Old Nov 18, 2012, 09:48 PM
evltoy is offline
Find More Posts by evltoy
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
Thanks for the info. I thought I did read somewhere last year that EC5's were reconmended... I guess there is no harm in asking.
I'm only going to have 4x 6s 5000 lipos for this 550 and I want to get into para charging for this lipo set.
evltoy is offline Find More Posts by evltoy
Old Nov 19, 2012, 02:44 AM
Paul 1968 is online now
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
I'm currently using 5.5mm bullets on my 550 and 600 batteries. The only reason is because the Turnigy and Zippy batteries are supplied pre fitted with them. Connecting them makes me twitch though as there is significant arcing. I'm not a fan of soldering the barge rope wires on these big batteries but I do plan on changing to EC5's at the earliest opportunity, but I'm going to need a bigger soldering iron.
By the way, anybody noticed how quiet these two 550 threads are. Either HK haven't sold any ore those of us that have them aren't having any issues. Mine has had lots of air time and so far has been 100% reliable. (There you go I've just gone and jinxed it ).
Paul 1968 is online now Find More Posts by Paul 1968
Old Nov 19, 2012, 02:52 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Mine is coming together well, I'm expecting servos and an ESC to arrive this week and I'll finish the build off. A few very minor issues, overall I'm more impressed with the kit the more I work with it.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Nov 19, 2012, 03:09 AM
.Superfly. is offline
Find More Posts by .Superfly.
RC is healthy for your brains!
Italy, Lombardy, Milan
Joined Nov 2012
Hi! Possibly also xt90 could do the work. Basically always remind that any connector should offer round, bullet male poles, as the theory of current flow suggests that to have the lowest flow resistance and associated surface heat generated is achieved by having a perfectly circular carrier.
I wonder if xt60 are adequate since they are rated for 60 amps steady. May be it is too low, this should be double checked with the veteran guys.
.Superfly. is offline Find More Posts by .Superfly.
Old Nov 19, 2012, 03:25 AM
Endolf is online now
Find More Posts by Endolf
BMFA Heli Examiner
Endolf's Avatar
United Kingdom, England
Joined Nov 2012
Hi
My 550 is getting a hobbywing 100a ESC and the motors I'm looking at are around the 90a sustained 150a burst, xt60s are not even close, xt90 would be pushing it, the EC5s are rating to 120a sustained from what I've read.
Endolf
Endolf is online now Find More Posts by Endolf
Old Nov 19, 2012, 03:37 AM
Joined Nov 2012
Yes, I couldn't put it better myself.
I wasn't aware about the current draw requirements, so the EC family seems to be the sturdiest design at present. My finger feeling experience with the EC3 is that it is very easy to handle, xt connectors are a bit more tight to operate, too.
Old Nov 19, 2012, 04:05 AM
BMFA Heli Examiner
Endolf's Avatar
Joined Nov 2012
EC3 are also 60a like the xt60s.
Endolf
Old Nov 19, 2012, 04:49 AM
Joined Nov 2012
Oh yes, I just cut corners there while typing, I meant that the general design of the EC family has an easier grip (because the two round plastic bodies are carved in, unlike the flat surface of the XT family).
Old Nov 19, 2012, 06:50 AM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
All of my helicopters- 450s and 600s use the deans connectors. I have never had a problem. Am I wrong in that assumption?
fpainter3 is offline Find More Posts by fpainter3
Old Nov 19, 2012, 07:06 AM
BMFA Heli Examiner
Endolf's Avatar
Joined Nov 2012
Deans themselves publish no data that I can find on the rating of their connectors. The ultra (normal rather than micro deans) seem to be interpreted differently by different people. Some claim to be using them on 700 sized machines pulling over 100a continuous quite happily and returning with cool connectors (the rating is pretty much about heat dissipation). The claim on the Deans website is less resistance than 12awg wire, which means 40a. I have seen sites selling them stating ratings of 100a and 50a. It looks like deans just don't have the information available.
If you using them fine and are happy with them, then I don't see any evidence to suggest you need to change them.
I wouldn't pick them by choice for my 550 though.
Endolf
Old Nov 19, 2012, 01:38 PM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Given the heavy gauge wire used on the big 5000 packs I have discounted Deans connectors altogether. It's almost impossible to get enough heat into the solder joint (for me at least) without destroying the connector in the process. That said my iron is a little on the small side @ 35watt for the job. For me it's likely to be EC5's or XT90's. I'll have to change sooner rather than later, after yesterdays flying session I was removing my last pack from the model and accidentally allowed the bullets to make contact, Murphys law dictated that a tiny bit of exposed connector made contact. After a loud crack and flash then a change of underpants I found a small crescent burned into the female connector and a groove has appeared in the side of the male. Thankfully the battery is ok but it certainly gives food for thought.
Old Nov 19, 2012, 02:18 PM
Joined Nov 2012
Actually, on a side note... since the batteries are delivered with the bullet connectors, why is it that we should change them into a EC or XT or deans connector?
Can we not keep the two leads separate and connect them one at a time?
Old Nov 19, 2012, 02:25 PM
2Doggs is online now
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I use bullet connectors on all my 450 batteries, and hook them up that way. It's just a slight inconvenience, compared with a twin lead, though you do need to be wary of shorting the leads out.
2Doggs is online now Find More Posts by 2Doggs
Old Nov 19, 2012, 04:59 PM
evltoy is offline
Just fly
evltoy's Avatar
Joined Jan 2011
Looks like I'll be going with the EC5 on the 550. Now I'll have to make up some charge leads and get the cool fused para board wih the built in EC5s
Thanks for the info guys.
Old Nov 27, 2012, 09:23 AM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
First of the build videos. There will likely be only two.
HK550TT FBL Build Video: Part I (13 min 58 sec)
Site Sponsor
Discussion HK550 or indeed any 550e clones hedgeheli Large Electric Helis 6 Jan 03, 2014 05:29 AM
Sold TT Raptor G4 FBL With all the good stuff!!! wolfcbr2003 Aircraft - Fuel - Helis (FS/W) 0 Jul 16, 2012 10:49 PM
Discussion New hk550 Foam boy Large Electric Helis 2 May 25, 2012 01:48 AM
Sold 2 New clone 450ProTT GT FB&FBL ARFs like newAlign 3G +Rx +ton of tt sprs 175 shipd blueindian Aircraft - Electric - Helis (FS/W) 3 May 09, 2012 02:01 PM
Sold JS Models 3D Frenzy 50 FBL Airframe with TT .53 Redline/Align muffer HD Hucker Aircraft - Fuel - Helis (FS/W) 0 Apr 12, 2012 08:06 PM
