The holds in my HK gear were drilled out of round and had to be replaced. It didn't appear to be any softer than the Align one I replaced it with. If the teeth stripped during pitch pumps, I would anticipate that the gear mesh was a bit loose. I'd be interested to hear what Endolf thinks happened.
Latest blog entry: Dynam Me-262 Schwalbe in Flight
I had a similar problem with my tail rotor after reassembling the grips. It turns out the thin shim washer that goes on the radial bearing sleeve needs to be set perfectly before putting the radial bearing back in the grips. One of the radial bearings feels notchy, but I don't think it's the thrust bearing, it feels smooth while pulling on the grips.
Joined Oct 2007
My guess is that tolerances in use for producing hubs, grips and even the feathering shafts are way too large. The counter measure in use during assembly is setting the screws at zero bearing tolerace, using glue to lock them. I found all 450 and 500 HK heli s disassebled and greased and reassembled to show this phenomenon.
Changed parts for align ones in my 550 and 600gt, kept the 450 s as is. All fly well :-) |
United States, SC, Irmo
Joined Sep 2011
What are you guys getting total build cost at? For decent equipment. I've been playing with the shopping cart and am getting to $500 pretty easy including shipping. And does not include batteries which I need at least 2 and that's another $120. I might need to stick to 450's. The price jumps crazy like! I'm getting close to prices of used Align if I shop around.
http://www.rcgroups.com/forums/showp...1&postcount=66 |
My 550 costings
https://docs.google.com/spreadsheet/...UE&output=html It's not quite done yet, the beastx suddenly snap rolls right up to 45 degrees when hovering side in to a reasonable wind. Suggestions are it's tail vibes, so I'm hunting those down at the moment, hopefully the posty will deliver the bits to replace the tail box and pitch slider today, if that works I'll add it to the costings. I also got some bling on the 550 that isn't on the costs, a canopy, some quick release canopy holders and some F3C skids. Endolf |
| Thread Tools | |
| Sold TT Raptor G4 FBL With all the good stuff!!! | wolfcbr2003 | Aircraft - Fuel - Helis (FS/W) | 0 | Jul 16, 2012 09:49 PM |
| Discussion New hk550 | Foam boy | Large Electric Helis | 2 | May 25, 2012 12:48 AM |
| Sold 2 New clone 450ProTT GT FB&FBL ARFs like newAlign 3G +Rx +ton of tt sprs 175 shipd | blueindian | Aircraft - Electric - Helis (FS/W) | 3 | May 09, 2012 01:01 PM |
| Sold JS Models 3D Frenzy 50 FBL Airframe with TT .53 Redline/Align muffer | HD Hucker | Aircraft - Fuel - Helis (FS/W) | 0 | Apr 12, 2012 07:06 PM |
| Discussion HK550 or indeed any 550e clones | hedgeheli | Large Electric Helis | 3 | Feb 01, 2011 07:33 AM |
