold Wicked 5400KV motor+50mm Alloy EDF+40A ESC $35 queadlunnrau Aircraft - Electric - Jets (FS/W) 6 May 04, 2012 07:50 PM
Sold Hobbyking 50mm Alloy EDF 4200kv $16 Shipped queadlunnrau Aircraft - Electric - Jets (FS/W) 2 Apr 04, 2012 08:35 PM
New Product HobbyKing - Mercury Alloy EDF Unit Mikey 68 Foamy EDFs 3 Nov 08, 2011 08:08 AM
Sold HobbyKing 7075 alloy struts BNIP $28 shipped kevinb120 Aircraft - Electric - Jets (FS/W) 1 Mar 01, 2011 10:33 PM
