Old Aug 10, 2012, 11:06 AM
Joined Jul 2012
Taking stills from video
Just wondering what quality stills could come from a video. I'll be using a Sony NEX 5n. It would be great to just shoot video and then cherry pick the best stills out of it. Anybody do this?
Tom
tombrown1 is offline Find More Posts by tombrown1
Old Aug 10, 2012, 02:32 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
quality will be 1080p which is quite low res....
even a 4k video camera is much lower than most cameras today.
it is much better to make a video from stills than a still from video
Adidas4275 is offline Find More Posts by Adidas4275
Old Aug 10, 2012, 03:28 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Up to 8 x 10, a 1280 x 720 video will be OK.
The pixelizations don't begin to get intrusive..
Sparky Paul is offline Find More Posts by Sparky Paul
Old Aug 10, 2012, 03:40 PM
United States, TX, Thrall
Joined Feb 2010
It depends on camera quality and then the print size if you do normal 8x10 or smaller you can do a descent job with the prints, but again it depends on the camera some will not do a great job other will surprise you.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Aug 10, 2012, 04:20 PM
Adidas4275's Avatar
Joined Mar 2011
Sure but mike the resolution cannot be any higher than 1080 1280x1080p which is like a 2mp camera.
Old Aug 10, 2012, 11:34 PM
Joined Jul 2012
Thanks for the responses.
Looks like I'll be fine using them for a decent bang-up job, but for anything important I'll switch to stills.
Best,
Tom
Old Aug 16, 2012, 07:02 AM
Joined Jul 2009
These were taken from a NEX-5 HD1080p video. They need a bit of photoshop work but are more or less ok for low res publication such as online.
diakatche is offline Find More Posts by diakatche
Old Aug 16, 2012, 09:45 AM
Joined Feb 2012
Video captures are okay if you have no other choice but honestly I think they look pretty crappy and wouldnt use them unless I absolutely had to.
epyonxero is offline Find More Posts by epyonxero
Old Aug 16, 2012, 11:06 AM
Joined Jul 2009
agreed. But unless you have a camera that can take stills while shooting video, not many other options in this case.
Can fix a lot of the issues in post if needed. Definitely not good enough for print other than newsprint. Web, can get away with it.
Old Aug 16, 2012, 11:13 AM
Adidas4275's Avatar
Joined Mar 2011
Most cameras that can take stills while recording do so at a lower res as well.
Old Aug 16, 2012, 12:57 PM
Joined Jul 2009
That is the problem. Anyone try this with the GH1? I have heard it can do full frame pics and video at the same time. So can a VS100 but that's a bit out of my price range.
Old Aug 17, 2012, 02:19 AM
United States, OR, Portland
Joined Aug 2011
Also, that's what makes "intervalometers" so popular, taking stills every whatever seconds. One post I saw commented that every 7 seconds seemed like the best compromise between getting "that one shot" and having to go through a $h_t load of pics.
But you'd need a separate cam for the FPV feed..
Jim
Jem3 is offline Find More Posts by Jem3
Old Aug 17, 2012, 06:11 AM
Joined Jul 2009
Jim
MK FC has a programmable trigger as does the APM (relay) which we've used with mixed success. I would love to try the GoPro with WiFi or EOS 5DmkII or mkII with wifi module. Direct control of the camera via wifi would be pretty cool, but also REAL expensive I think.
For now, just set it on auto and sort through the pics. A flight won't fill even a 2gb card unless you are using an NEX-7.
Side note, anyone been able to get liveview via HDMI working on the GH1 or any NEX?
Discussion Keychain that takes stills? TJFINAN Aerial Photography 4 Jun 06, 2012 06:37 AM
Discussion Still learning but a video from the other day - slow-mo help with 60i? slowjett Aerial Photography 5 Mar 20, 2012 08:51 AM
Discussion Jaffa from air - PIC.. then ..from water take off video guyg Aerial Photography 1 Apr 26, 2008 07:47 AM
Aerial video/still photo from Partenavia Mike_Then Aerial Photography 8 Nov 20, 2001 08:10 AM
